Hi All - I'm having a strange issue with RFLink and two identical roller blinds.
RFLink identifies both BrelMotors with an ID of 494395 and a switch of 31 and 32.
The issue I have is I can send a command to 31 and it works but when I send it to 32 that roller blind does not work.
Has anyone had this issue and solved it? The output from RFLink loader is below.
Thanks in advance for any help.
Rick
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
10;version;
20;01;VER=1.1;REV=48;BUILD=04;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
20;03;BrelMotor;ID=494395;SWITCH=31;CMD=DOWN;
20;04;BrelMotor;ID=494395;SWITCH=31;CMD=STOP;
20;05;BrelMotor;ID=494395;SWITCH=32;CMD=DOWN;
20;06;BrelMotor;ID=494395;SWITCH=32;CMD=STOP;
10;BrelMotor;494395;31;DOWN;
20;07;OK;
20;08;BrelMotor;ID=494395;SWITCH=31;CMD=STOP;
10;BrelMotor;494395;32;DOWN;
20;09;OK;
Issue with multiple BrelMotors
Re: Issue with multiple BrelMotors
Make a debug log as described on the rflink homepage to get this sorted out.
Thanks for the reply Stuntteam.
Below is the output of the same commands with debug on:
Please let me know if I can provide anything else.
Kind regards
Rick
10;version;
10;status;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;04;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,270,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,300,240,630,240,630,240,630,240,630,600,300,600,300,600,300,240,630,240,630,600,270,240,630,600,270,240,630,600,330,240,630,240,630,600,300,600,300,240,630,240,630,240,660,600,330,240,630,240,630,600,270,600,270,240,630,240,630,600,300,600,330,4710,1440,240,630,600,300,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,300,240,630,240,630,600,300,240,630,600,300,240,630,600,330,240,660,240,630,600,300,600,300,240,630,240,630,240,630,600,300,240,630,240,630,600,270,600,300,240,630,240,630,600,300,600,330,4680,1440,240,660,600,300,240,660,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,300,600,330,600,300,240,630,240,660,600,300,240,630,600,300,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,240,630,600,330,240,630,240,630,600,300,600,300,240,660,240,660,600,300,600,6990;
20;05;BrelMotor;ID=494395;SWITCH=31;CMD=DOWN;
20;06;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,300,240,630,240,630,600,300,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,300,600,300,600,300,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,600,300,240,630,600,330,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,300,600,330,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,300,600,300,240,630,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,600,270,240,630,600,330,4710,1440,240,630,600,300,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,240,630,600,300,600,300,240,630,240,630,240,630,600,300,240,630,600,270,240,630,600,270,240,630,600,300,240,630,600,6990;
20;07;BrelMotor;ID=494395;SWITCH=31;CMD=STOP;
20;08;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,300,600,330,600,300,240,630,240,630,600,300,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,300,240,630,240,630,600,300,240,660,240,630,240,630,600,300,600,300,240,630,240,630,600,300,600,330,4710,1440,240,630,600,270,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,300,240,630,240,630,240,630,240,660,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,300,240,630,600,330,240,630,240,630,600,300,600,300,240,630,240,630,600,300,240,660,240,660,240,630,600,270,600,270,240,630,240,630,600,270,600,330,4680,1440,240,630,600,300,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,300,240,630,240,630,240,630,240,630,600,270,600,300,600,300,240,630,240,630,600,300,240,630,600,300,240,660,600,330,240,630,240,630,600,300,600,270,240,630,240,630,600,270,240,660,240,630,240,630,600,300,600,270,240,630,240,630,600,300,600,6990;
20;09;BrelMotor;ID=494395;SWITCH=32;CMD=DOWN;
20;0A;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,300,240,630,240,630,600,300,240,630,600,300,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,600,300,240,660,240,630,600,300,240,630,600,300,240,630,600,270,240,630,600,330,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,300,240,630,240,630,240,630,240,630,600,270,600,330,600,300,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,300,240,630,240,630,600,300,240,660,240,630,600,270,240,630,600,300,240,630,600,270,240,630,600,300,4710,1440,240,630,600,300,240,630,240,630,600,300,240,630,240,630,600,330,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,300,240,630,600,270,240,630,600,330,240,630,240,630,600,300,600,300,240,630,240,630,600,270,240,660,240,630,600,270,240,630,600,270,240,630,600,300,240,630,600,6990;
20;0B;BrelMotor;ID=494395;SWITCH=32;CMD=STOP;
10;BrelMotor;494395;31;DOWN; (This Works)
20;0C;OK;
20;0D;DEBUG;Pulses=246;Pulses(uSec)=4770,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,270,630,240,630,240,630,600,300,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,330,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,270,630,240,630,600,270,600,270,240,630,240,630,240,630,600,300,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,300,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,270,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,240,630,600,300,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,6990;
20;0E;BrelMotor;ID=494395;SWITCH=31;CMD=STOP;
10;BrelMotor;494395;32;DOWN; (This dosn't work)
20;0F;OK;
20;10;DEBUG;Pulses=246;Pulses(uSec)=4770,1410,240,630,600,270,240,630,270,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,600,270,240,660,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,300,4710,1410,240,630,600,270,270,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,600,270,240,660,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,330,4710,1440,240,630,600,270,240,630,240,630,600,270,240,630,240,630,600,300,240,630,600,270,240,630,240,630,240,630,240,630,600,270,600,300,600,270,240,630,240,630,600,270,240,630,600,270,240,630,600,300,240,630,240,630,600,270,600,270,240,630,240,630,600,270,240,660,240,630,600,270,240,630,600,270,240,630,600,270,240,630,600,6990;
20;11;BrelMotor;ID=494395;SWITCH=32;CMD=STOP;
Kind regards
Rick
10;version;
10;status;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;0C;OK;
20;0F;OK;
