I am using the mega-20200204 firmware on a wemos D1 mini. I am new to ESP Easy and I am really suprised how easy it was to setup my system (OLED1306 and HC-SR04). Everything works as expected, except:
I am not able to select GPIO=None for a switch input device in the web interface. The same happens with the Display Button in the OLED device. I accidently set this to a GPIO. However, I am not using it and want to set it to NONE. After submitting the changes (None) my previous choosen GPIO is displayed again.
For reproducing I added a new switch device. The GPIO is set to None by default. Once changed to a real GPIO I can't set it back to None anymore. Choosing any other real GPIO works as expected.
Do you have an idea what I am doing wrong here?
Thank you!
Could not select "None" as GPIO in switch device
Re: Could not select "None" as GPIO in switch device
Did you tried deleting the device?
Even if deleting the device may solve the issue, it is clearly a bug that needs to be addressed.
"Reset and try again" is not really compatible with "Easy" we try to express here
It is a confirmed bug and it may have affected all settings where plugin pins were updated and set to "no pin".
It will be fixed in the next build.
Yes, that works. At least as long I don‘t change the Pin. However, I will wait for the next build...
Thanks for your support
Users browsing this forum: Ahrefs [Bot] and 31 guests
