I would buy this relay board with Esp8266.
It will be possible to replace the firmware with ESP Easy?
http://researchdesignlab.com/modules/wi ... p8266.html
Esp8266 8 channel relay board
- rdl_wifi-relay_esp8266_1.jpg (51.87 KiB) Viewed 5120 times
Re: Esp8266 8 channel relay board
The documentation for this board on the website is scarce.
When I look at the pictures it looks like:
ESP8266-12 E/F very likely to have 4MB flash memory.
JP2 looks like a programming connection, with Gnd, Vcc, Rxd, Txd and Reset.
The ULN2803 is the relaisdriver and there seems to be no optical isolation , which are often implemented on relaisboards for sale at Ebay/Aliexpress.
So when you buy this board and solder a header on jp2 you probably will succeed in flashing the latest ESPEasy on it.
However:
The 8 relais seems to be driven by 8 GPIO pins from the ESP. The original firmware will most likely also use RX/TX GPIO_1/3 as outputs to have enough output_pins for the relais.
When you flash ESPEasy on it you cannot use these 2 pins as outputs.
So in the most optimistic view you can flash it with espeasy and effectively use 6 relais.
However:
Following this french forum :
http://easydomoticz.com/forum/viewtopic.php?f=7&t=1507
You ll have a exemple using ESPEasy and a saintsmart relay board
