I'm running Home Assistant on a PI3.
I use RFLink connected to that PI and I can receive data from the RFLink.
Now I want to integrate my RTS somfy covers (volets).
I followed the instructions to pair the cover with RFLink using RFlink loader and my PC.
I can send this command :
10;RTS;02FFFF;0;down
and the cover is going down.
Now I'm plugging RFlink to the PI and have in my configuration.yaml:
cover:
- platform: rflink
devices:
rts_d61447_01:
(bad indent do to copy/paste)
the name of the cover (voletsalon) is recognised in the logs.
But nothing happen.
I put the RFLINK as close to the cover as possible and as far from the PI as possible....no move!
Any help welcome!
Thank you
Home Assistant to RFLnk to somfy covers
Re: Home Assistant to RFLnk to somfy covers
If I'm not mistaken, your config should be as follows:
cover:
- platform: rflink
devices:
rts_02FFFF_0:
Did you also enable the RFLink integration?
https://www.home-assistant.io/integrati ... figuration
