TSOP4838 IR Input. different values for on/off normal?
tozett
#1 Post by tozett » 02 Feb 2016, 21:28
i hooked up a TSOP4838 on GPIO12 with R076.
i press one button on my samsung or Pioneer remote, i see a sequenz for this single button of the remote.
also i would like to send the "code" with the http-request/push template, not only the float ? "value" (because the code is shorter).
do i have to configure something more?
is this normal, that the remote sends one code for the button-press, and another arbitrary for release?
the "press"-code seems the same, the "release"-code seems to change..
this is two time the on/off=press/release sequence of the same button (info) on my samsung remote:
Feb  2 21:21:26 ESP Unit: 0 : HTTP : closing connection
PRESS -- Feb  2 21:21:32 ESP Unit: 0 : IR   : Code e0e0f807
Feb  2 21:21:32 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:21:32 ESP Unit: 0 : /esp01?device=sw13?device=&param=IR&value=3772839936.00
Feb  2 21:21:32 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:21:32 ESP Unit: 0 : IR   : Code a6240345
Feb  2 21:21:32 ESP Unit: 0 : HTTP : Delay 1000 ms
Feb  2 21:21:33 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:21:33 ESP Unit: 0 : /esp01?device=sw13?device=&param=IR&value=2787377920.00
Feb  2 21:21:33 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:21:36 ESP Unit: 0 : DS   : Temperature: 23.87 (28-ff-dd-f0-4c-4-0-3a)
Feb  2 21:21:36 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:21:36 ESP Unit: 0 : /esp01?device=sw13?device=&param=Temperature&value=23.87
Feb  2 21:21:36 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:21:46 ESP Unit: 0 : DS   : Temperature: 23.94 (28-ff-dd-f0-4c-4-0-3a)
Feb  2 21:21:46 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:21:46 ESP Unit: 0 : /esp01?device=sw13?device=&param=Temperature&value=23.94
Feb  2 21:21:46 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:21:46 ESP Unit: 0 : WD   : Uptime 6 ConnectFailures 0 FreeMem 24888
Feb  2 21:21:46 ESP Unit: 0 : UDP  : Send Sysinfo message
PRESS -- Feb  2 21:21:49 ESP Unit: 0 : IR   : Code e0e0f807
Feb  2 21:21:49 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:21:49 ESP Unit: 0 : /esp01?device=sw13?device=&param=IR&value=3772839936.00
Feb  2 21:21:50 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:21:50 ESP Unit: 0 : IR   : Code 49f3e444
Feb  2 21:21:50 ESP Unit: 0 : HTTP : Delay 1000 ms
Feb  2 21:21:50 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:21:50 ESP Unit: 0 : /esp01?device=sw13?device=&param=IR&value=1240720512.00
Feb  2 21:21:51 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:21:56 ESP Unit: 0 : DS   : Temperature: 23.87 (28-ff-dd-f0-4c-4-0-3a)
Feb  2 21:21:56 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:21:56 ESP Unit: 0 : /esp01?device=sw13?device=&param=Temperature&value=23.87
Feb  2 21:21:56 ESP Unit: 0 : HTTP : closing connection
this is the same button from my pioneer remote:
Feb  2 21:23:56 ESP Unit: 0 : HTTP : closing connection
PRESS -- Feb  2 21:24:00 ESP Unit: 0 : IR   : Code fc200794
Feb  2 21:24:00 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:24:00 ESP Unit: 0 : /esp01?device=sw13?device=&param=IR&value=4229957632.00
Feb  2 21:24:01 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:24:01 ESP Unit: 0 : IR   : Code 8a87cad4
Feb  2 21:24:01 ESP Unit: 0 : HTTP : Delay 1000 ms
Feb  2 21:24:01 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:24:01 ESP Unit: 0 : /esp01?device=sw13?device=&param=IR&value=2324155136.00
Feb  2 21:24:02 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:24:06 ESP Unit: 0 : DS   : Temperature: 23.87 (28-ff-dd-f0-4c-4-0-3a)
Feb  2 21:24:06 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:24:06 ESP Unit: 0 : /esp01?device=sw13?device=&param=Temperature&value=23.87
Feb  2 21:24:06 ESP Unit: 0 : HTTP : closing connection
PRESS -- Feb  2 21:24:13 ESP Unit: 0 : IR   : Code fc200794
Feb  2 21:24:13 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:24:13 ESP Unit: 0 : /esp01?device=sw13?device=&param=IR&value=4229957632.00
Feb  2 21:24:13 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:24:13 ESP Unit: 0 : IR   : Code 105f71ef
Feb  2 21:24:13 ESP Unit: 0 : HTTP : Delay 1000 ms
Feb  2 21:24:14 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:24:14 ESP Unit: 0 : /esp01?device=sw13?device=&param=IR&value=274690528.00
Feb  2 21:24:14 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:24:16 ESP Unit: 0 : DS   : Temperature: 23.94 (28-ff-dd-f0-4c-4-0-3a)
Feb  2 21:24:16 ESP Unit: 0 : HTTP : connecting to 192.168.14.253
Feb  2 21:24:16 ESP Unit: 0 : /esp01?device=sw13?device=&param=Temperature&value=23.94
Feb  2 21:24:16 ESP Unit: 0 : HTTP : closing connection
Feb  2 21:24:16 ESP Unit: 0 : WD   : Uptime 8 ConnectFailures 0 FreeMem 24888
Feb  2 21:24:16 ESP Unit: 0 : UDP  : Send Sysinfo message
tozett
Re: TSOP4838 IR Input. different values for on/off normal?
#2 Post by tozett » 02 Feb 2016, 21:32
i tried to test it again after posting, but now it seems to get noise from the IR. is this possible?
its configured with the default device setting "pull-up". maybe wrong?
tozett
#3 Post by tozett » 03 Feb 2016, 19:48
i recognized some erratic receives, where no remote was sending anything.
i cannot really code something, but google 8-)
and if found this pieces, which led me to a
+1 Feature-Request: give out the recognized remote (sony/sanyo/technics..)
+1 Feature-Request: IR-Send (sometime?)
https://github.com/juanpintom/Souliss_E ... Receiver.h
http://internetofhomethings.com/homethings/?p=899
tozett
#4 Post by tozett » 03 Feb 2016, 20:20
i looked like a "drift" in the receiving quality over time.
i cold-reset the ESP. than i took two different small remotes and got clear readings.
and always 1 code for 1 button.
i exchanged the batteries of the technics remote.
i got clear readings (after the cold-reboot) with the technics-remote
still 1 code for the button-press, and another abitrary for the release.
the same with some buttons of my samsung-remote.
with the "GUIDE" button i got abritrary codes on button press and on release.
so far, so good
tozett
#5 Post by tozett » 04 Feb 2016, 07:39
just to fill the record:
i got clear readings after an uptime of 600+ minutes...
but actually i am in a dark environment...
so there is maybe no "drift" but irritation through "scattered light" in the evening, when all lights an on in the room.
i will check this, if i maybee need a box around the small IR-receiver
Deennoo
#6 Post by Deennoo » 21 Feb 2016, 12:05
I'm on it to, will try on a box, because openspace rive lot of flase code.
Deennoo
#7 Post by Deennoo » 23 Feb 2016, 23:00
Made some test with ans without box, and with 2 differents IR reciever results are the same, to much false code to be usable.
Maybe a learning méthode have to be done like LIRC do (only the first part), just to reconize which protocole have to be use.
tozett
#8 Post by tozett » 24 Feb 2016, 07:26
i had a lot of false readings because of weak batteries in two of my remotes.
maybe usefull to try again with fresh batteries?
Deennoo
#9 Post by Deennoo » 24 Feb 2016, 07:33
OK will try.
But i don't have any problème with LIRC.
Deennoo
#10 Post by Deennoo » 24 Feb 2016, 14:05
I'm back with new battery and a real TSOP4838 (on previous test i use a HSIR38S2 stolen from an old hifi parts)...
Have to admit that it is really better, but sometime false code still appear.
