Blynk - offline device
Posted: 03 Aug 2020, 20:48
I am using a Blynk controller (local server and cloud) and a modul Wemos D1 mini.
The problem is because the Blynk app always shows that the device (Wemos D1 mini) is offline.
I can send data from ESP_Easy to Blynk and it also displays it correctly.
Communication from Blynk to D1 mini does not work. For example, I can't turn on the LED from the Blynk app.
If I program in Arduino and use <BlynkSimpleEsp8266.h>, Blynk signals that the D1 mini is successfully connected.
Communication also works in both directions. I can also turn on an LED or relay from the app.
What's wrong with ESP_Easy that communication isn't two-way? Does anyone have experience?
I used various older versions of ESP_Easy and also the latest version of ESP_Easy_mega_20200801.
Thanks for the help,
Damjan
Damjan
