MQTT IMPORT and rules trigger
leel1967l
#1 Post by leel1967l » 25 Mar 2018, 12:46
Does MQTT Import modified with taskvalueset triggers a rule?
I am having the following issue:
I created a MQTT IMPORT task (name=import, value=set1, task number 2) and the following rule:
on import#set1 do
  ..do something ..
If I fire the command from a rule:
taskvalueset,2,1,100
taskRun,2
Log:
145870 : ACT : taskvalueset,2,1,100
145883 : ACT : taskRun,2
The first rule is not triggered
Wemos D1
Firmware: mega-20180326
leel1967l
Re: MQTT IMPORT and rules trigger
#2 Post by leel1967l » 26 Mar 2018, 21:52
I have updated the description of the problem after fixing some syntax errors.
Can anyone have a look?
toffel969
#3 Post by toffel969 » 27 Mar 2018, 13:08
leel1967l wrote: 25 Mar 2018, 12:46 Hi,
on import#set1 do
  ..do something ..
taskRun,2
Log:
Wemos D1
I'm not sure, but like stated in the other thread, you should probably not use taskvalueset on the mqtt import device.
