I have Ventus W155 Weather station (http://www.nshnordic.com/en/products/ve ... anemometer). Stations wind measurement unit is recognized by Rflink and the temperature and humidity data seems ok. But wind speed and direction data isn't valid (at least when viewed in domoticz). Wind direction seems to be 180 degrees of the target and wind speeds show up much slower than in weather station.
Could you check if rflink recognizes or passes sensor data some how incorrectly.
Thanks for the great project and nice that you have launched support forum
Here's debug log:
20;31;DEBUG;Pulses=26;Pulses(uSec)=450,3900,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,2670;
20;32;DEBUG;Pulses=40;Pulses(uSec)=450,1920,390,3900,360,1920,390,1920,390,1920,360,3900,390,1920,360,3900,390,1920,390,1920,390,1920,390,1920,390,3900,390,1920,390,1920,390,3900,390,3900,360,1920,390,1920,390,1800;
20;33;DEBUG;Pulses=74;Pulses(uSec)=450,1920,390,3900,390,1920,390,1920,390,1920,360,3900,390,1920,390,3900,390,1920,390,1920,360,1920,390,1920,390,3900,360,1920,390,1920,360,3900,390,3900,390,1920,390,1920,390,1920,360,1920,390,1920,360,1920,360,1920,390,1920,360,1920,390,3900,360,1920,390,1920,390,1920,360,1920,390,3900,360,3900,390,1920,390,3900,360,3900,390,6990;
20;34;Alecto V1;ID=02a0;TEMP=0019;HUM=84;BAT=OK;
20;35;DEBUG;Pulses=30;Pulses(uSec)=450,1920,390,3900,390,1920,360,3900,390,1920,360,3900,360,3900,390,1920,360,3900,390,1920,390,1920,360,1920,390,1920,360,1920,390,1290;
20;36;DEBUG;Pulses=34;Pulses(uSec)=450,1920,360,3900,390,1920,360,1920,390,1920,390,3900,390,1920,390,3900,360,1920,390,3900,390,3900,360,1920,390,3900,360,3900,360,3900,390,3900,390,1800;
20;37;DEBUG;Pulses=26;Pulses(uSec)=420,1800,360,1800,360,1800,360,1860,360,1920,390,1920,390,1920,360,1920,390,3900,360,3900,390,3900,390,1920,360,6990;
20;38;DEBUG;Pulses=74;Pulses(uSec)=450,1920,390,3900,390,1920,360,1920,390,1920,360,3900,360,1920,390,3900,360,1920,390,3900,360,3900,360,1920,390,3900,360,1920,390,1920,360,1920,360,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,360,3900,360,3900,390,6990;
20;39;Alecto V1;ID=02a0;WINSP=0000;BAT=OK;
20;3A;DEBUG;Pulses=74;Pulses(uSec)=450,1920,360,3900,390,1920,360,1920,390,1920,360,3900,360,1920,390,3900,360,1920,390,3900,390,3900,360,1920,390,3900,360,1920,390,1920,360,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,1920,390,1920,390,1920,360,3900,360,3900,390,6990;
20;3B;DEBUG;Pulses=40;Pulses(uSec)=420,1800,360,3720,390,3900,390,1920,360,3900,390,3900,360,3900,360,3900,390,1920,360,1920,390,1920,360,1920,360,3900,390,3900,360,3900,390,1920,390,1920,360,1920,390,1920,360,690;
20;3C;DEBUG;Pulses=66;Pulses(uSec)=450,1920,360,3900,360,1920,390,1920,360,1920,390,3900,360,1920,390,3900,390,1920,360,3900,390,3900,390,1920,360,3900,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1110;
20;3D;DEBUG;Pulses=46;Pulses(uSec)=450,3900,360,3900,360,1920,390,1920,360,1920,390,1920,360,3900,360,3920;40;DEBUG;Pulses=36;Pulses(uSec)=450,1920,360,3900,390,1920,390,1920,390,1920,390,3900,360,1920,390,3900,390,1920,360,3900,390,3900,390,1920,360,3900,390,1920,360,1920,390,1920,360,1920,390,1470;
20;41;DEBUG;Pulses=74;Pulses(uSec)=450,1920,390,3900,390,1920,360,1920,390,1920,360,3900,390,1920,360,3900,390,1920,390,3900,360,3900,390,1920,390,3900,360,3900,390,3900,360,3900,360,1920,390,1920,390,1920,390,1920,360,3900,360,3900,390,3900,390,1920,390,1920,360,1920,360,1920,390,1920,390,1920,390,1920,390,1920,390,1920,390,3900,360,3900,390,3900,390,1920,390,6990;
20;42;Alecto V1;ID=02a0;WINDIR=0005;WINGS=0000;BAT=OK;
20;43;DEBUG;Pulses=56;Pulses(uSec)=450,3900,360,3900,390,1920,360,3900,390,3900,390,3900,360,3900,390,1920,360,1920,390,1920,390,1920,360,3900,390,3900,360,3900,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,360,1920,390,1920,360,3900,390,3900,390,3900,360,1920,360,6990;
20;44;DEBUG;Pulses=26;Pulses(uSec)=450,1920,390,3900,360,1920,390,1920,390,1920,360,1920,390,3900,360,1920,390,1920,360,3900,360,3900,390,1920,360,1740;
20;45;DEBUG;Pulses=42;Pulses(uSec)=450,3900,390,1920,390,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,360,3900,390,1920,390,1920,390,1920,390,1920,390,3900,390,3900,360,1920,390,3900,390,3900,390,6990;
20;46;DEBUG;Pulses=32;Pulses(uSec)=450,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,1920,360,3900,390,1920,390,1920,390,1920,390,1920,360,3900,390,3900,390,1920,360,2670;
20;47;DEBUG;Pulses=28;Pulses(uSec)=420,1800,360,1800,360,1800,360,3870,390,1920,360,3900,390,1920,390,1920,360,1920,390,1920,360,3900,390,1920,390,1920,360,2580;
20;48;DEBUG;Pulses=30;Pulses(uSec)=420,1800,360,1830,360,1830,360,1830,390,3900,360,1920,390,1920,360,1920,390,1920,390,3900,360,3900,390,1920,390,3900,390,3900,390,6990;
20;49;DEBUG;Pulses=30;Pulses(uSec)=420,1800,360,3690,360,1860,390,1920,360,1920,390,1920,390,3900,390,1920,390,1920,390,3900,39020;4B;DEBUG;Pulses=74;Pulses(uSec)=450,1920,360,3900,390,1920,390,1920,390,1920,390,3900,360,1920,390,3900,390,1920,360,3900,390,3900,390,1920,390,3900,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,3900,360,3900,390,6990;
20;4C;Alecto V1;ID=02a0;WINSP=0000;BAT=OK;
20;4D;DEBUG;Pulses=32;Pulses(uSec)=450,1920,390,1920,360,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,3900,360,3900,390,6990;
20;4E;DEBUG;Pulses=26;Pulses(uSec)=450,1890,390,3900,360,1920,390,1920,360,1920,390,3900,390,1920,360,3900,390,1920,360,3900,390,3900,390,1920,360,3720;
20;4F;DEBUG;Pulses=30;Pulses(uSec)=450,3900,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,390,3900,390,3900,360,3900,390,1920,390,240;
20;50;DEBUG;Pulses=52;Pulses(uSec)=450,1920,360,3900,360,3900,390,1920,360,3900,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,870;
20;51;DEBUG;Pulses=36;Pulses(uSec)=450,1920,360,3900,390,1920,360,1920,390,1920,360,3900,360,1920,390,3900,390,1920,390,3900,390,3900,360,1920,390,3900,360,3900,390,3900,390,3900,360,1920,390,300;
20;52;DEBUG;Pulses=24;Pulses(uSec)=420,1830,360,1800,360,1800,360,1860,390,1920,390,1920,360,1920,390,3900,390,3900,390,3900,390,1920,390,6990;
20;53;DEBUG;Pulses=74;Pulses(uSec)=420,1920,390,3900,390,1920,360,1920,390,1920,360,3900,390,1920,390,3900,360,1920,390,3900,360,3900,360,1920,390,3900,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,360,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,360,3900,390,3900,390,6990;
20;54;DEBUG;Pulses=24;Pulses(uSec)=450,1920;57;DEBUG;Pulses=50;Pulses(uSec)=450,1920,390,3900,390,1920,390,1920,390,1920,360,3900,390,1920,360,3900,390,1920,390,3900,360,3900,390,1920,390,3900,360,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,360;
20;58;DEBUG;Pulses=30;Pulses(uSec)=450,1920,390,1920,360,1920,390,1920,360,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,3900,360,2790;
20;59;DEBUG;Pulses=26;Pulses(uSec)=450,1920,360,1920,390,1920,390,1920,390,1920,360,1920,360,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1770;
20;5A;DEBUG;Pulses=60;Pulses(uSec)=450,3900,390,1920,360,3900,390,1920,360,3900,360,3900,390,1920,360,3900,390,3900,390,3900,390,3900,390,1920,360,1920,390,1920,390,1920,360,3900,390,3900,360,3900,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,3900,390,3900,390,2520;
20;5B;DEBUG;Pulses=32;Pulses(uSec)=450,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,3510;
20;5C;DEBUG;Pulses=62;Pulses(uSec)=450,1920,390,3900,360,1920,390,3900,390,3900,360,1920,390,3900,360,3900,390,3900,390,3900,390,1920,390,1920,360,1920,390,1920,390,3900,390,3900,390,3900,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,3900,360,3900,390,3900,390,1920,360,6990;
20;5D;DEBUG;Pulses=32;Pulses(uSec)=450,1920,360,1920,360,1920,390,20;5E;DEBUG;Pulses=28;Pulses(uSec)=450,1920,360,3900,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,90;
20;5F;DEBUG;Pulses=32;Pulses(uSec)=450,1920,390,1920,360,1920,390,1920,360,3900,390,3900,390,3900,360,1920,390,1920,360,1920,390,1920,360,1920,360,1920,390,1920,360,1920,390,1800;
20;60;DEBUG;Pulses=58;Pulses(uSec)=450,1920,390,3900,360,3900,390,1920,360,3900,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,3900,390,3900,360,6990;
20;61;DEBUG;Pulses=30;Pulses(uSec)=450,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,360;
20;62;DEBUG;Pulses=50;Pulses(uSec)=450,3900,390,1920,360,1920,390,3900,390,3900,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,3900,360,1920,390,1920,360,1920,390,1920,360,3900,390,3900,390,1920,390,3900,390,3930,360,6990;
20;63;DEBUG;Pulses=30;Pulses(uSec)=450,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,3900,390,1920,360,1920,390,1920,360,1920,390,3240;
20;64;DEBUG;Pulses=28;Pulses(uSec)=420,1830,360,3870,390,1920,390,1920,360,1920,390,3900,360,1920,390,3900,390,1920,360,1920,390,1920,360,1920,390,3900,390,1200;
20;65;DEBUG;Pulses=30;Pulses(uSec)=420,1800,360,1890,390,1920,390,1920,360,3900,390,1920,360,1920,390,1920,390,1920,360,3900,390,3900,360,1920,390,3900,390,3900,360,4170;
20;66;DEBUG;Pulses=30;Pulses(uSec)=450,1920,390,1920,360,1920,390,1920,360,3900,390,1920,390,1920,360,1920,390,1920,360,3900,390,3900,390,1920,360,3900,390,3900,360,5490;
20;67;DEBUG;Pulses=38;Pulses(uSec)=450,1920,390,1920,360,1920,390,1920,360,1920,39020;68;DEBUG;Pulses=70;Pulses(uSec)=450,1920,360,1920,390,1920,360,3900,390,1920,360,3900,360,1920,390,3900,360,3900,390,1920,390,3900,390,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,3900,390,3900,390,3030;
20;69;DEBUG;Pulses=30;Pulses(uSec)=450,1920,360,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,3900,360,3900,390,6990;
20;6A;DEBUG;Pulses=46;Pulses(uSec)=450,1920,390,3900,360,1920,390,1920,360,1920,360,3900,390,1920,360,3900,390,1920,360,3900,360,3900,390,1920,360,3900,390,3900,390,3900,360,3900,390,1920,360,1920,360,1920,390,1920,360,3900,390,3900,390,990;
20;6B;DEBUG;Pulses=74;Pulses(uSec)=450,1920,390,3900,360,1920,390,1920,360,1920,390,3900,390,1920,390,3900,390,1920,360,3900,390,3900,390,1920,360,3840,450,1920,360,1920,360,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,19
Ventus W155 Weather station wind measurement broblem
Re: Ventus W155 Weather station wind measurement broblem
We will check your data and have several fixes waiting already.
Thanks for quick reply. I noticed that log data doesn't contain any windspeed data because there were no wind present at the time I was generating log.
I'll try to attach log containing some windspeed data when I get back to home.
Here's some extra log data. The wind sensor was pointing approximately to south and weather station showed 5.6 gust windspeed. Hope this helps...
20;03;DEBUG;Pulses=30;Pulses(uSec)=450,1920,390,3900,360,1920,360,1920,390,1920,360,3900,390,1920,390,3900,360,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,2400;
20;04;DEBUG;Pulses=24;Pulses(uSec)=450,3900,390,3900,360,1920,390,1920,390,1920,390,1920,390,3900,390,3900,390,3900,390,3900,390,3900,390,6990;
20;05;DEBUG;Pulses=24;Pulses(uSec)=450,1920,360,3900,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,3900,390,1920,390,3900,360,1620;
20;06;DEBUG;Pulses=34;Pulses(uSec)=450,1920,360,3900,390,1920,390,3900,360,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,3900,360,1920,390,3900,390,1920,360,1920,390,1920,390,1680;
20;07;DEBUG;Pulses=26;Pulses(uSec)=450,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,3900,390,3900,390,3900,360,1920,390,1920,360,1920,390,1380;
20;08;DEBUG;Pulses=32;Pulses(uSec)=450,1920,390,3900,390,1920,390,1920,390,1920,360,3900,390,1920,390,3900,390,1920,390,3900,390,3900,390,1920,360,3900,390,1920,390,1920,360,840;
20;09;DEBUG;Pulses=74;Pulses(uSec)=450,1920,360,3900,390,1920,390,1920,360,1920,390,3900,390,1920,360,3900,390,1920,390,3900,390,3900,360,1920,390,3900,390,3900,360,3900,390,3900,390,1920,360,3900,390,3900,360,1920,390,3900,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,390,3900,390,3900,360,3900,390,1920,360,6990;
20;0A;Alecto V1;ID=02a0;WINDIR=0001;WINGS=0000;BAT=OK;
20;0B;DEBUG;Pulses=43;Pulses(uSec)=450,3900,360,1920,360,3900,390,1920,360,3900,360,3900,390,1920,360,3900,390,3900,360,3900,390,3900,390,1920,360,3900,390,3900,390,1920,360,3900,390,1920,360,1920,390,1920,390,1920,360,1920,390;
20;0C;DEBUG;Pulses=74;Pulses(uSec)=450,1920,390,3900,390,1920,390,1920,390,1920,390,3900,390,1920,390,3900,360,1920,390,3900,360,3900,390,1920,390,3900,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,1920,360,3900,390,3900,390,6990;
20;0D;Alecto V1;ID=02a0;WINSP=0000;BAT=OK;
20;0E;DEBUG;Pulses=50;Pulses(uSec)=450,1920,390,3900,390,1920,390,1920,390,1920,390,3900,360,1920,390,3900,390,1920,390,3900,390,3900,360,1920,390,3900,390,1920,390,1920,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1440;
20;0F;DEBUG;Pulses=74;Pulses(uSec)=450,1920,390,3900,360,1920,390,1920,390,1920,390,3900,390,1920,360,3900,390,1920,390,3900,360,3900,390,1920,390,3900,360,3900,390,3900,360,3900,390,1920,390,3900,360,3900,390,1920,360,3900,360,1920,390,1920,390,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,3900,390,3900,390,39020;11;DEBUG;Pulses=24;Pulses(uSec)=450,1920,360,3900,390,1920,390,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,1920,390,3900,360,270;
20;12;DEBUG;Pulses=50;Pulses(uSec)=450,3900,390,1920,360,1920,390,1920,390,1920,390,3900,390,1920,360,3900,390,1920,390,3900,360,1920,390,1920,360,1920,390,1920,390,1920,390,1920,390,1920,360,1920,390,3900,360,3900,360,1920,390,1920,360,1920,390,1920,360,2220;
20;13;DEBUG;Pulses=36;Pulses(uSec)=450,1920,390,3900,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,1920,390,3900,390,3900,360,1920,360,1920,390,1920,360,1920,390,3900,360,3090;
20;14;DEBUG;Pulses=48;Pulses(uSec)=450,1920,360,1920,390,1920,360,1920,390,3900,390,1920,390,3900,390,1920,360,3900,390,1920,390,1920,360,1920,390,1920,360,1920,390,1920,360,1920,390,1920,390,3900,360,3900,390,1920,360,1920,390,1920,390,1920,360,2910;
20;15;DEBUG;Pulses=66;Pulses(uSec)=450,1800,360,3900,390,1920,360,3900,390,1920,390,1920,390,1920,390,1920,360,3900,390,1920,360,3900,360,1920,390,3900,360,1920,390,120;17;DEBUG;Pulses=40;Pulses(uSec)=450,1920,390,3900,390,1920,390,1920,360,1920,390,3900,390,1920,360,3900,390,1920,360,3900,390,3900,390,1920,360,3900,390,1920,360,1920,390,1920,390,1920,360,1920,390,1920,360,1410;
20;18;DEBUG;Pulses=36;Pulses(uSec)=450,1920,360,3900,390,1920,360,1920,390,1920,390,3900,360,1920,390,3900,360,1920,390,3900,390,3900,360,1920,390,3900,360,3900,360,3900,390,3900,390,1920,390,2460;
20;19;DEBUG;Pulses=24;Pulses(uSec)=450,1920,360,3900,390,1920,360,1920,390,1920,390,3900,360,1920,390,3900,390,1920,390,3900,390,3900,360,450;
20;1A;DEBUG;Pulses=40;Pulses(uSec)=420,1800,360,1800,360,1800,360,1890,360,1920,390,1920,390,1920,390,3900,360,3900,360,3900,390,1920,360,1920,390,1920,390,1920,390,1920,390,3900,360,1920,390,3900,360,1920,390,6990;
20;1B;DEBUG;Pulses=48;Pulses(uSec)=450,3900,360,3900,390,3900,390,3900,360,1920,390,3900,360,3900,390,1920,360,3900,390,1920,390,1920,360,1920,390,1920,360,1920,390,3900,390,3900,390,3900,390,1920,360,1920,360,1920,390,1920,390,3900,390,1920,390,3
