Old LCD with ESP ?
Posted: 21 Apr 2020, 14:13
by sawo
Hi all,
do you think it is possible to use an old lcd display from an thermometer, such as this one (see attachment) to controll it via an esp?
I want to show the temperatur from the aquarium.
Sascha
Re: Old LCD with ESP ?
Posted: 21 Apr 2020, 19:51
by Ath
Not sure this belongs in the experimental forum, hardware seems more appropriate, but we'll see if a moderator moves it
Do you have any info on the lcd controller and possibly other ic's that are used? It is rather hard to find anything without that kind of information...
Posted: 22 Apr 2020, 00:36
by TD-er
Those thermometers often have a single chip, which is not accessible as its silicon is mounted directly on the PCB and has a blob poured over it.
So then you have to find out the lines of the LCD to what 'pixel' and make your own controller.
If you can do that, integrating it with ESPEasy is the least of your problems
Posted: 22 Apr 2020, 08:02
by sawo
Hi TD-er,
okay I'll take it apart and see what's in it.
THX
