Hi, I was looking through the code of P095 to see if it was possible to redefine the size of the TFT to accomodate the 1.4 version (128X128) but couldn't figure it out. The plugin works with it (https://docs.wemos.cc/en/latest/d1_mini ... t_1_4.html) but half of the screen is garbage.
Thanks,
Also, what does TS_CS stand for ?
Grumpf.
P095 With 1.4 TFT shield
Re: P095 With 1.4 TFT shield
P095 is meant to drive a ILI9341, not the ST7735s, and I'm not sure how compatible these chips are.
The TS_CS should be a chip-select signal, to be able to have multiple displays on the same SPI bus, but I don't know if that is supported by ESPEasy (don't own that type of display, so can't test)
I think that's a left-over for touch screen support in the code.
TS_CS sounds like "Touch Screen Chip Select"
With SPI communication you have 2 data pins (input: MISO and output: MOSI), a clock and one chip select to each device connected to the same SPI bus to signal if the communication is meant for that device.
So if a display and a touch screen is connected to the same device, you need 2 CS pins to talk to either of them.
