Can't get the esp stable
I have a problem with all my esp units (4 pcs)
I run them with R48 and core 2.0.0
When I run the esp's without a sensor for example ds18b20 they run fine without problems.
But when I connect a ds18b20 after a few hours the esp is unreachable and I have to disconnect power and then it is up again. I thought it was my power supply....
What I did was Esp01 with dallas and Esp02 without dallas on de same 3Amp power supply and this morning the Esp02 was still up and running and the Esp01 was unreachable. I also did a log on the power supply and there where no dips.
I also have nodemcu v0.9 with this one I have the same issue. Stable without dallas with dallas it is unreachable after a while.
Re: Can't get the esp stable
If it's unreachable, it could have rebooted into upload mode. I've seen this behavior in the past but not recently on my units.
I'm using NodeMCU 1.0 boards and always connect Dallas and DHT to GPIO-12 and/or GPIO-13 to stay away from GPIO-0.
What GPIO are u using for the dallas sensor?
I used gpio16 for the dallas
I will try gpio12 to see if it makes a difference.
It doesn't make difference if I use gpio12 Esp01 is again unreachable. Also Esp02 without sensors is not reachable. If I disconnect power and power up again there are back online.
There also not in ap mode. Maybe in Boot will it help if I pull gpio0 high?
Esp01 was online for 5 hours
Esp02 was online for 13 hours
I don't have domoticz running all the time because I use it now on my pc. Does that something to do with it?
did you try with domoticz, i think maybe can be this, my advice are to put you definition of domoticz on espeasy.
Had that sort of problems too with my ESP modules.
I placed a small capacitor (1-10 nF) as close as possible to the reset pin and ground to prevent the ESP from resetting on EM interference.
I also use an extra capacitor (1-10 uF) between Vcc & ground close to the ESP Vcc pin.
That made them stable enough too.
You can also have a bad breadboard which causes problems, or perhaps bad dupont wire/connector.
I had the same problem with v48 and v51
latest version 52 fixed the issue (do a reset as well configure it from scratch just in case).
and I 2nd the 10µF capacitor close to the VCC and GND on the ESP to smooth the power
Uploaded r52 2 esp's remain stable now for 17 hrs without any sensor attached.
2 esp's only have a ds18b20 and they don't run stable.
Both give same error. If I disconnect the ds18b20 than there is no problem. I also cannot Boot with the ds18b20 attached. Maybe a bug this didn't happen with R48
https://www.dropbox.com/s/9zybvo934h5h6 ... 1.png?dl=0
Can somebody please tell me there exact setup of theRe esp and how it is running stable?
My setup:
Esp-12e loaded with R052 core 2.0.0
Flashed as nodemcu v1.0 4m (1m spffs)
Power supply 12v 2A 220v ac to dc
Buck converter 12v to 3.3v capable for 3Amp
Extra capacitor over 12v side 10uF
And over 3.3v side 10uF.
Only sensor attached ds18b20 on gpio 13. +3.3v signal gnd. between 3.3v and signal 4.7k ohm resistor
And every morning I check the esp there is no connection possible. I really don't have a clue what's going wrong here.
My setup:
If possible in your situation, hook up the unit to the serial port on your computer, set serial debug level to 4 and keep the serial monitor running for a day. Then you may get a clue about what's going on there.
Some possible causes:
- It boots into upload mode and that's the last thing you will see in serial monitor: boot mode:(1,6) or boot mode:(1,7)
- It looses WiFi connection and can't reestablish. You will likely see some messages from the SDK core routines about the issue.
I think i found the problem... What i can understand from the log it didnt connect with my Domoticz server. (my server at the moment is my home pc that i shut down at night. because Domoticz is still my test HA because i use the Nodo as main HA) From what i can see in the log the problems of instability started short after i shutted down my pc. (Domoticz Server) The next morning i could'nt connect to the esp with my cellphone. but in the afternoon it was working again. (my pc was running again ofcourse with the domoticz server).
This piece of the log was just before i couldn't connect anymore to my esp by entering the ip address.
And here is my pc with domoticz running again.
So i think the esp is stable. But i didn't know that Domoticz must run to get your esp running
WD : Uptime 572 ConnectFailures 28 FreeMem 25920
WD : Uptime 573 ConnectFailures 28 FreeMem 26424
DS : Temperature: 13.69 (28-30-ef-b6-5-0-0-eb)
HTTP : connecting to 192.168.1.6
HTTP : connection failed
WD : Uptime 573 ConnectFailures 29 FreeMem 25928
WD : Uptime 574 ConnectFailures 29 FreeMem 26424
WD : Uptime 574 ConnectFailures 30 FreeMem 25920
WD : Uptime 575 ConnectFailures 30 FreeMem 26424
Delayed Reset 60
Delayed Reset 59
Delayed Reset 58
Delayed Reset 57
Delayed Reset 56
Delayed Reset 55
Delayed Reset 54
Delayed Reset 53
Delayed Reset 52
Delayed Reset 51
Delayed Reset 50
Delayed Reset 49
Delayed Reset 48
Delayed Reset 47
Delayed Reset 46
Delayed Reset 45
Delayed Reset 44
Delayed Reset 43
Delayed Reset 42
Delayed Reset 41
Delayed Reset 40
Delayed Reset 39
Delayed Reset 38
Delayed Reset 37
Delayed Reset 36
Delayed Reset 35
Delayed Reset 34
Delayed Reset 33
Delayed Reset 32
Delayed Reset 31
Delayed Reset 30
Delayed Reset 29
Delayed Reset 28
Delayed Reset 27
Delayed Reset 26
Delayed Reset 25
Delayed Reset 24
Delayed Reset 23
Delayed Reset 22
Delayed Reset 21
Delayed Reset 20
Delayed Reset 19
Delayed Reset 18
Delayed Reset 17
Delayed Reset 16
Delayed Reset 15
Delayed Reset 14
Delayed Reset 13
Delayed Reset 12
Delayed Reset 11
Delayed Reset 10
Delayed Reset 9
Delayed Reset 8
Delayed Reset 7
Delayed Reset 6
Delayed Reset 5
Delayed Reset 4
Delayed Reset 3
Delayed Reset 2
Delayed Reset 1
ets Jan 8 2013,rst cause:4, boot mode:(3,4)
wdt reset
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
ªU
INIT : Booting Build nr:55
mode : sta(5c:cf:7f:07:91:7c) + softAP(5e:cf:7f:07:91:7c)
add if1
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
bcn 100
bcn 0
del if1
WIFI : Connecting... 1
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
pm open phy_2,type:2 0 0
cnt
connected with DSSMeekelenkamp_ext, channel 1
wifi evt: 0dhcp client start...
wifi evt: 3ip:192.168.1.101,mask:255.255.255.0,gw:192.168.1.1
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
NTP : NTP sync requested
:urn 48:urd 48, 48, 0NTP : NTP replied!
:ur 1WD : Uptime 0 ConnectFailures 0 FreeMem 27240
:err -8HTTP : connection failed
WD : Uptime 1 ConnectFailures 1 FreeMem 27112
WD : Uptime 1 ConnectFailures 1 FreeMem 27080
WD : Uptime 2 ConnectFailures 2 FreeMem 27032
WD : Uptime 2 ConnectFailures 2 FreeMem 26968
WD : Uptime 3 ConnectFailures 3 FreeMem 26904
WD : Uptime 4 ConnectFailures 4 FreeMem 26888
WD : Uptime 5 ConnectFailures 5 FreeMem 26856
Fatal exception (0):
epc1=0x402278a3, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
Exception (0):
epc1=0x402278a3 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: sys
sp: 3ffffdd0 end: 3fffffb0 offset: 01a0
>>>stack>>>
3fffff70: 3fffdcc0 4010399b 00000000 3ffef424
3fffff80: 401039d6 3fffdab0 00000000 3fffdcb0
3fffff90: 3ffea688 3fffdab0 00000000 4021b6ff
3fffffa0: 40000f49 40000f49 3fffdab0 40000f49
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
ªU
add if1
bcn 100
bcn 0
del if1
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
:ur 1WD : Uptime 0 ConnectFailures 0 FreeMem 27272
WD : Uptime 1 ConnectFailures 1 FreeMem 27144
WD : Uptime 1 ConnectFailures 2 FreeMem 26504
DS : Temperature: 13.75 (28-30-ef-b6-5-0-0-eb)
WD : Uptime 2 ConnectFailures 3 FreeMem 26440
WD : Uptime 3 ConnectFailures 3 FreeMem 26920
WD : Uptime 3 ConnectFailures 4 FreeMem 26360
WD : Uptime 4 ConnectFailures 4 FreeMem 26904
WD : Uptime 4 ConnectFailures 5 FreeMem 26376
WD : Uptime 5 ConnectFailures 5 FreeMem 26904
WD : Uptime 5 ConnectFailures 6 FreeMem 26296
WD : Uptime 6 ConnectFailures 6 FreeMem 26856
WD : Uptime 6 ConnectFailures 7 FreeMem 26296
WD : Uptime 7 ConnectFailures 7 FreeMem 26856
WD : Uptime 7 ConnectFailures 8 FreeMem 26296
WD : Uptime 8 ConnectFailures 8 FreeMem 26856
WD : Uptime 8 ConnectFailures 9 FreeMem 26296
WD : Uptime 9 ConnectFailures 9 FreeMem 26856
WD : Uptime 9 ConnectFailures 10 FreeMem 26328
WD : Uptime 10 ConnectFailures 10 FreeMem 26856
DS : Temperature: 13.62 (28-30-ef-b6-5-0-0-eb)
WD : Uptime 10 ConnectFailures 11 FreeMem 26296
WD : Uptime 11 ConnectFailures 11 FreeMem 26856
WD : Uptime 11 ConnectFailures 12 FreeMem 26272
WD : Uptime 12 ConnectFailures 12 FreeMem 26824
WD : Uptime 12 ConnectFailures 13 FreeMem 26296
WD : Uptime 13 ConnectFailures 13 FreeMem 26808
WD : Uptime 13 ConnectFailures 14 FreeMem 26288
WD : Uptime 14 ConnectFailures 14 FreeMem 26808
WD : Uptime 14 ConnectFailures 15 FreeMem 26256
WD : Uptime 15 ConnectFailures 15 FreeMem 26792
WD : Uptime 15 ConnectFailures 16 FreeMem 26272
WD : Uptime 16 ConnectFailures 16 FreeMem 26792
WD : Uptime 16 ConnectFailures 17 FreeMem 26272
WD : Uptime 17 ConnectFailures 17 FreeMem 26792
WD : Uptime 17 ConnectFailures 18 FreeMem 26272
WD : Uptime 18 ConnectFailures 18 FreeMem 26792
WD : Uptime 18 ConnectFailures 19 FreeMem 26272
WD : Uptime 19 ConnectFailures 19 FreeMem 26792
WD : Uptime 19 ConnectFailures 20 FreeMem 26272
WD : Uptime 20 ConnectFailures 20 FreeMem 26792
WD : Uptime 20 ConnectFailures 21 FreeMem 26272
WD : Uptime 21 ConnectFailures 21 FreeMem 26792
WD : Uptime 21 ConnectFailures 22 FreeMem 26272
WD : Uptime 22 ConnectFailures 22 FreeMem 26792
WD : Uptime 22 ConnectFailures 23 FreeMem 26272
WD : Uptime 23 ConnectFailures 23 FreeMem 26792
WD : Uptime 23 ConnectFailures 24 FreeMem 26272
WD : Uptime 24 ConnectFailures 24 FreeMem 26792
WD : Uptime 24 ConnectFailures 25 FreeMem 26272
WD : Uptime 25 ConnectFailures 25 FreeMem 26792
WD : Uptime 25 ConnectFailures 26 FreeMem 26272
WD : Uptime 26 ConnectFailures 26 FreeMem 26792
WD : Uptime 26 ConnectFailures 27 FreeMem 26272
WD : Uptime 27 ConnectFailures 27 FreeMem 26792
WD : Uptime 27 ConnectFailures 28 FreeMem 26272
WD : Uptime 28 ConnectFailures 28 FreeMem 26792
WD : Uptime 28 ConnectFailures 29 FreeMem 26272
WD : Uptime 29 ConnectFailures 29 FreeMem 26792
DS : Temperature: 13.56 (28-30-ef-b6-5-0-0-eb)
WD : Uptime 29 ConnectFailures 30 FreeMem 26272
WD : Uptime 30 ConnectFailures 30 FreeMem 26792
Fatal exception (28):
epc1=0x402278b4, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00003abc, depc=0x00000000
Exception (28):
epc1=0x402278b4 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00003abc depc=0x00000000
ctx: sys
>>>stack>>>
3fffff70: 3fffdcc0 4010399b 00000000 3ffef3d8
3fffff80: 4022794e 3fffdab0 00000000 3fffdcb0
3fffff90: 3ffea680 3fffdab0 00000000 4021b6ff
<<<stack<<<
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
ªU
add if1
bcn 100
bcn 0
del if1
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
ªU
add if1
bcn 100
bcn 0
del if1
f 0, Fatal exception (9):
epc1=0x402278b1, epc2=0x00000000, epc3=0x00000000, excvaddr=0x402278ab, depc=0x00000000
Exception (9):
epc1=0x402278b1 epc2=0x00000000 epc3=0x00000000 excvaddr=0x402278ab depc=0x00000000
ctx: sys
>>>stack>>>
3fffff70: 3fffdcc0 4010399b 00000000 00000000
3fffff90: 3ffea680 3fffdab0 00000000 3fffdcc0
<<<stack<<<
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
ªU
add if1
bcn 100
bcn 0
del if1
Exception (9):
ctx: sys
>>>stack>>>
<<<stack<<<
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
ªU
add if1
bcn 100
bcn 0
del if1
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
<<<stack<<<
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
ªU
add if1
bcn 100
bcn 0
del if1
f 0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
DS : Temperature: 11.94 (28-30-ef-b6-5-0-0-eb)
:ref 1/json.htm?type=command¶m=udevice&idx=34&svalue=11.94
:wr:sent 111:rn 213:wwHTTP/1.1 200 OKHTTP : Succes!
Content-Length: 53:rcla:abortContent-Type: application/json;charset=UTF-8Cache-Control: no-cachePragma: no-cacheAccess-Control-Allow-Origin: *{
"status" : "OK",
"title" : "Update Device"
:c0 1, 213}
HTTP : closing connection
:ur 1WD : Uptime 1 ConnectFailures 0 FreeMem 27144
WD : Uptime 1 ConnectFailures 0 FreeMem 27112
Content-Length: 53Content-Type: application/json;charset=UTF-8Cache-Control: no-cachePragma: no-cacheAccess-Control-Allow-Origin: *{
"status" : "OK",
:c0 1, 213}
:ur 1:closeWD : Uptime 2 ConnectFailures 0 FreeMem 26792
Content-Length: 53Content-Type: application/json;charset=UTF-8Cache-Control: no-cachePragma: no-cacheAccess-Control-Allow-Origin: *:rcla:abort{
"status" : "OK",
:c0 1, 213}
:ur 1WD : Uptime 2 ConnectFailures 0 FreeMem 26744
WD : Uptime 3 ConnectFailures 0 FreeMem 26936
"status" : "OK",
:c0 1, 213}
:ur 1WD : Uptime 3 ConnectFailures 0 FreeMem 26824
WD : Uptime 4 ConnectFailures 0 FreeMem 26824
DS : Temperature: 11.88 (28-30-ef-b6-5-0-0-eb)
:ref 1/json.htm?type=command¶m=udevice&idx=34&svalue=11.88
:rcla:abortContent-Length: 53Content-Type: application/json;charset=UTF-8Cache-Control: no-cachePragma: no-cacheAccess-Control-Allow-Origin: *{
"status" : "OK",
:c0 1, 213}
:ur 1WD : Uptime 4 ConnectFailures 0 FreeMem 26792
WD : Uptime 5 ConnectFailures 0 FreeMem 26792
"status" : "OK",
:c0 1, 213}
:ur 1:closeWD : Uptime 5 ConnectFailures 0 FreeMem 26352
WD : Uptime 6 ConnectFailures 0 FreeMem 26552
:rcla:abort "status" : "OK",
:c0 1, 213}
:ur 1WD : Uptime 6 ConnectFailures 0 FreeMem 26568
WD : Uptime 7 ConnectFailures 0 FreeMem 26792
DS : Temperature: 11.81 (28-30-ef-b6-5-0-0-eb)
:ref 1/json.htm?type=command¶m=udevice&idx=34&svalue=11.81
"status" : "OK",
:c0 1, 213}
:ur 1WD : Uptime 7 ConnectFailures 0 FreeMem 26792
WD : Uptime 8 ConnectFailures 0 FreeMem 26792
Users browsing this forum: Bing [Bot] and 4 guests
