How to send codes to devices in learn mode
Posted: 01 Feb 2016, 23:38
by cherowley
Hi!
I would like to setup a manual switch in domoticz then put a home easy light dimmer in learn mode and get it trained but most devices, not just home easy, need you to keep your finger on the remote button for a few second thus repeating the code multiple times until leaning is complete.
Is this possible with domoticz and rflink?
Cheers!
Re: How to send codes to devices in learn mode
Posted: 02 Feb 2016, 00:10
by Voyager
In Domoticz, the manual switch creationg has a test button. Pressing this button sends the ON signal.
You can press it multiple times to pair..
Posted: 02 Feb 2016, 10:36
by cherowley
Many thanks voyager for that suggestion, tried it now but unfortunately it doesn't repeat quickly enough. Plus straight after sending the on code I need to send the off code (for home easy devices)..
Posted: 21 Jul 2016, 11:51
by grib77
I've got the same request, i'm using rflink firmeware v42, and i see 'Added: Command "echo" function to auto create devices without the need of remote controls.'
But I don't know how to use this feature with domoticz and emw110 plug.
Does anyone have an idea ?
regards
Posted: 04 Aug 2016, 20:13
by daveabbott007
i have the HE-206 ceiling rose's and and the plug in dimmer (cant remember the model) and i have them setup as follows
in Domotics Switch's page,
click Manual Light/Switch
Hardware: RFlink (What ever your RFlink device is called)
Device Name: your device name here
Switch Type: Dimmer
Type: AC
ID: 0 10 00 41 (alternately 0 00 00 42 works aswell)
Unit code: 1 (increment this for each new device)
Once you setup one, put the light in learning mode then click "ON" in domoticz for the relevant new switch and all should work fine inc dimming.
the result for 3 of them in the log looks like the following.
RFLink Sending: 10;NewKaku;000042;2;ON
RFLink Sending: 10;NewKaku;000041;2;ON
RFLink Sending: 10;NewKaku;1000041;1;ON
Hope this helps
all the best
