Hi all,
Until now I used my RFlink in combination with domoticz.
Currently I am wondering if I also can use RFlink stand alone with a little help from esp easy.
My RFlink is connected to an ESP-01 device so that it is WiFi enabled.
What I want to do: send command to RFlink (trigger)
Response:
1) send another command
2) send IR code using esp easy
3) turn an output pin on the RFlink high.
Is this possible stand alone? That saves me an extra RPI
Stand alone RFlink
Re: Stand alone RFlink
Using RFLink with ESP Easy can run as a standalone unit.
But features are limited to what you can do with rules.
Sample:
Sample:
on !RFLink#NewKaku;ID=12345678;SWITCH=2;CMD=ON; do
SerialSend 10;NewKaku;1234abcd;2;ON;
SerialSend 10;NewKaku;1234abcd;3;ON;
thank you very much! works like a charm
