[moved, closed] Robotdyn ATmega2560+ESP8266 - no serial in ESP-Easy
Posted: 25 Jan 2019, 23:55
I really hope that someone can help me out.
I have the current version of ESP-Easy (alread tried older versions) and the current version of RF-Link on a Robotdyn ATmega2560+ESP8266. I can connect to the serial port of both devices and I get a valid output on both devices. On the Arduino part I see the initialization of RF-Link and when I trigger a (i.e. IT, Kaku) device I see the correct output. But unfortunately I can not get to work the link between the Arduino and the ESP.
I tried the following dip-switch combination:
I created a device in ESP-Easy with ‘Communication - Serial Server’ and
When I connect to 5333 I can not see output. Further I tried to forward it to a mqtt-server with the following rule:
Nothing is forwareded to the mqtt server - I can not see anything in the log
Does someone has an idea?
Thanks in advance,
dmq
Connection DIP
1 2 3 4 5 6 7
ATmega2560<->ESP8266 ON ON OFF OFF OFF OFF OFF
USB <-> ATmega2560<-> ESP8266 ON ON ON ON OFF OFF OFF To RXD3/TXD3
a. Name: RFLINK
b. Enabled: checked
c. TCP Port: 5333
d. Baud Rate: 57600
e. Data bits: 8
f. Parity: No Parity
g. Stop bits: 1
h. Reset target after boot: - none –
i. RX receive timeout: 0
j. Event processing: RFLINK
On !RFLink#* do
Publish test,%eventvalue%
Thanks in advance,
dmq
