i have this temperature sensor, which can be found on many thermometers on ebay, banggood, gearbest, ali epxress ....
http://www.avrfreaks.net/forum/chinese- ... r-protocol
Here is the link to some spec documentation
https://fccid.io/R8G-XT200
and one to the manufacturer
http://www.hopefulindustrial.com/#!xh120/c1zra
Here is what i get in RFLink
It seems to be received by RFlink only when i unplugg / replug batteries, and only in debug mode
(It once showed up as Alecto V3 also in domoticz but gave totally weird temp, then never showed up again)
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R35;
20;01;RFUDEBUG=ON;
20;02;DEBUG;Pulses=96;Pulses(uSec)=570,870,450,870,450,870,450,870,450,870,450,870,450,870,450,870,1380,870,1380,900,450,900,450,900,1350,900,1350,900,1350,900,450,900,1350,900,1350,900,1350,900,420,900,450,900,1350,900,1350,900,1350,900,1350,900,450,900,420,900,420,900,1350,900,420,900,420,900,420,900,420,900,420,900,420,900,420,930,420,900,420,900,420,900,420,900,1350,900,1350,930,1350,930,420,930,420,930,420,930,1320,930,1320,6990;
20;03;Alecto V3;ID=0015;TEMP=8119;
20;04;DEBUG;Pulses=88;Pulses(uSec)=540,870,450,870,450,870,450,870,1380,900,1380,870,450,870,450,870,1350,900,1380,900,1350,900,450,900,450,900,1350,900,1350,900,1350,900,450,900,450,900,420,900,420,900,1350,900,420,900,450,900,420,900,1350,900,450,900,420,900,450,900,420,900,420,900,420,900,450,900,420,900,450,900,420,900,450,900,420,900,1350,900,1350,900,1350,900,420,900,420,900,420,930,1320,6990;
20;05;DEBUG;Pulses=82;Pulses(uSec)=480,900,1350,900,1350,900,450,900,450,900,1350,900,1350,900,1350,900,450,900,450,900,1350,900,420,900,420,900,450,900,1350,900,1350,900,420,900,1350,900,450,900,420,900,450,900,1350,900,450,900,420,900,420,900,420,900,450,900,420,900,420,900,420,900,420,900,420,930,420,930,420,900,420,900,450,900,420,900,1350,900,420,900,420,900,1350,6990;
20;06;DEBUG;Pulses=66;Pulses(uSec)=480,870,390,870,1260,870,390,930,390,900,420,930,1320,930,1320,930,420,900,1350,900,450,900,420,900,450,900,1350,900,420,900,420,900,450,900,420,900,450,900,420,900,420,900,420,900,450,900,420,900,450,900,420,900,420,900,420,900,420,900,1350,900,450,900,420,900,1350,6990;
20;07;DEBUG;Pulses=76;Pulses(uSec)=0,450,420,900,1350,900,1350,900,1350,900,420,900,420,900,420,900,1350,900,420,900,1350,900,420,900,1350,900,1350,900,1350,900,420,900,420,900,420,900,1350,900,420,900,420,930,420,900,420,900,420,900,420,900,420,900,420,900,420,930,420,900,420,900,1350,900,420,900,1350,900,1350,900,1350,900,1350,900,1350,900,1350,6990;
20;08;DEBUG;Pulses=86;Pulses(uSec)=540,900,420,900,450,900,1350,900,1320,900,420,900,420,900,1350,930,1320,900,1350,930,420,900,420,930,420,900,420,900,1350,900,420,900,1350,930,1320,900,1350,900,1350,930,420,900,420,900,420,900,1350,930,420,930,420,900,420,900,420,900,420,900,420,930,420,900,420,900,420,900,420,930,420,900,420,900,420,900,420,930,1350,900,1350,900,420,900,420,900,1350,6990;
20;09;DEBUG;Pulses=82;Pulses(uSec)=510,900,1350,900,1350,900,420,900,420,900,1350,900,1350,900,1350,900,420,900,420,900,420,900,420,900,420,900,1350,900,420,900,1350,930,420,900,1350,930,420,900,420,900,420,900,1350,930,420,900,420,930,420,900,420,900,420,900,420,900,420,900,420,900,420,930,420,900,420,900,1350,930,420,930,420,900,420,900,420,900,420,900,420,900,450,6990;
20;0A;DEBUG;Pulses=82;Pulses(uSec)=540,870,1380,870,1380,870,450,870,450,870,1380,870,1350,900,450,900,1350,870,1350,900,1350,900,1350,900,1350,900,1350,900,1350,900,420,900,1350,930,1350,900,420,930,420,900,420,900,1350,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,420,930,1320,930,420,930,1320,6990;
20;0B;DEBUG;Pulses=84;Pulses(uSec)=510,900,450,900,1380,900,1350,900,450,900,450,900,1350,900,1350,900,450,900,1350,900,1350,900,1350,900,420,900,1350,900,420,900,420,900,450,900,420,900,1350,900,420,900,420,900,420,900,1350,900,420,900,450,900,420,900,420,900,420,900,420,900,420,900,420,900,450,900,420,900,420,900,420,900,1350,900,420,900,420,900,420,900,420,900,420,930,1350,6990;
20;0C;DEBUG;Pulses=70;Pulses(uSec)=360,870,390,870,1260,870,1260,840,1260,870,390,900,1350,900,420,900,420,930,420,930,390,930,1320,900,450,900,420,900,450,900,1350,900,450,900,420,900,420,900,420,900,450,900,420,900,420,900,420,900,420,900,420,900,450,900,420,900,1350,900,420,900,420,900,420,900,420,900,420,900,1350,6990;
20;0D;DEBUG;Pulses=80;Pulses(uSec)=1530,900,1380,870,450,900,450,900,1350,900,1350,870,450,900,1350,870,1350,900,1350,900,420,900,450,900,420,900,1350,900,420,900,450,900,1350,900,420,900,420,900,420,900,1350,900,420,900,420,900,420,900,450,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,1350,900,1350,900,420,900,420,900,1350,900,1350,900,420,930,420,6990;
20;0E;DEBUG;Pulses=90;Pulses(uSec)=540,900,450,900,450,870,450,870,450,900,1350,900,1350,900,450,900,420,900,1350,900,1350,900,450,900,1350,900,1350,900,1350,900,420,900,450,900,420,900,450,900,1350,900,420,900,1350,900,420,900,420,900,420,900,1350,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,450,900,420,900,420,900,420,900,420,900,1350,900,1350,900,420,900,1350,900,420,900,420,900,1350,6990;
20;0F;DEBUG;Pulses=64;Pulses(uSec)=1350,870,1260,840,390,870,390,870,420,840,390,930,1320,900,420,930,1320,930,390,930,390,900,450,900,1350,900,420,900,450,900,420,900,450,900,420,900,450,900,420,900,420,900,420,900,420,900,420,900,420,900,1350,900,1350,900,420,900,1350,900,420,900,420,930,1350,6990;
20;10;DEBUG;Pulses=90;Pulses(uSec)=510,900,450,900,450,900,450,900,420,900,1350,900,1350,900,450,900,420,900,1350,900,1350,900,450,900,1350,900,1350,900,1350,900,420,900,420,900,420,900,420,900,1350,900,420,900,1350,900,420,900,420,900,420,900,1350,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,450,900,420,900,420,900,420,930,420,900,1350,900,1350,900,420,900,1350,900,420,900,420,930,1350,6990;
20;11;DEBUG;Pulses=64;Pulses(uSec)=1320,870,1260,840,390,870,390,870,390,870,390,900,1320,930,390,930,1320,960,390,930,420,900,420,900,1350,900,420,900,450,900,420,900,450,900,420,900,420,900,420,900,450,900,420,900,450,900,420,900,420,900,1350,900,1350,900,420,900,1350,900,420,900,420,900,1350,6990;
20;12;DEBUG;Pulses=92;Pulses(uSec)=600,900,450,870,450,900,450,900,450,870,450,870,1380,900,1350,900,450,900,450,900,1350,900,1350,900,450,900,1350,900,1350,900,1350,900,450,900,450,900,450,900,1350,900,420,900,450,900,1350,900,420,900,450,900,420,900,1350,900,420,900,420,900,420,900,450,900,420,900,420,900,420,900,450,900,420,900,420,900,420,900,1350,900,1350,900,420,900,420,900,1350,900,1350,900,420,900,420,6990;
20;13;DEBUG;Pulses=84;Pulses(uSec)=1200,690,450,870,1380,900,1350,900,450,900,450,900,1350,900,1350,900,420,900,1350,900,1350,900,1350,900,450,900,420,900,450,900,1350,900,450,900,1350,900,1350,900,450,900,420,900,450,900,1350,900,450,900,420,900,450,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,1350,900,420,900,420,900,420,900,1350,900,420,900,1350,900,420,6990;
20;14;DEBUG;Pulses=90;Pulses(uSec)=510,900,450,900,450,900,450,870,450,900,1380,870,1350,900,450,900,450,900,1350,900,1350,900,420,900,1350,900,1350,900,1350,900,420,900,450,900,420,900,1350,900,1350,900,420,900,1350,900,420,900,420,900,420,900,1350,900,420,900,420,900,420,900,450,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,1350,900,420,900,420,900,420,900,420,900,420,900,420,6990;
20;15;DEBUG;Pulses=66;Pulses(uSec)=150,840,1260,870,1260,840,390,870,390,900,390,870,1320,930,1320,960,360,960,1290,960,390,960,390,900,420,900,1350,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,450,900,420,900,1350,900,420,900,420,900,420,900,420,900,420,900,450,6990;
20;16;DEBUG;Pulses=92;Pulses(uSec)=540,900,450,870,450,900,450,870,450,900,450,870,1350,900,1350,870,450,900,450,900,1350,900,1350,900,450,900,1350,900,1350,900,1350,900,420,900,450,900,420,900,1350,900,1350,900,1350,900,1350,900,420,900,420,900,420,900,1350,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,1350,900,1350,900,420,6990;
20;17;DEBUG;Pulses=80;Pulses(uSec)=1350,900,1350,900,450,900,450,900,1350,900,1350,900,450,900,1350,900,1350,900,1350,900,420,900,420,900,450,900,1350,900,1350,900,1350,900,1350,900,420,900,420,900,420,900,1350,900,450,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,420,900,1350,900,1350,900,420,6990;
XT200 chinese temperature sensor
Re: XT200 chinese temperature sensor
Lets add support for it.. I have send you a message..
