I have couple of MEEK switches. Switch work perfect. Also the touch task is working (switch input - switch gpio-12)
I have add this one in Home Asssistant:
switch:
- platform: mqtt
command_topic: "homeassistant/MeekBathroom/Touch/Button/cmd"
state_topic: "homeassistant/MeekBathroom/Touch/Button"
payload_on: "1"
payload_off: "0"
state_on: "1"
state_off: "0"
Generic - Dummy Device with a value: Touch:
This will be turned on and off by a TaskValue in Rule.
What can I do to create a device that is able to be turned on and off by TaskValue in a Rule. but Also can be add to a "Sensor to Controller" and send directly his state change like the Touch button above? I only see all time interval with 60 sec, but and when I change this to 1, every second there will be a state send.
