Somfy Tilt 50 RTS needs continuous transmission
Posted: 31 Mar 2018, 00:50
I'm trying to control my Somfy tilt 50 RTS motor with RFLink. I got a 433.42 mhz rflink transmitter which seems to work fine.
The problem is that the tilt 50 motor (used to only control the tilt of 50mm blinds) requires continuous commands.
Whereas most other somfy motors you press down and they keep going doing until they reach their limit and same for up. But the tilt 50 stops moving when you stop pressing the button on the remote.
If I try to send the commands in a loop it works but it moves in steps instead of 1 fluid continuous motion.
Does anybody know how to do this correctly?
