Variables for use in rules??
Posted: 09 Jan 2019, 21:19
by bastibasti
I'm trying to do something like this
(its a simple dimmer, a push button increases a variable, and the pwm output is set according to one of the 5 available dimmer levels)
on button#switch do
if [button#switch]=0
$a=$a+1
if $a=5
$a=0
if $a=0
pwm,2,1024,750
if $a=1
pwm,2,1000,750
if $a=2
pwm,2,800,750
if $a=3
pwm,2,500,750
if $a=4
pwm,2,0,750
any idea how to achieve this??
Re: Variables for use in rules??
Posted: 09 Jan 2019, 21:25
by Domosapiens
In rules you can use the command let
let,1,10 this will assign the value 10 to %v1%.
To get the value of %v1%, you can use %v1% or [VAR#1] depending on the rule syntax:
if %v1%=10
or
taskvalueset,1,1,%v1%
or
taskvalueset,1,1,[VAR#1]
Posted: 11 Jan 2019, 01:28
by Jackill
Domosapiens wrote: ↑09 Jan 2019, 21:25
WOW!
Great info! Searched for it resultless..
Where did you find the list of commands to use in rules?
Posted: 11 Jan 2019, 05:35
by grovkillen
I'm doing my best but need to work on my daytime job too. But the commands are found here:
https://espeasy.readthedocs.io/en/lates ... mmand.html
Not all are listed, I will do my best adding them but I don't have the the time just now.
Posted: 11 Jan 2019, 10:06
by Domosapiens
While reading the forum, I collect snippets of Rules as examples in a document.
The (new) "Let" statement one was found here:
viewtopic.php?f=4&t=5961&p=32580&hilit= ... ill#p32580
Posted: 11 Jan 2019, 14:44
by Jackill
grovkillen wrote: ↑11 Jan 2019, 05:35
Shure. This is not even discussed, daytime job on first place.
Nevertheless, system variables can save much.
Face this when I had to do calculations for my solar heating system.
Code like this: "if [Boiler#Temp]<[Solar#Temp]+5 <do smthng> endif" not worked, it need to be passed thru dummy (taskValueSet).
Now I'll save 1 of 12 tasks.
Domosapiens wrote: ↑11 Jan 2019, 10:06
Good practice! I will put into service.
Posted: 14 Jan 2019, 12:11
by bastibasti
any idea how to increment a value?
let 1,%v1%+1??
Posted: 14 Jan 2019, 13:45
by grovkillen
Posted: 08 Feb 2020, 07:40
by EDsteve
Somehow i can't get it working 100% with the Let command.
When soil humidity is higher than 900 it should set varia#2 to 2. And if this var#2 is 2 it should trigger a relay and increment a second variable (The incrementation of the second variable works). But somehow it doesn't enter the "if [var#2]=2 do".
on Soil#Analog do
SendToHTTP,192.168.8.115,8080,/json.htm?param=udevice&type=command&idx=25&nvalue=[Soil#Analog]
if [soil#Analog]>900 do
timerSet,1,2
Let,2,[var#2]=2
On Rules#Timer=1 do
if [var#2]=2 do
GPIO,12,1
Let,1,[var#1]+1
timerSet,2,2
On Rules#Timer=2 do
if [var#1]=3 do
GPIO,12,0
Let,1,[var#1]=0
Let,2,[var#2]=0
GPIO,12,0
timerSet,1,6
I am also not really sure how it all works with the Let command.
What exactly does the number 1 stand for: Let,
1,[VAR#
1]+1
And my Dummy devices don't change it's value. So with the Let command i can have a variable without connected to a Dummy device?
So the Let command has nothing to do with TaskValueSet ?
Sorry for my maybe stupid questions.
Posted: 08 Feb 2020, 09:42
by grovkillen
Your syntax is wrong, see here:
on Soil#Analog do
timerSet,1,2
Let,2,2 //<---- no equal sign.
On Rules#Timer=1 do
if [var#2]=2 do
GPIO,12,1
Let,1,[var#1]+1 //THIS WILL ADD 1 to the variable one i.e. "Let,1,1" would make the var one = 1 and "Let,15,33" would make var fifteen = 33
timerSet,2,2
On Rules#Timer=2 do
if [var#1]=3 do
GPIO,12,0
Let,1,0 //<---- no equal sign.
Let,2,0 //<---- no equal sign.
GPIO,12,0
timerSet,1,6
I guess the most user friendly way would be the syntax "Let,v1=..." but that would make the syntax for Let be completely different from the other commands. So we will keep it using the comma instead of the equal sign for consistency.
Posted: 08 Feb 2020, 09:45
by grovkillen
Let are internal variables, the task values are just that, task values. So they have nothing to do with each other, BUT one can be used to influence the other using formulas and task value set. So if you want to use an internal value for a task value you would need to use a dummy variable and set it by using the TaskValueSet (or TaskValueSetAndRun) to populate it with the number from the internal variable.
Posted: 08 Feb 2020, 10:47
by EDsteve
Ohh. Thanks so much. Now i understand. I should have thought about that
I know... script kiddies like me are annoying.
Posted: 08 Feb 2020, 11:54
by grovkillen
EDsteve wrote: ↑08 Feb 2020, 10:47
Don't say that, I'm a script kid myself.
Posted: 01 Aug 2021, 18:30
by DMike92
I'm a bit confused.
I read :
- Is there any differences between v and var? %v1% represent [var#1]? Or [v#1]?
- Does these variables must exists somehere (Devices, maybe)?
- Is it possible to get the variable value with a http command (control?cmd=???)
Sorry for all these begginer questions
Michel
Posted: 01 Aug 2021, 19:04
by Ath
DMike92 wrote: ↑01 Aug 2021, 18:30
a) There are 3 ways to use a variable set via the 'let,n,value' command: use %vn% where n > 0, so %v1% would be correct, use [var#n], so [var#1] would result in the same output, or use [int#n], with [int#1] resulting in the rounded integer result of the value in that variable you set.
b) These variables are stored in memory only, so putting the device in deepsleep will wipe them out. The currently assigned variables and their values can be viewed on the Tools/System Variables page.
c) No, you can not access them directly, not even by getting the /json output. You could put the values you really need in the max. 4 Values of a Dummy Device task (there can be multiple of these), using a "TaskValueSet,taskname,valuename,[var#1]" command, that
can be retrieved from the json output or sent to a Controller. It is also possible via rules to send the values directly using a "SendToHttp,ip_or_hostname,port,/url/to/send/data?value=[var#1]" command.
Posted: 01 Aug 2021, 20:12
by DMike92
Ath wrote: ↑01 Aug 2021, 19:04
Thank you very much for your answer
c) If I do the "TaskValueSet,taskname,valuename,[var#1]" command," or anything else, is there a way (via Rules or Devices, or... ?) to get the state of this variable with a http command ?
I'm curently issuing a
event,action command, maybe this event can answer the caller with that value ? That would be ideal.
I deal with blinds, so the first this when I open my app (I'm writting the app) is to get the curent status of the blinds (open/close).
Then when I issue a cmd I would like to have this status update and confirmed by the ESP.
Does that makes any sense?
Posted: 01 Aug 2021, 20:23
by Ath
DMike92 wrote: ↑01 Aug 2021, 20:12
Does ESPEasy control the relays for the blinds too? If so, it would probably be more efficient to use the state of the relay (can easily be reflected using a Switch device on that GPIO pin), and you can get the current state from the http://ip_of_espeasy_device/json url (try it in your browser, or use the Tools/Show JSON button), where you get data like this:
(partial, formatted)
"TaskValues": [
"ValueNumber": 1,
"Name": "State",
"NrDecimals": 0,
"Value": 0
"DataAcquisition": [
"Controller": 1,
"IDX": 0,
"Enabled": "false"
"Controller": 2,
"IDX": 0,
"Enabled": "false"
"Controller": 3,
"IDX": 0,
"Enabled": "false"
"TaskInterval": 0,
"Type": "Switch input - Switch",
"TaskName": "Switch",
"TaskDeviceNumber": 1,
"TaskEnabled": "true",
"TaskNumber": 9
Posted: 04 Sep 2021, 12:23
by DMike92
Thanks a lot Ath,
After a second reading, I get everything:)
How can I close this ?
Posted: 04 Sep 2021, 13:00
by Ath
No need to close, you have now mentioned that your question is answered, that's enough.
