Raintight model RC0-17
Posted: 20 Jan 2019, 17:06
I have a new electric plugs with a 3 buttons remote that seem to be 318Mhz. I am able to see the signals in debug mode and tried to learn the commands using the rffind order. Unfortunately it does not work.
Do you think it"s possible to add them in firmware. They are from Raintight model RC0-17. This is the debug output:
Thanks a lot for you help
ON-1
Pulses=220;Pulses(uSec)=150,60,600,60,120,90,150,30,180,90,150,90,150,60,180,60,150,60,150,90,120,90,120,90,120,90,120,90,150,60,150,90,120
,120,120,90,120,90,150,90,120,90,120,90,120,120,150,60,180,60,120,90,150,90,120,90,120,90,120,120,120,90,150,90,90,120,150,90,120,90,120,120,120,120,15
0,90,120,120,90,120,120,90,120,120,120,90,120,120,120,120,120,4200,120,540,540,120,540,120,120,540,540,120,120,540,120,510,90,540,540,120,120,510,120,5
40,120,540,510,120,510,120,120,540,120,4650,90,540,510,120,510,120,120,540,510,120,120,540,120,540,120,540,510,120,120,540,120,540,120,540,510,120,510,
120,90,540,120,4650,120,540,510,150,510,120,90,540,510,150,90,540,90,540,90,540,510,150,90,540,90,540,90,570,510,150,510,150,90,570,90,4680,120,540,510
,150,510,120,120,540,510,150,90,540,120,540,90,570,510,150,90,570,90,570,90,570,510,150,510,150,90,540,90,6990;
OFF-1
Pulses=208;Pulses(uSec)=210,90,150,90,120,90,180,60,150,90,150,60,120,90,120,90,120,90,120,90,150,90,120,120,120,90,120,120,120,90,120,90,1
20,120,120,90,150,90,120,90,120,120,120,90,120,90,120,90,120,120,150,60,120,120,120,120,120,120,150,60,120,120,150,90,120,120,120,90,120,90,120,90,120,
120,120,120,90,120,120,4230,120,540,540,120,540,120,120,510,540,120,120,540,90,540,120,540,120,540,510,120,120,540,120,540,510,120,510,120,120,540,90,4
650,120,540,540,120,510,150,120,540,540,120,120,540,90,540,90,540,90,540,510,150,90,540,120,510,510,120,510,150,90,540,90,4650,90,540,540,120,510,150,9
0,540,510,120,90,540,90,540,90,570,90,570,510,150,90,540,90,540,510,120,510,150,90,570,90,4650,90,540,510,150,510,120,90,570,510,150,90,540,90,570,90,5
40,90,540,510,150,90,540,90,570,480,150,510,120,90,540,90,6990;
ON-2
Pulses=184;Pulses(uSec)=180,60,150,90,150,90,120,90,180,60,150,90,150,90,120,90,120,120,150,90,210,30,120,90,150,90,120,90,120,90,120,90,12
0,120,120,90,120,120,120,120,120,120,120,120,120,90,120,90,120,120,120,90,180,60,90,4230,120,540,540,120,540,120,120,540,540,90,120,540,120,540,120,540
,120,540,120,540,540,90,120,540,540,120,510,120,120,510,90,4680,120,540,510,120,510,120,120,540,510,120,90,540,90,540,90,540,120,540,120,570,510,120,90
,540,510,120,510,150,90,540,120,4650,90,570,510,120,510,150,90,540,510,120,120,540,90,540,90,540,90,570,90,540,510,120,120,540,510,120,510,120,90,570,9
0,4680,90,540,510,120,510,120,90,570,510,150,90,570,90,540,90,540,90,540,90,570,510,150,90,540,510,150,510,120,90,540,90,6990;
OFF-2
20;4E;DEBUG;Pulses=222;Pulses(uSec)=30,1080,180,90,150,60,120,90,180,30,150,60,150,60,150,90,150,90,150,60,150,90,150,60,120,90,150,90,120,90,150,90,12
0,90,150,90,150,90,120,90,570,60,120,90,150,60,120,90,120,90,120,120,120,90,120,90,120,120,120,120,120,90,120,120,120,90,120,90,120,90,120,90,120,120,1
20,90,120,120,120,120,120,90,120,120,120,120,120,90,120,90,120,120,120,4230,90,540,540,120,540,120,120,510,540,120,120,540,90,540,120,540,90,540,90,540
,120,540,510,120,540,120,510,120,120,540,120,4650,120,540,510,120,510,150,90,540,510,120,90,540,90,540,120,540,90,540,120,540,90,540,510,120,510,150,51
0,150,120,540,90,4680,90,540,510,120,510,120,90,540,510,150,90,570,90,540,90,570,90,540,90,540,90,570,510,150,510,150,510,150,90,540,90,4680,90,540,510
,150,510,120,90,570,510,150,90,540,90,570,90,540,90,540,90,540,90,540,510,150,510,150,510,150,90,570,90,6990;
ON-3
20;4F;DEBUG;Pulses=214;Pulses(uSec)=120,60,120,90,150,60,180,30,120,90,150,90,150,90,120,90,150,60,120,90,120,90,120,120,120,90,120,90,120,90,120,120,1
20,90,120,120,120,90,150,90,120,90,120,120,120,90,120,90,120,120,120,120,90,120,120,120,120,90,120,90,120,90,120,120,120,120,120,120,120,120,120,120,12
0,120,120,120,120,90,90,120,120,90,120,120,120,4230,150,510,570,90,510,120,120,540,540,120,120,540,90,540,540,120,90,540,120,540,90,540,90,540,540,120,
510,120,120,510,120,4650,120,540,540,120,540,120,120,540,510,120,90,540,90,570,510,150,90,540,120,540,90,540,90,540,510,120,510,150,90,540,90,4680,90,5
70,510,120,510,120,120,540,510,120,90,540,90,540,510,150,90,570,90,540,120,540,90,540,510,150,510,150,90,570,90,4650,120,540,510,120,510,150,90,570,510
,150,90,570,90,570,510,120,90,540,90,540,90,540,90,570,510,150,510,150,90,570,90,6990;
OFF-3
20;50;DEBUG;Pulses=218;Pulses(uSec)=210,60,150,60,150,60,150,90,120,120,180,60,120,90,150,90,150,60,120,90,120,90,120,90,120,90,150,90,120,90,120,90,12
0,120,120,120,120,120,180,30,150,90,120,120,120,90,150,60,120,120,120,120,120,120,90,120,120,120,90,120,120,90,120,120,120,120,90,120,120,120,120,90,12
0,120,120,90,120,120,120,120,120,90,120,120,150,60,150,90,120,4230,120,540,540,120,540,120,120,540,540,120,120,540,510,120,120,540,120,540,120,540,120,
540,90,540,510,120,510,150,90,540,90,4650,120,540,510,120,510,150,120,540,510,120,90,540,510,120,90,540,90,540,90,540,120,540,120,540,510,150,510,150,1
20,540,120,4650,120,540,510,120,510,150,120,540,510,150,120,540,510,120,90,540,90,570,90,540,90,540,90,570,510,120,510,150,90,570,90,4680,90,540,510,12
0,510,150,90,570,510,150,90,570,510,120,120,540,90,570,90,570,90,540,90,540,510,120,510,150,90,570,90,6990;
ON-1
OFF-1
ON-2
OFF-2
ON-3
OFF-3
