RF link firmware non reconnu
French support forum, post can be done in French, answers will either be in French or in English.
Moderators: rtenklooster, Voyager, BertB, Stuntteam, Deennoo
jerem
#1 Post by jerem » 31 Jul 2020, 18:35
Bonjour
j ai fabriqué une passerelle rf433 avec un mega + rxb6+ fs1000a en suivant un tuto. https://opendomotech.com/fabriquer-rfli ... du-rfxcom/ 1
je suis sur un RPI3
jeedom v4.0.60
version plugin: 2020-01-18 02:07:09
suite a l installation du plugin le status du démon resté NOK . quelqu un m a aider et maintenant le démon est OK .
mon problème est que le firmware n est pas reconnu apparemment il y a des erreurs type Arduino dans les log d’installation de dépendance
voila le log
Début de l'installation
--2020-07-30 19:25:13-- https://raw.githubusercontent.com/lunar ... /nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.120.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1491 (1.5K) [text/plain]
Saving to: ‘dependencies.sh’
0K . 100% 2.14M=0.001s
2020-07-30 19:25:13 (2.14 MB/s) - ‘dependencies.sh’ saved [1491/1491]
dependencies.sh: 3: [: rflink: unexpected operator
Version actuelle : 12
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (10.2019051400+rpi1).
0 upgraded, 0 newly installed, 0 to remove and 44 not upgraded.
Ok, version suffisante
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
> @serialport/bindings@9.0.0 install /var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings
> prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=12.18.3 runtime=node arch=arm libc= platform=linux)
make: Entering directory '/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build'
CXX(target) Release/obj.target/bindings/src/serialport.o
In file included from ../src/./serialport.h:6,
from ../src/serialport.cpp:1:
../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
, reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
../src/serialport.cpp: At global scope:
../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
In file included from ../../../nan/nan.h:56,
/var/www/.cache/node-gyp/12.18.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
(node::addon_register_func) (regfunc), \
/var/www/.cache/node-gyp/12.18.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
NODE_MODULE(serialport, init);
CXX(target) Release/obj.target/bindings/src/serialport_unix.o
In file included from ../src/serialport.h:6,
from ../src/serialport_unix.cpp:2:
../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
CXX(target) Release/obj.target/bindings/src/poller.o
In file included from ../src/poller.cpp:1:
CXX(target) Release/obj.target/bindings/src/serialport_linux.o
SOLINK_MODULE(target) Release/obj.target/bindings.node
COPY Release/bindings.node
make: Leaving directory '/var/www/html/plugins/rflink/resources/node_modules/@serialport/bindings/build'
> serialport@9.0.0 postinstall /var/www/html/plugins/rflink/resources/node_modules/serialport
> node thank-you.js
[96m[1mThank you for using serialport![96m[1m
[0m[96mIf you rely on this package, please consider supporting our open collective:[22m[39m
> [94mhttps://opencollective.com/serialport/donate[0m
npm notice created a lockfile as package-lock.json. You should commit this file.
added 124 packages from 114 contributors and audited 124 packages in 104.004s
5 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
Fin de l'installation
autre chose les trames sont visible dans le log node
Fri Jul 31 2020 15:19:39 GMT+0100 (British Summer Time) - 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
Fri Jul 31 2020 15:19:39 GMT+0100 (British Summer Time) - Send Value : 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
Fri Jul 31 2020 15:19:39 GMT+0100 (British Summer Time) - SaveValue Error : null
Fri Jul 31 2020 15:19:41 GMT+0100 (British Summer Time) - Server connected
Fri Jul 31 2020 15:19:41 GMT+0100 (British Summer Time) - 20;01;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
Fri Jul 31 2020 15:19:41 GMT+0100 (British Summer Time) - Send Value : 20;01;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
Fri Jul 31 2020 15:19:41 GMT+0100 (British Summer Time) - SaveValue Error : null
Fri Jul 31 2020 15:20:04 GMT+0100 (British Summer Time) - 20;02;EV1527;ID=0216c0;SWITCH=04;CMD=ON;
Fri Jul 31 2020 15:20:04 GMT+0100 (British Summer Time) - Send Value : 20;02;EV1527;ID=0216c0;SWITCH=04;CMD=ON;
Fri Jul 31 2020 15:20:04 GMT+0100 (British Summer Time) - SaveValue Error : null
Fri Jul 31 2020 15:32:47 GMT+0100 (British Summer Time) - Jeedom url : http://127.0.0.1:80/jeedom/plugins/rfli ... DDPTWya0iE, gwAddress : /dev/ttyACM0
Fri Jul 31 2020 15:32:47 GMT+0100 (British Summer Time) - server bound on 8020
Port open
Fri Jul 31 2020 15:32:48 GMT+0100 (British Summer Time) - 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
Fri Jul 31 2020 15:32:48 GMT+0100 (British Summer Time) - Send Value : 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
Fri Jul 31 2020 15:32:49 GMT+0100 (British Summer Time) - SaveValue Error : null
Fri Jul 31 2020 15:46:01 GMT+0100 (British Summer Time) - 20;01;EV1527;ID=0216c0;SWITCH=01;CMD=ON;
Fri Jul 31 2020 15:46:01 GMT+0100 (British Summer Time) - Send Value : 20;01;EV1527;ID=0216c0;SWITCH=01;CMD=ON;
Fri Jul 31 2020 15:46:01 GMT+0100 (British Summer Time) - SaveValue Error : null
Fri Jul 31 2020 15:46:08 GMT+0100 (British Summer Time) - 20;02;EV1527;ID=0216c0;SWITCH=04;CMD=ON;
Fri Jul 31 2020 15:46:08 GMT+0100 (British Summer Time) - Send Value : 20;02;EV1527;ID=0216c0;SWITCH=04;CMD=ON;
Fri Jul 31 2020 15:46:08 GMT+0100 (British Summer Time) - SaveValue Error : null
Fri Jul 31 2020 15:46:10 GMT+0100 (British Summer Time) - 20;03;EV1527;ID=0216c0;SWITCH=01;CMD=ON;
Fri Jul 31 2020 15:46:10 GMT+0100 (British Summer Time) - Send Value : 20;03;EV1527;ID=0216c0;SWITCH=01;CMD=ON;
Fri Jul 31 2020 15:46:10 GMT+0100 (British Summer Time) - SaveValue Error : null
Fri Jul 31 2020 15:46:11 GMT+0100 (British Summer Time) - 20;04;EV1527;ID=0216c0;SWITCH=04;CMD=ON;
Fri Jul 31 2020 15:46:12 GMT+0100 (British Summer Time) - Send Value : 20;04;EV1527;ID=0216c0;SWITCH=04;CMD=ON;
Fri Jul 31 2020 15:46:12 GMT+0100 (British Summer Time) - SaveValue Error : null
Fri Jul 31 2020 15:46:12 GMT+0100 (British Summer Time) - 20;05;EV1527;ID=0216c0;SWITCH=01;CMD=ON;
Fri Jul 31 2020 15:46:12 GMT+0100 (British Summer Time) - Send Value : 20;05;EV1527;ID=0216c0;SWITCH=01;CMD=ON;
Fri Jul 31 2020 15:50:40 GMT+0100 (British Summer Time) - 20;06;EV1527;ID=0216c0;SWITCH=04;CMD=ON;
Fri Jul 31 2020 15:50:40 GMT+0100 (British Summer Time) - Send Value : 20;06;EV1527;ID=0216c0;SWITCH=04;CMD=ON;
Fri Jul 31 2020 15:50:40 GMT+0100 (British Summer Time) - SaveValue Error : null
Si quelqu un y comprend quelque chose et peu me sortir de la je lui en serai très reconnaissant
