MQTT Publishing by boot
Posted: 10 May 2019, 14:55
by pw444
Hia,
I'm trying to publish the state of the device, as
On System#Boot do
let,1,0
// gpio 2 -> relay state high = relay off
GPIO,2,1
Publish,%sysname%/status,Light Off
on pb01#value do
gpiotoggle,2
if [VAR#1]=0
let,1,1 // state on
Publish,%sysname%/status,Light On
let,1,0 // state off
on pb01on do
GPIO,2,0
let,1,1
on pb01off do
GPIO,2,1
let,1,0
on pb01sw do
gpiotoggle,2
if [VAR#1]=0
let,1,1 // state on
but by mqtt-explorer, the publish of on system#boot is not presented, showing:
192.168.1.6 > > Lamp-0101> status LWT = Connected
By Controller, i have:
openhab mqtt
ip: 192.168.1.6
Controller Subscribe: /%sysname%/#
Controller Publish: /%sysname%/%tskname%/%valname%
enabled: yes
But none of those is published either.
Any hint?
THX in advance
Re: MQTT Publishing by boot
Posted: 10 May 2019, 15:22
by grovkillen
At boot the connection to your network is not ready. Use the event
MQTT#Connected instead.
https://espeasy.readthedocs.io/en/lates ... vents.html
Posted: 10 May 2019, 15:45
by pw444
Thank you.
By MQTT#Connected will it perforn once after boot or every time when connecting, i.e, a netorwork disconnection, but no reboot and change of state?
And regarding controllers:
openhab mqtt
ip: 192.168.1.6
enabled: yes
Thx!
Posted: 10 May 2019, 16:45
by grovkillen
Yeah that is correct. But then you should add a timer at boot and when that one trigger publish.
Posted: 10 May 2019, 23:45
by pw444
Thx!
i did the following:
// pb01 - gpio 0 - D5
// output - gpio 2 - D3
// boots off
On System#Boot do
let,1,0
GPIO,2,1
on MQTT#Connected do
event,publishstatus
on pb01#onoff do
gpiotoggle,2
if [VAR#1]=0
let,1,1 // state on
event,publishstatus
event,publishstatus
on pb01on do
GPIO,2,0
let,1,1
event,publishstatus
on pb01off do
GPIO,2,1
let,1,0
event,publishstatus
on pb01sw do
gpiotoggle,2
if [VAR#1]=0
let,1,1 // state on
event,publishstatus
event,publishstatus
On publishstatus do
Publish,%sysname%/pb01/onoff,%v1%
so, by network reconnection, i have the actual state and by reboot, the default state, it's working fine.
by mqtt-explorer, all ok, except that the var is showed as:
onoff = 0.00
Is there a way to cut the decimals, so i have onoff = 0, instead of onoff = 0.00?
TIA
Posted: 11 May 2019, 10:10
by grovkillen
You can try the
[VAR#1] syntax since the %v1% will convert the float value to a string. If that still add the decimals you could do it like this:
On publishstatus do
If [VAR#1]=1
Publish,%sysname%/pb01/onoff,1
Else
Publish,%sysname%/pb01/onoff,0
Endif
Posted: 11 May 2019, 18:31
by pw444
Ok, [VAR#1] also ouputs 1.00 or 0.00, so accepted your suggesttion
![Knipoog ;-)](./images/smilies/icon_e_wink.gif)
Thx a lot.
BTW, by Controller, i have:
openhab mqtt
ip: 192.168.1.6
enabled: yes
Why does my mqtt server does not sows the %sysname% by subscription?
and what is the controller publish is for?
TIA
Posted: 11 May 2019, 19:18
by grovkillen
That's the syntax used by the task devices when the "send to controller is checked". And please remember that the first / is also part of the topic. But it's considered bad practice to use a leading front slash.
Posted: 14 May 2019, 16:47
by pw444
thx!
just one stupid question.
using my browser, i can control it with i.e.
http://192.168.1.5/control?cmd=event,pb01sw
how could you do the same using the mqtt broker (mosquito)?
TIA
Posted: 14 May 2019, 17:06
by grovkillen
You post to the topic of your device and add the extra level "CMD" and send the command as the payload. Please read the docs:
https://espeasy.readthedocs.io/en/lates ... mmand.html
Posted: 14 May 2019, 19:12
by pw444
Yes, i did read it, but could not find how, that's why i asked for an example based on the rules, so i can figure out.
MQTT <MQTT subscribe template>/cmd with payload: <command>
i was able so far to figure out:
mosquitto_pub -h 192.168.1.6 -t "/Lamp-0101/gpio/2" -m "1"
what i'm asking is how to use the:
on pb01#onoff
on pb01on do
on pb01off do
on pb01sw do
i'm not finding out how...
Posted: 14 May 2019, 19:35
by grovkillen
The command would then be
Event,pb01#onoff
mosquitto_pub -h 192.168.1.6 -t "/Lamp-0101/cmd" -m "Event,pb01#onoff"
Posted: 14 May 2019, 19:40
by pw444
thx!!!
Posted: 15 May 2019, 21:20
by waspie
grovkillen wrote: ↑14 May 2019, 19:35
Event,pb01#onoff
i don't have to do this by mqtt import plugin?
Posted: 15 May 2019, 21:31
by grovkillen
No, the MQTT import it's only used to import float values (numbers). You can of course use values to trigger rules but that is not necessary in this case.
