No Publish after Deep Sleep
Posted: 27 Apr 2018, 12:05
Hi i am using a battery powered temperature and pressure unit.
After i tried ESPMega 20180422 up to 20180426.
In all of this version i don't get the new values in my Broker.
OLD Version (which is working):
INIT : Booting version: (custom)
INIT : Rebooted from deepsleep #12
FS : Mounting...
FS : Mount successful, used 75802 bytes of 957314
CRC : No program memory checksum found. Check output of crc2.py
CRC : Settings CRC ...FAIL
CRC : SecuritySettings CRC ...OK
INIT : Free RAM:23632
INIT : I2C
INIT : SPI not enabled
EVENT: System#Wake
WIFI : AP Mode disabled
WIFI : AP Mode ssid will be ESP_TEMP_1-0 with address 192.168.4.1
IP : Static IP :2517280960
WIFI : Connecting XXXXXXXXXXXXXX attempt #0
EVENT: System#Boot
WD : Uptime 0 ConnectFailures 0 FreeMem 20896
ADC : Analog value: 776
EVENT: ESP_1_Volt#Volt=3.32
BMP : Temperature: 23.36
BMP : Barometric Pressure: 1016.23
EVENT: ESP_Temp_1#Temperature=23.36
EVENT: ESP_Temp_1#Pressure=1016.23
BMP : Temperature: 23.35
BMP : Barometric Pressure: 1016.24
EVENT: ESP_Temp_1#Temperature=23.35
EVENT: ESP_Temp_1#Pressure=1016.24
WIFI : Connected! AP: XXXXXXXXXXXXXX (E0:28:6D:87:DE:CA) Ch: 11 Duration: 3064 ms
EVENT: WiFi#ChangedAccesspoint
WIFI : Static IP: 192.168.10.150 (ESP-TEMP-1-0) GW: 192.168.10.254 SN: 255.255.255.0
EVENT: WiFi#Connected
MQTT : Intentional reconnect
MQTT : Connected to broker with client ID: ESPClient_5C:CF:7F:4E:72:1E
Subscribed to: /ESP_TEMP_1/#
EVENT: MQTT#Connected
WD : Uptime 1 ConnectFailures 0 FreeMem 20248
ADC : Analog value: 772
EVENT: ESP_1_Volt#Volt=3.30
BMP : Temperature: 23.33
BMP : Barometric Pressure: 1016.29
EVENT: ESP_Temp_1#Temperature=23.33
EVENT: ESP_Temp_1#Pressure=1016.29
EVENT: System#Sleep
EVENT: System#Sleep
SLEEP: Powering down to deepsleep...
New Versions:
INIT : Booting version: (custom) (ESP82xx Core 2_3_0)
294 : INIT : Rebooted from deepsleep #2
295 : FS : Mounting...
320 : FS : Mount successful, used 75802 bytes of 957314
330 : CRC : No program memory checksum found. Check output of crc2.py
360 : CRC : SecuritySettings CRC ...OK
463 : INIT : Free RAM:24184
463 : INIT : I2C
463 : INIT : SPI not enabled
476 : INFO : Plugins: 10 [Normal] (ESP82xx Core 2_3_0)
476 : EVENT: System#Wake
505 : WIFI : Switch on WiFi
505 : WIFI : Set WiFi to STA
517 : EVENT: System#Boot
550 : WD : Uptime 0 ConnectFailures 0 FreeMem 23376
567 : ADC : Analog value: 771
569 : EVENT: ESP_1_Volt#Volt=3.29
1154 : BMP : Temperature: 23.38
1155 : BMP : Barometric Pressure: 1016.08
1156 : EVENT: ESP_Temp_1#Temperature=23.38
1181 : EVENT: ESP_Temp_1#Pressure=1016.08
2204 : WIFI : Connecting XXXXXXXXXXXXXXXXX attempt #0
2204 : IP : Static IP : 192.168.10.150 GW: 192.168.10.254 SN: 255.255.255.0 DNS: 192.168.10.254
2219 : WIFI : Static IP: 192.168.10.150 (ESP-TEMP-1-0) GW: 192.168.10.254 SN: 255.255.255.0 duration: 2206 ms
2230 : EVENT: WiFi#Connected
2260 : Webserver: start
2262 : MQTT : Intentional reconnect
2288 : MQTT : Failed to connect to broker
2294 : WD : Uptime 1 ConnectFailures 0 FreeMem 21016
2294 : MQTT : Intentional reconnect
2315 : MQTT : Failed to connect to broker
2319 : ADC : Analog value: 772
2321 : EVENT: ESP_1_Volt#Volt=3.30
3271 : BMP : Temperature: 23.40
3271 : BMP : Barometric Pressure: 1015.96
3272 : EVENT: ESP_Temp_1#Temperature=23.40
3300 : EVENT: ESP_Temp_1#Pressure=1015.96
5398 : Current Time Zone: STD time start: 2018-10-28 03:00:00 offset: 60 min
5400 : EVENT: Time#Initialized
5427 : EVENT: Clock#Time=Fri,09:38
5458 : WIFI : Connected! AP: XXXXXXXXXXXXXXXXX (E0:28:6D:87:DE:CA) Ch: 11 Duration: 3066 ms
5459 : EVENT: WiFi#ChangedAccesspoint
5488 : WIFI : Static IP: 192.168.10.150 (ESP-TEMP-1-0) GW: 192.168.10.254 SN: 255.255.255.0 duration: 1 ms
5499 : EVENT: WiFi#Connected
5538 : ADC : Analog value: 776
5540 : EVENT: ESP_1_Volt#Volt=3.32
5636 : BMP : Temperature: 23.38
5636 : BMP : Barometric Pressure: 1015.95
5637 : EVENT: ESP_Temp_1#Temperature=23.38
5662 : EVENT: ESP_Temp_1#Pressure=1015.95
6636 : EVENT: Time#Set
6663 : MQTT : Intentional reconnect
6736 : MQTT : Connected to broker with client ID: ESPClient_5C:CF:7F:4E:72:1E
6749 : Subscribed to: /ESP_TEMP_1/#
6779 : EVENT: MQTT#Connected
6806 : EVENT: System#Sleep
6836 : EVENT: System#Sleep
6865 : SLEEP: Powering down to deepsleep...
There is no Event for Volt, Temperature and Pressure after MQTT connected.
Maybe there is only a little rule needed in the new versions now.
FS : Mounting...
INIT : I2C
EVENT: System#Wake
EVENT: System#Boot
EVENT: System#Sleep
EVENT: System#Sleep
New Versions:
463 : INIT : I2C
