Hi all,
Is it possible to add this device (chineese dimmer switch => https://www.aliexpress.com/item/UK-Stan ... 24037.html)
Well identified and configured on domoticz but without action on switch when commanded
thank you
RFLink Gateway V1.1 - R48
button A (light on/off)
2018-02-03 10:32:45 - 20;CD;DEBUG;Pulses=50;Pulses(uSec)=870,210,210,810,840,210,210,810,840,210,840,210,840,210,840,210,840,210,840,210,210,810,840,210,840,210,840,210,840,210,840,210,840,210,840,210,840,210,210,810,210,810,840,210,210,810,210,810,210,6990;
20;CE;Eurodomest;ID=050201;SWITCH=05;CMD=ALLON;
button B (light -)
button C (light +)
2018-02-03 10:35:10 - 20;64;DEBUG;Pulses=50;Pulses(uSec)=900,210,210,810,840,210,210,810,840,210,840,210,840,210,840,210,840,210,840,210,210,810,840,210,840,210,840,210,840,210,840,210,840,210,840,210,840,210,210,810,840,210,210,810,210,810,210,810,210,6990;
20;65;EV1527;ID=0afdfe;SWITCH=08;CMD=ON;
button D (no use)
2018-02-03 10:36:15 20;B2;DEBUG;Pulses=50;Pulses(uSec)=930,210,210,810,840,210,210,810,840,210,840,210,840,210,840,210,840,210,840,210,210,810,840,210,840,210,840,210,840,210,840,210,840,210,840,210,840,210,210,810,210,810,210,810,840,210,210,810,210,6990;
20;B3;Eurodomest;ID=050201;SWITCH=06;CMD=ALLON;
eurodomest dimmer switch
Re: eurodomest dimmer switch
You can learn this remote to rflink with the following explanation:
http://www.rflink.nl/blog2/faq#RFFind
Thank you. It works !
