Relay daily timer - reboot handle?
spachal
#1 Post by spachal » 11 Mar 2018, 18:05
Hallo, I need to keep one of my relays, connected to ESP8266, switch on and off every day, at the same time interval.
So far, it's easy to do so by rules. Relay is defined as switch input device, but I'm controlling it directly via GPIO (GPIO13 in this case):
On Clock#Time=All,09:00 do
  Gpio,13,1
On Clock#Time=All,15:30 do
  Gpio,13,0
But I need to handle the situation, when ESP could be rebooted between 9:00-15:30 for any reason. In this case, the relay will stay off == problem.
I found this solution, that could handle this reboot, but it's not ideal. It 'takes' one of system timers and could cause very short on/off switch of relay, that is not 'healthy' for connected AC device ..
On System#Boot do
  TimerSet,6,1  // timer for relay02
  Gpio,13,1
  Gpio,13,0
On Rules#Timer=6 do
  If %systime% < 09:00:00
    Gpio,13,0
  Else
    Gpio,13,1
  Endif
  If %systime% > 15:30:00
    Gpio,13,0
  Endif
It's a pity that we can't use boolean logic or nested if-if conditions .. Is there any 'more elegant' solution how to handle relay timer for any accidental reboot of controller?
Thanks for help! :]
Please excuse my English, thanks!
papperone
Re: Relay daily timer - reboot handle?
#2 Post by papperone » 11 Mar 2018, 19:48
I think the AND / OR boolean have been introduced recently so you can certainly use them:
On System#Boot do
  If %systime% > 09:00:00 and %systime% < 15:30:00
    Gpio,13,1
  Else
    Gpio,13,0
  Endif
#3 Post by grovkillen » 11 Mar 2018, 22:22
Yep, not yet documented. Sorry :oops: ;)
spachal
#4 Post by spachal » 12 Mar 2018, 10:04
papperone wrote: 11 Mar 2018, 19:48 I think the AND / OR boolean have been introduced recently so you can certainly use them:
PERFECT, that's exactly what I need, it helps a lot, thanks!! :]
