ESP Conrol Brinks WTW
Posted: 19 Aug 2018, 13:24
by sincze
As you can see with the amount of posts in this forum I just started using ESPEasy. :D .
I have to admit I've created some nice things already. This time for my neighbour he wanted to control his Renovent HR Medium/Large - Brink Climate Systems.
In his house there is only 1 switch in the Kitchen, so if you want to turn it on in the bathroom... your are out of luck. To have it turn on by iteself if the humidity is to high.. That would be ideal.
I've figured out the solution some time ago using Mysensors. But for him I wanted to create a small and easy solution.
https://forum.mysensors.org/topic/7180/ ... te-systems
This is what I started with:
Basically you need WEMOS D1 mini, combo board and a relais for ESPEasy to make it work.
The relais (if enabled) should 'connect' the wires to switch on WTW Speed 3. If disabled the WTW will run at is default speed of 1.
As it needed to be cheap... You can figure out where the housing came from..
Housing
Housing
Within the rules you need: (So you can control the relais via HTTP)
on wtw_on do
    gpio,5,1
on wtw_off do
    gpio,5,0
The relais can be controlled by:
Can be controlled by:
http://<your_ip_here>/control?cmd=event,wtw_Off
http://<your_ip_here>/control?cmd=event,wtw_On
Keep in mind that GPIO 5 is default connected to SCL within ESPEasy so you might have to free that one up from within menu 'ESPEasy -> Hardware'.
Next stop will be the filter indicator.
I have that working in domoticz. However it will need some additional hardware to make it work with ESPEasy. (If the filter is full it will generate 24v... so you'll have to bring that down to 3,3v as an input for the ESP to read it as a digital 1).
Re: ESP Conrol Brinks WTW
Posted: 13 Jan 2021, 13:52
by ESPHA
Thank you for the inspiration sincze! I have made my own iteration based on yours for a Brink renovent 300/400 excellent, ESP8266 and home assistant integration. I will post some snippets, mainly because the color coding was somewhat confusing as many wires have different colors than yours.
I used an RJ12 cable and splitter so that my Brink RF transmitter can stay in place and also copied your idea for the filter indicator.
The RJ12 pinout is as follows (see p. 28 in the installation guide https://www.brinkclimatesystems.nl/docu ... 054-en.pdf)
Pin 1: 24V (not connected but could theoretically be used as a power supply)
Pin 2: GND
Pin 3: Position 0/sleep mode (not connected in my case
Pin 4: position 2, to enable connect to ground with relay (~13 V to ground)
Pin 5: position 3, to enable connect to ground with relay (~13V to ground)
Pin 6: Filter indicator (gives off 24V to GND when filter needs cleaning/replacement).
Note that:
- the Brink defaults to position 1 and that it is capable of handling two inputs simultaneously as it is made to handle multiple switches (e.g. 2 RF modules). Nevertheless I 'interlocked' both relays in ESPhome.
- I'm not yet sure what's current is drawn if the filter indicator is on. Might need a heat sink for the voltage regulator.
- I connected a 5V microUSB power supply to my ESP8266 in order to supply the necessary 5V to the relays.
My wiring:
In ESPhome I configured it as follows:
switch:
  - platform: gpio
    pin: D7
    interlock: [relay2]
  - platform: gpio
    pin: D8
    interlock: [relay1]
  - platform: template
    turn_on_action:
     - switch.turn_off: relay1
     - switch.turn_off: relay2
     - switch.turn_off: position1
binary_sensor:
  - platform: gpio
    device_class: problem
    pin: D6
    name: "Brink renovent filter indicator"
In home assistant I used this blueprint (https://community.home-assistant.io/t/t ... ine/255999) to automatically switch the fan to position3 based on the bathroom humidity.
Some (messy) pictures are included of the device and HA lovelace view.
Posted: 14 Jan 2021, 22:17
by _Cyber_
here is another solution for brink units:
I have a wemos d1 with a dht22 in bathroom. it measures on 5 minutes basis the humidity and does a GET request to a raspberry.
this raspberry has a ebus connection to the brink unit and sets via ebusd the fan speed of stand 1 dynamically between 50m³/h and the configured maximum os stand 1 on basis of the measured humidity between 50% and 100%.
if someone is interested I can post php code of the relevant parts. :-)
Posted: 15 Jan 2021, 15:37
by ESPHA
_Cyber_ wrote: 14 Jan 2021, 22:17 here is another solution for brink units:
Very interested yes. Also how did you make the ebusd connection? And how have you integrated the system? What were the costs? The RJ12 solution benefits from low cost (~15 eu including ESP module) and easy to connect.
Posted: 20 Jan 2021, 12:05
by _Cyber_
the ebus connection is done in my case with an ebus-usb-adapter. I soldered the one from here: https://www.mikrocontroller.net/topic/3 ... age=single
there are also other projects around how to make your own ebusd adapter, cheaper and direct with wifi, with a wemos D1. e.g. https://ebus.github.io/adapter/index.en.html
on the RPI I have configured ebusd and connected it with the USB adapter. for ebus-configuration, have a look at https://github.com/dstrigl/ebusd-config ... ellent-300
with this you can completely control the brink unit. You can read how long the filter will last, how much m³ Air is flowing, the different temperatures, etc. I wrote a munin plugin to graph this, it looks like this:
the munin script is here:
#!/usr/bin/php
<?php
if ($argc == 2) {
	if ($argv[1] == "config") {
		echo("graph_title Brink Renovent Excellent 300".PHP_EOL);
		echo("graph_vlabel Brink Parameter".PHP_EOL);
		echo("graph_category House".PHP_EOL);
		echo("Ventilatorstufe.label Ventilatorstufe".PHP_EOL);
		echo("Ablufttemperatur.label Ablufttemperatur".PHP_EOL);
		echo("Frischlufttemperatur.label Frischlufttemperatur".PHP_EOL);
		echo("Aussenlufttemperatur.label Aussenlufttemperatur".PHP_EOL);
		echo("TatsaechlicheZuluftmenge.label TatsaechlicheZuluftmenge".PHP_EOL);
		echo("TatsaechlicheAbluftmenge.label TatsaechlicheAbluftmenge".PHP_EOL);
		echo("IstwertZuluftdruck.label IstwertZuluftdruck".PHP_EOL);
		echo("IstwertAbluftdruck.label IstwertAbluftdruck".PHP_EOL);
		echo("FilterStatus.label FilterStatus".PHP_EOL);
		echo("TageMitFilter.label TageMitFilter".PHP_EOL);
		echo("TageMitFilter.draw LINE1".PHP_EOL);
		echo("StatusBypass.label StatusBypass".PHP_EOL);
		echo("StatusVorheizregister.label StatusVorheizregister".PHP_EOL);
		echo("LeistungVorheizregister.label LeistungVorheizregister".PHP_EOL);
		echo("EWTStatus.label EWTStatus".PHP_EOL);
		echo("EWTStatus.cdef EWTStatus,1,+,2,%".PHP_EOL);
		echo("BypassTemperatur.label BypassTemperatur".PHP_EOL);
		echo("BypassHysterese.label BypassHysterese".PHP_EOL);
		echo("EWTTug.label EWTTmin".PHP_EOL);
		echo("EWTTog.label EWTTmax".PHP_EOL);
		echo("LuftmengeStufe1.label LuftmengeStufe1".PHP_EOL);
	exit;
function fetchjsonfromurl($url) {
	$ch = curl_init();
	curl_setopt($ch, CURLOPT_URL, $url);
	curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
	curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, 6);
	curl_setopt($ch, CURLOPT_TIMEOUT, 9);
	$output = curl_exec($ch);
	curl_close($ch);
	return json_decode($output, true);
$fieldzero = array( "Ventilatorstufe", "Ablufttemperatur", "Frischlufttemperatur", "Aussenlufttemperatur", "TatsaechlicheZuluftmenge", "TatsaechlicheAbluftmenge", "IstwertZuluftdruck", "IstwertAbluftdruck", "FilterStatus", "TageMitFilter", "StatusBypass", "StatusVorheizregister", "LeistungVorheizregister", "EWTStatus" );
$fieldaktuell = array( "BypassTemperatur", "BypassHysterese", "EWTTug", "EWTTog", "LuftmengeStufe1" );
$fieldaktuellelements = array( "aktuell", "minimum", "maximum", "Schrittgroesse", "Werkseinstellung");
$kwlvalues = fetchjsonfromurl("http://localhost:8880/data?numeric&required");
foreach ($fieldzero as $key => $value) echo $fieldzero[$key].'.value '.$kwlvalues["kwl"]["messages"][$value]["fields"]["0"]["value"].PHP_EOL;
foreach ($fieldaktuell as $key => $value) echo $fieldaktuell[$key].'.value '.$kwlvalues["kwl"]["messages"][$value]["fields"]["aktuell"]["value"].PHP_EOL;
changing the air volume is then only a matter of sending the desired value by MQTT to the ebus-daemon. it is then setting the m³/h direct on the unit.
this I have simply attached to a php script which is graphing also temperatures and humidity of some rooms with munin:
function publishvalue($prefix, $param, $message) {
		$topic = $prefix.$param;
		$client = new Mosquitto\Client();
		//$client->setCredentials('S1','123456');
		$client->connect("localhost", 1883, 5);
		$client->publish($topic, $message, 1, 0);
		$client->disconnect();
		unset($client);
function evalkwlspeed($humidity) {
	$Ventilatorstufe = 1;
	$humi_max = 90;
	$humi_aim = 50;
	$Aussenlufttemperaturmax = 23;
	$EWTStatus = '';
	$Aussenlufttemperatur = '';
	$Luftmengemin = 50;
	$Luftmengemax = 160;
	$Luftmengestep = 5;
	$Luftmengecurrent = 50;
	$brinkData = fetchjsonfromurl('http://127.0.0.1:8880/data/kwl/EWTStatus?required');
	$EWTStatus = $brinkData['kwl']['messages']['EWTStatus']['fields']['0']['value'];
	$brinkData = fetchjsonfromurl('http://127.0.0.1:8880/data/kwl/data?numeric&required');
	$Aussenlufttemperatur = $brinkData['kwl']['messages']['Aussenlufttemperatur']['fields']['0']['value'];
	$Luftmengemin = explode(';', $brinkData['LuftmengeStufe'.($Ventilatorstufe-1)])[0];
	$Luftmengemax = explode(';', $brinkData['LuftmengeStufe'.($Ventilatorstufe+1)])[0];
	$Luftmengestep = explode(';', $brinkData['LuftmengeStufe'.($Ventilatorstufe)])[3];
	$Luftmengecurrent = explode(';', $brinkData['LuftmengeStufe'.($Ventilatorstufe)])[0];
	date_default_timezone_set("Europe/Vienna");
	$hour = date("H", time());
	if (!($hour > 6 && $hour < 21)) $Luftmengemax = 120;
	if ($humidity > $humi_max) $newval = $Luftmengemax;
	else if ($humidity <= $humi_max && $humidity > $humi_aim) $newval = $Luftmengestep * round(((($humidity - $humi_aim) * (($Luftmengemax - $Luftmengemin)/($humi_max - $humi_aim))) + $humi_aim)/$Luftmengestep);
	else $newval = $Luftmengemin;
	if ($EWTStatus == 'Enabled') {
		if ($Aussenlufttemperatur >= $Aussenlufttemperaturmax) {
			if ($hour > 6 && $hour < 21) $newval = $Luftmengemax;
		if ($newval < ($Luftmengemax * 0.6)) $newval = ($Luftmengemax * 0.6);
	publishvalue('brink/kwl/Luftmengestufe1/', 'set', $newval);
	//echo("set fanspeed to ".$newval);
With this function:
* I set the air volume to maximum, as soon as I start cooling with the brink unit (there is a heat exchanger in air supply, which switches on as soon as the outside air temperature is over 23°C)
* during day between the (on brink unit) configured maximum air volume of stage 1 (I use stage 1 as "automatic" adjusted) is used
* during night I limit it to 120m³/h (it cannot be heared in house if it is running at 120m³ or below)
the sensor in bathroom is a wemos D1 with a DHT-hat. it reports every 5 minutes temperature and humidity.
costs: I use a RPI1 which is "left over", the ebus USB adapter, some cables, ... I would guess everything in sum is below 30€.
but don't calculate the hours working time on it ... ;)
Have fun!
BR
Alois
Posted: 28 Jan 2021, 13:06
by ESPHA
Thank you Alois, impressive! However, I am starting to get the feeling that my solution has had an excellent time-benefit ratio :D Are there specific functions other than setting ventilation level and filter indicator that you are using on a daily basis?
Posted: 29 Jan 2021, 16:34
by _Cyber_
yes, I read regularly the EWT status and depending on it, I put in summer the floor cooling into active state.
but, besides this, no. :-)
btw: brink itself offers the way to put a humididy sensor into the unit, cable it to the unit and then the fan speed control is done by the brink unit iself.
But it is disappointingly expensive, over 130€. google for brink rh sensor.
BR
Alois
Posted: 05 Feb 2021, 14:31
by ESPHA
Yes, those ridiculous Brink prices is what made me make my own device in the first place. 275 EUR (discount price) for a second RF remote control! :shock: :shock:
Posted: 06 Dec 2021, 21:13
by Dos
Nice projects
i want to build also something to control my WTW brink HR medium.
i have now a 3 position switch(to control the speed) that is connected trought a perilex connetor (to power the WTW and provide with the speed selection)
I want still want to use that swwitch but i also want to controll and monitor it by HA
So mybe a very easy solution is using 2x shelly1 devices
but what will happen when i select High and Medium speed . normaly it is not possible by a 3 position switch
but when using simple 2x NO contacts it is possible, wil teh controller be dammaged or it detects it selects automatcally the highes speed ?
Posted: 06 Dec 2021, 22:00
by Ath
The trouble will be that these switch solutions will in almost all cases conflict with each other, which means you will have to change your switch to be monitored in some way that it controls the relays, not and directly switches power to the WTW.
If you picked a Shelly 2.5 switch, you can connect the M(edium) and H(igh) speed each to a relay output (L(ow) is usually no power to either M or H), and also the 3-position switch to the inputs of the Shelly, and when using ESPEasy rules, you can ensure that they are never closed at the same time. And also control the WTW from HA.
Disadvantage of the 3-position switch is that it won't change its position when HA sends a different state (bummer :?), but replacing that switch with 2 push buttons (and maybe some type of signal-lights connected to the outputs for showing the currently selected state, or expose the LEDs of the Shelly) would resolve that.
Posted: 07 Dec 2021, 21:51
by Dos
yes so i have to removed actually the 3position switch to get it working, mmh ok thx
Posted: 07 Dec 2021, 22:03
by Ath
Dos wrote: 07 Dec 2021, 21:51 yes so i have to removed actually the 3position switch to get it working, mmh ok thx
Well, you can use it to control the WTW unit via the ESP, but when changing the state via HA, that switch won't assume the corresponding position... :lol: that's why I suggest to use push-buttons to change the state.
