Next release?
Posted: 22 Jun 2020, 10:27
by Guahtdim
Is there a new release coming soon?
If not could you please release the source so I could add some units?
I would really like to include the ecowitt soilmoisture monitors. There is already code for it:
https://github.com/merbanan/rtl_433/blo ... neoffset.c
Way down in line 514 (Fine Offset WH51, ECOWITT WH51, MISOL/1 Soil Moisture Sensor)
Re: Next release?
Posted: 23 Jun 2020, 00:05
by Stuntteam
and way down in line 1005:
.name = "Fine Offset Electronics/ECOWITT WH51 Soil Moisture Sensor",
.modulation = FSK_PULSE_PCM,
You will never be able to receive these signals with the OOK based receivers due to the very simple fact that the transmitter is using FSK modulation..
Re: Next release?
Posted: 23 Jun 2020, 10:09
by Guahtdim
Thank you for considering and finding what I am missing!
Re: Next release?
Posted: 11 Dec 2021, 10:55
by Ton_vN
Looking for read-out of WH51 Moisture-sensor.
Have a 'standard' RFLinkGateway with testfirmware v49.4
(to include WS7000P_19).
In that perspective just wondering what is meaning of
Is the implication that the complete contents of the indicated section at Github are useless for those using OOK-receiver, or just the bottom lines which clearly refer to OOK-receiver?
Hint appreciated how to link the github-script into the firmware of the RFLinkGateway.
