octavius_8
#1
Post
by octavius_8 » 04 Mar 2020, 11:32
Hello espeasy community
maybe someone can help me with my problem. We are currently working on a school project and use espeasy to measure temperature, humidity and orientation (angle XYZ).
Unfortunately, the data from Gyro MPU6050 shows only acceleration values. Is there a way to convert the information into angles. For example with a formula or using rules.
Our configuration:
Espeasy release
- ESPEasy_mega-20191208-17-PR_2820 (ESP_Easy_mega-20191208-17-PR_2820_test_beta_ESP8266_4M1M.bin)
The Hardware
Thank you in advance for your ideas
Post
by TD-er » 04 Mar 2020, 12:51
Not supported in rules, but I guess we could make its output selectable to generate a roll/pitch value.
See
https://wiki.dfrobot.com/How_to_Use_a_T ... lt_Sensing
Determine the roll and pitch like that will result in quite unstable readings when one of the sensor's axis is close to being vertical.
So I guess it also needs some filtering
And in most use cases, those are just the orientations used the most. (measuring if something is level or not)
octavius_8
#3
Post
by octavius_8 » 04 Mar 2020, 14:09
Thanks for the quick response, that means I have to use the formula field (UI Espeasy) or alternatively the plugin has to be adapted for the selectable output.
Can you tell me what exactly needs to be done. Is it difficult?
Post
by TD-er » 04 Mar 2020, 14:42
Well it looks like there needs to be some changes in the plugin.
Also I'm not really sure how stable the results will be.
So maybe you have enough experience in math to see for yourself how useful it will be and what may be needed?
It looks like the plugin only outputs a single value, or which 3 selections are gyroscopic values per axis.
Not sure what the range of these values is (pct, angle in deg or rad, something else?), but it looks like that one can already be used to compute the angle with some plane.
Maybe that can already be tested first, to get some feeling of whether the sensor is actually usable for your purpose? By using the G-value relative to a single axis, you may limit the detection range, but at least you can see if it is somewhat usable or not.
If it is usable, I can add the computed pitch and roll values as output functions.
For this I do need to know if the sensor does need some kind of "reset" or "calibration" and also the unit of measure this G-value does output.
octavius_8
#5
Post
by octavius_8 » 04 Mar 2020, 15:52
for example in arduino sketch (s. picture below) the raw data can be called up directly from MPU6050 and displayed in the serial monitor (second picture).
Unfortunately I am not an IT and cannot apply the adjustments to the plagin by my self
and i will need your help. I am also slightly surprised that so far nobody aks for the Gyro angle option (in degrees).
A reset or calibration is not necessary, because we use the Sleep Mode to save battery and the data can remain absolute.
#include<Wire.h>
const int MPU6050_addr=0x68; // I2C address of the MPU-6050
int16_t AccX,AccY,AccZ,Temp,GyroX,GyroY,GyroZ;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU6050_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
Serial.begin(9600);
void loop(){
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU6050_addr,14,true);
AccX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AccY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AccZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Temp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyroX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyroY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyroZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Serial.print("AccX = "); Serial.print(AccX);
Serial.print(" || AccY = "); Serial.print(AccY);
Serial.print(" || AccZ = "); Serial.print(AccZ);
Serial.print(" || Temp = "); Serial.print(Temp/340.00+36.53);
Serial.print(" || GyroX = "); Serial.print(GyroX);
Serial.print(" || GyroY = "); Serial.print(GyroY);
Serial.print(" || GyroZ = "); Serial.println(GyroZ);
delay(100);
Data of the MPU6050
3 Axis Accelerometer Sensor Gyroscope 6DOF Module 3.3V-5V
chip: MPU-6050
Communication: standard IIC communication agreement
Chip built-in 16 bit AD converter, 16 bits of data output
The gyroscope range: + 250 500 1000 2000 ° /s
Acceleration range: ± 2 ± 4 ± 8 ± 16 g
- Arduino_MPU6050_Monitor.jpg (22.66 KiB) Viewed 17206 times
octavius_8 on 04 Mar 2020, 16:37, edited 2 times in total.
Post
by TD-er » 04 Mar 2020, 16:03
Please make an issue for it, as I am sure I will forget it when it is posted on the forum.
And hopefully someone else may also pick up the issue to make a pull request for it. (I'm a bit swamped in other stuff to do right now)
Wolfsbane
#8
Post
by Wolfsbane » 09 Jun 2022, 05:56
octavius_8 wrote: ↑04 Mar 2020, 15:52
#include<Wire.h>
void setup(){
Wire.begin();
Serial.begin(9600);
void loop(){
delay(100);
Data of the MPU6050
chip: MPU-6050
Thank you for this example, may I ask how to map the AccX to 180-degree values?
Users browsing this forum: No registered users and 128 guests
