Running uPyEasy from a SD Card
Posted: 04 Apr 2018, 10:57
by LisaM
Cheered to early... :(
It is using the standard Loboris firmware for the ESP32-WROVER, like a Lolin32 Pro, which has both an SD Card and 4MB of PsRam (url: https://github.com/loboris/MicroPython_ ... _psram_all). Then put all of the modules code and the upyeasy code (in the SD root dir upyeasy) on the SD Card.
Next put this in the boot.py:
import uos,os
uos.sdconfig(uos.SDMODE_SPI, clk=14, mosi=15, miso=2, cs=13)
os.mountsd()
import upyeasy
upyeasy.main()
Since you now have 2MB of heap, there's plenty of room left to load all of the modules. But...
There's a bug on Loboris, meaning you'll have to change line 235 of the file uasyncio/__init__.py to:
ai = _socket.getaddrinfo(host, port)
Then put the next code on line 239:
s.settimeout(10000)
Then reboot, and the following appear in the log:
Internal FS (SPIFFS): Mounted on partition 'internalfs' [size: 1048576; Flash address: 0x200000]
Filesystem size: 956416 B
           Used: 14848 B
           Free: 941568 B
D (278) intr_alloc: Connected src 31 to int 9 (cpu 1)
 Mode: SPI
 Type: SDHC/SDXC
Speed: default speed (25 MHz)
  CSD: ver=1, sector_size=512, capacity=31088640 read_bl_len=9
  SCR: sd_spec=2, bus_width=5
loaded sink log
loaded sink console
loaded sink syslog
1970-01-01T00:26:53.005 [debug] uPyEasy: Init: Init constructor
1970-01-01T00:26:53.005 [debug] uPyEasy: Init: Entering init
1970-01-01 00:26:53 [debug] uPyEasy: Init: Create directory config
1970-01-01 00:26:54 [debug] uPyEasy: Init: Create directory plugins
1970-01-01 00:26:54 [debug] uPyEasy: Init: Create directory protocols
1970-01-01 00:26:54 [debug] uPyEasy: Init: Create directory scripts
1970-01-01 00:26:54 [debug] uPyEasy: Init: Create directory rules
1970-01-01 00:26:54 [debug] uPyEasy: Init: config Table
1970-01-01 00:26:55 [debug] uPyEasy: Init: network Table
1970-01-01 00:26:55 [debug] uPyEasy: Init: protocol Table
1970-01-01 00:26:55 [debug] uPyEasy: Init: controller Table
1970-01-01 00:26:55 [debug] uPyEasy: Init: hardware Table
1970-01-01 00:26:55 [debug] uPyEasy: Init: dxpin Table
1970-01-01 00:26:56 [debug] uPyEasy: Init: dxmap Table
1970-01-01 00:26:56 [debug] uPyEasy: Init: plugin Table
1970-01-01 00:26:56 [debug] uPyEasy: Init: pluginstore Table
1970-01-01 00:26:56 [debug] uPyEasy: Init: device Table
1970-01-01 00:26:56 [debug] uPyEasy: Init: service Table
1970-01-01 00:26:57 [debug] uPyEasy: Init: notification Table
1970-01-01 00:26:57 [debug] uPyEasy: Init: advanced Table
1970-01-01 00:26:57 [debug] uPyEasy: Init: script Table
1970-01-01 00:26:57 [debug] uPyEasy: Init: rule Table
1970-01-01 00:26:58 [debug] uPyEasy: Hal: Init
1970-01-01 00:26:59 [debug] uPyEasy: Hal: init, network record present
1970-01-01 00:26:59 [debug] uPyEasy: Hal: esp32
I (21346) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
1970-01-01 00:27:02 [debug] uPyEasy: Hal: esp32, ip: 192.168.178.109
1970-01-01 00:27:02 [debug] uPyEasy: Hal: nic present
1970-01-01 00:27:02 [debug] uPyEasy: Protocols: Load
1970-01-01 00:27:02 [debug] uPyEasy: Protocols: Init protocol records
1970-01-01 00:27:03 [debug] uPyEasy: Protocols: Load protocol domoticz_mqtt
1970-01-01 00:27:05 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_mqtt
1970-01-01 00:27:05 [debug] uPyEasy: Protocols: Load protocol domoticz_http
1970-01-01 00:27:06 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_http
1970-01-01 00:27:06 [debug] uPyEasy: Plugins: Load
1970-01-01 00:27:06 [debug] uPyEasy: Plugins: init plugin records
1970-01-01 00:27:07 [debug] uPyEasy: Plugins: Register frozen plugin switch
1970-01-01 00:27:09 [debug] uPyEasy: Plugin: switch contruction
1970-01-01 00:27:09 [debug] uPyEasy: Plugins: Create frozen plugin Record: switch
1970-01-01 00:27:09 [debug] uPyEasy: Plugins: Register frozen plugin bme280
1970-01-01 00:27:11 [debug] uPyEasy: Plugins: Create frozen plugin Record: bme280
1970-01-01 00:27:11 [debug] uPyEasy: Plugins: Register frozen plugin test
1970-01-01 00:27:11 [debug] uPyEasy: Plugins: Create frozen plugin Record: test
1970-01-01 00:27:12 [debug] uPyEasy: Plugins: Register frozen plugin ds18
1970-01-01 00:27:13 [debug] uPyEasy: Plugin: ds18 contruction
1970-01-01 00:27:14 [debug] uPyEasy: Plugins: Create frozen plugin Record: ds18
1970-01-01 00:27:14 [debug] uPyEasy: Init: Init devices
1970-01-01 00:27:14 [debug] uPyEasy: Scripts: Load
1970-01-01 00:27:14 [debug] uPyEasy: Scripts: Init
1970-01-01 00:27:14 [debug] uPyEasy: Plugins: GetQueue
1970-01-01 00:27:15 [debug] uPyEasy: Scripts: init scripts records
1970-01-01 00:27:15 [debug] uPyEasy: Scripts: init rules records
1970-01-01 00:27:16 [debug] uPyEasy: Utils: Sys hostname
1970-01-01 00:27:16 [debug] uPyEasy: Utils: uPyEasy Name
Set syslog hostname 0.0.0.0
reloaded sink syslog
1970-01-01 00:27:17 [debug] uPyEasy-uPyEasy: Hal: Entering SetTime
1970-01-01 00:27:17 [debug] uPyEasy-uPyEasy: Hal: Entering GetNtpTime
1970-01-01 00:27:17 [debug] uPyEasy-uPyEasy: Hal: network Table
1970-01-01 00:27:17 [debug] uPyEasy-uPyEasy: Hal: Using NTP Hostname: pool.ntp.org
1970-01-01 00:27:17 [debug] uPyEasy-uPyEasy: Hal: TimeZome offset: 60
1970-01-01 00:27:18 [debug] uPyEasy-uPyEasy: Hal: Received UTC NTP Time: 576168798
1970-01-01 00:27:18 [debug] uPyEasy-uPyEasy: Hal: Timezone corrected NTP Time: 576172398
1970-01-01 00:27:18 [debug] uPyEasy-uPyEasy: Hal: DST corrected NTP Time: 576172398
1970-01-01 00:27:18 [debug] uPyEasy-uPyEasy: Hal: Received NTP Time: 576172398
1970-01-01 00:27:19 [debug] uPyEasy-uPyEasy: Hal: StartTime: 576172398
1970-01-01 00:27:19 [debug] uPyEasy-uPyEasy: Set time: 1970-01-01T00:27:19
1970-01-01 00:27:30 [debug] uPyEasy-uPyEasy: Main: Pre-loading home page
1970-01-01 00:27:31 [debug] uPyEasy-uPyEasy: Hal: get_ip_address esp32, ip: 192.168.178.109
1970-01-01 00:27:31 [debug] uPyEasy-uPyEasy: Main: Schedule async loops
1970-01-01 00:27:31 [debug] uPyEasy-uPyEasy: Main: uPyEasy Main Async Loop
1970-01-01 00:27:32 [debug] uPyEasy-uPyEasy: Plugins: Async processing plugins
1970-01-01 00:27:32 [debug] uPyEasy-uPyEasy: Protocols: Async processing protocols
1970-01-01 00:27:33 [debug] uPyEasy-uPyEasy: Scripts: Async processing scripts/rules
The nasty part? It then hangs and doesn't response anymore... :oops:
I've have filed this bug for it: https://github.com/loboris/MicroPython_ ... issues/119
Re: Running uPyEasy from a SD Card!
Posted: 04 Apr 2018, 14:34
by AndrewJ
Very nice!! :D :D
I'll give it a try on a TTGO T8 ESP32 board which arrived recently, which has an SD card slot.
(I do/did have a Lolin32 Pro, which also has SD, but it seems to have died.... :cry: )
Cheers
Andrew
Posted: 04 Apr 2018, 15:28
by LisaM
AndrewJ wrote: 04 Apr 2018, 14:34 Very nice!! :D :D
Cheers
Andrew
In that case, you'll need to adjust the parameters:
spi = machine.SPI(1, baudrate=10000000, polarity=0, phase=0, sck=machine.Pin(14), miso=machine.Pin(2), mosi=machine.Pin(15))
sd = sdcard.SDCard(spi, machine.Pin(13))
For the Lolin32 pro, the connections listed above are:
sdcard lolin32 pro.png (21.99 KiB) Viewed 17061 times
So you'll need to take a look at your ESP32 SD Card to see on which pins miso, mosin, sck and cs are. CS is used in the secode code line.
Posted: 04 Apr 2018, 16:37
by AndrewJ
Hi Lisa,
Thanks for the tip - it should avoid a quantity of hair-pulling! :)
Andrew
Posted: 04 Apr 2018, 17:10
by LisaM
AndrewJ wrote: 04 Apr 2018, 16:37 Hi Lisa,
Andrew
Sorry Andrew, i have run into a wall. See first page.
You can still mount the SD however and use it using the uPyEasy firmware version, with the uPyEasy firmware version it's not possible to run uPyEasy from the SD card.
import machine, os, sdcard
vfs = os.VfsFat(sd)
os.mount(vfs, "/sd")
If you then run the command os.listdir() the sd directory will be visible.
Posted: 04 Apr 2018, 19:09
by AndrewJ
LisaM wrote: 04 Apr 2018, 17:10
Andrew
vfs = os.VfsFat(sd)
Oh, that's a real shame. :( Still, there's a lot of potential there, when the issue is resolved.
I haven't yet experimented with the SD card in the TTGO, I'll see what happens with it.
Andrew
Posted: 09 Apr 2018, 11:31
by Drum
Having the extra storage still opens a lot of very cool possibilities, especially for displaying information in stored templates, almost endless functional menus on touch displays....
Maybe it is possible to put some larger parts of the firmware, like more complex plugins on the SD Card or boot from internal memory and run from SD.
Even without a larger firmware, it still opens the possibility for much more advanced inexpensive wireless touchscreen controllers and displays.
I really have to work on my programming skills.....
Posted: 09 Apr 2018, 23:10
by LisaM
PYcom also has an ESP32 micropython version for their ESP32's, i'll order one to see if that's working as planned. I was going to order the NB-IoT ESP32 version from them anyway...
Cheers,
Lisa
