Page 4 of 6
Re: ESP32 boards
Posted: 17 Mar 2018, 20:07
by karl222
I am getting permanent reboots...
I am using an esp32 wroom module and no wrover, can this be a reason?
Karl
Re: ESP32 boards
Posted: 18 Mar 2018, 15:46
by LisaM
karl222 wrote: ↑17 Mar 2018, 20:07
Karl
Can you share your logfile?
Which wroom module?
Re: ESP32 boards
Posted: 18 Mar 2018, 16:11
by BertB
@LisaM
This is all it does:
On the ESP32:
ESP32-WROVER
FCC ID2AC7Z-ESP32WROVER
rst:0x1 (POWERON_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3f400020,len:429240
Re: ESP32 boards
Posted: 18 Mar 2018, 16:19
by karl222
Me too
Re: ESP32 boards
Posted: 18 Mar 2018, 16:23
by BertB
nd I have the same with a ESP-WROOM-32
Re: ESP32 boards
Posted: 18 Mar 2018, 17:00
by LisaM
I've my working setup attached. I'm using this one:
https://www.aliexpress.com/item/Officia ... 21054.html
Can you post a picture of your setup and a link to where you bought it?
I have also these in stock:
https://www.aliexpress.com/item/ESP32-B ... 25963.html (didn't work so far)
https://www.aliexpress.com/item/LOLIN32 ... 682537.htm (it has 4MB of PsRam and is really different)
https://www.aliexpress.com/item/ESP-32S ... 38946.html (not soldered yet)
Please also try this (non-upyeasy) firmware:
http://micropython.org/download#esp32 to see if it's something in uPyEasy ESP32 firmware or if it's the ESP32 board itself.
There seems to be a lot of different ESP32 board going around, which are all different..
Cheers,
Lisa
Re: ESP32 boards
Posted: 18 Mar 2018, 17:31
by BertB
I have these two:
https://nl.aliexpress.com/item/Lolin-ES ... 0.0.0c92Eb
and:
https://nl.aliexpress.com/item/LOLIN32- ... 0.0.0c92Eb
The Oled one has no further devices attached and is directly connected to the USB of my PC.
The other one only has a BME/BMP 280 and a DS18B20
Re: ESP32 boards
Posted: 18 Mar 2018, 17:45
by BertB
On both boards, the first version of upyeasy works.
Re: ESP32 boards
Posted: 18 Mar 2018, 19:20
by LisaM
BertB wrote: ↑18 Mar 2018, 17:45
That's very interesting! The first version was a 4MB version, while later ones are 2MB versions.
I've added a 4MB version (upyeasy_v021_20180318_test_esp32_4096.bin) to the release dir:
https://github.com/letscontrolit/uPyEasy/releases
Can you try the 4MB version?
Cheers,
Lisa
Re: ESP32 boards
Posted: 18 Mar 2018, 19:46
by karl222
I am using this esp32 board
https://www.aliexpress.com/item/Wireles ... 0.0.gYWUKY
it is an esp32 wroom. I will give it a try with the 4MB version.
I'll keep you posted
I also have ordered esp32 wrover boards to see whether it works or not.. I really would love to see it running
regards
karl
Re: ESP32 boards
Posted: 18 Mar 2018, 20:56
by AndrewJ
Hi all,
I have (or had) three ESP32 boards:-
1. Lolin32 Lite: bought from Aliexpress,
https://www.aliexpress.com/item/WEMOS-L ... 0.0.O82kUi
Now disconnected, but it had a BME280 and a DS18B20 connected. This is now my main ESP32 board (for the time being).
2. Lolin32 pro WROVER with 4Mb PSRAM: also from Aliexpress:
https://www.aliexpress.com/item/LOLIN32 ... 0.0.O82kUi.
This one seems to have died just recently, it got very hot and now refuses to connect! (I hear that this version can suffer from this problem and that Wemos have withdrawn it from sale - although some other sellers are still offering it.)
3. DOIT ESP32 DEVKIT V1: Rev 0 chip. bought when ESP32 first came out (can't find where I bought it now). I've more or less abandoned this board, as it has a very unreliable USB socket.
Lisa, you are right when you say there is a variety of ESP32 boards out there!! And I think they can have various differences, particularly the peripheral components used, which may affect tolerances, timings etc. To make life harder, the reliability of at least some of the variants seems to be questionable.
As others have reported, I was getting the repeated boot loops with boards 1. and 2. when I used the bin file from the releases page of Github. Interestingly, more recently I built uPyEasy from source, using the recently issued instructions, and it worked! (no bootloop) Yay!
Could be something in the flash settings of the Makefile vs. esp flash tool?? I haven't looked into this yet.
Re: ESP32 boards
Posted: 18 Mar 2018, 21:45
by karl222
Bingo, I do have the DOIT DEVKIT V1 ESP32 module with WROOM32. I just tried to flash it with the 4MB firmware and it doesn't work either
Now I am going to try the stm32 module. Last time I had Trouble to wire up the Ethernet module but got some hints.
reagards
karl
Re: ESP32 boards
Posted: 18 Mar 2018, 21:58
by BertB
With the 4M bin, I get this
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
load:0x3f400020,len:429368
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
Re: ESP32 boards
Posted: 20 Mar 2018, 00:43
by LisaM
AndrewJ wrote: ↑18 Mar 2018, 20:56
Hi all,
Interesting! I'm happy the dev guide worked by the way!
The makefile says:
BAUD ?= 460800
FLASH_MODE ?= dio
FLASH_FREQ ?= 40m
Translated, it means this flash command:
sudo python esptool.py --chip esp32 --port /dev/ttyUSB0 -b 460800 write_flash --flash_freq 40m --flash_mode dio -z 0x1000 upyeasy_vXX_2018YYZZ_test_esp32_2048.bin
Does that work for you @bert @karl?
Re: ESP32 boards
Posted: 20 Mar 2018, 11:27
by karl222
For me it’s a bit too technical. My knowledge is exhausted with cop/paste of instructions...
@abert: can you please share the .bin file...
Thx
Karl
Re: ESP32 boards
Posted: 20 Mar 2018, 17:47
by karl222
I am coming closer
btw. I have received an esp32 wrover module now and tried to test it
I've tried this but it doesn't work:
E:\esp32>esptool.py --chip esp32 --port COM7 --baud 460800 write_flash --flash_freq 40m --flash_mode dio -z 0x1000 upyeasy_v021_20180318_test_esp32_4096.bin
can you please double check what's wrong with it?
thx
karl
Re: ESP32 boards
Posted: 20 Mar 2018, 20:18
by BertB
karl222 wrote: ↑20 Mar 2018, 17:47
I am coming closer
thx
karl
Try to remove the baud part. it causes problems here.
In my Win10 pc I entered D:\Program Files\Python\Python36>python esptool-master\esptool.py --chip esp32 --port COM5 write_flash --flash_freq 40m --flash_mode dio -z 0x1000 D:\Tools\uPython\upyeasy-esp32\upyeasy_v021_2.bin
The ESP is getting programmed, but I still have this continuous loop.
Re: ESP32 boards
Posted: 20 Mar 2018, 20:31
by AndrewJ
I am coming closer
thx
karl
Hi Karl,
Interested to hear you've received the esp32 wrover module. Could you post a link to the one you have, please?
When you say the command "esptool.py.........4096.bin" doesn't work, what exactly happens - do you see any error messages? These may make it easier to help.
Some thoughts/ideas in the meantime...
- You might need to put "python " in front of esptool.py..... I'm working on Linux now, but I started off on Windows and found that was necessary on my machine.
- I've also hit problems at times with the bit that says "--baud 460800". I even got it to work on one occasion by just leaving this out! Alternatively, you could try a lower speed, 115200.
- I haven't tried yet with the 4096.bin version yet, all my successes until now have been with 2048.bin versions.
Good luck!!
Andrew
Re: ESP32 boards
Posted: 20 Mar 2018, 20:44
by karl222
several attempts, no success:
bullshit, had not plugged in usb cable (but just this time)... will Report shortly...
Re: ESP32 boards
Posted: 20 Mar 2018, 20:49
by karl222
still no success:
E:\esp32>esptool.py --chip esp32 --port COM7 --baud 115200 write_flash --flash_freq 40m --flash_mode dio -z 0x1000 upyeasy_v021_20180218_test_esp32_2048.bin
esptool.py v2.3.2-dev
Connecting........_____....._____....._____....._____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
E:\esp32>esptool.py --chip esp32 --port COM7 --baud 460800 write_flash --flash_freq 40m --flash_mode dio -z 0x1000 upyeasy_v021_20180218_test_esp32_2048.bin
E:\esp32>esptool.py --chip esp32 --port COM7 write_flash --flash_freq 40m --flash_mode dio -z 0x1000 upyeasy_v021_20180218_test_esp32_2048.bin
Re: ESP32 boards
Posted: 20 Mar 2018, 20:56
by karl222
Re: ESP32 boards
Posted: 20 Mar 2018, 21:06
by karl222
Breakthrough!
googling here and googling there... you have to press the boot button before you plug the esp32 in to usb and Keep it pressed. then start Flash sequence and tataaaaa, flashing runs through easily
Connecting....
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0220
Compressed 1146384 bytes to 688849...
Wrote 1146384 bytes (688849 compressed) at 0x00001000 in 64.9 seconds (effective 141.3 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
Re: ESP32 boards
Posted: 20 Mar 2018, 21:07
by karl222
aaaaargh, bootloop.... damn!
rst:0x10 (RTCWDT_RTC_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
same problem with the 4MB version....
Re: ESP32 boards
Posted: 20 Mar 2018, 22:44
by AndrewJ
That looks similar to one I have just ordered, but mine is from AlliExpress. I'll be interested to see how yours goes!
Andrew
Re: ESP32 boards
Posted: 20 Mar 2018, 22:47
by karl222
it does not go, thats the problem
Re: ESP32 boards
Posted: 20 Mar 2018, 22:49
by AndrewJ
karl222 wrote: ↑20 Mar 2018, 22:47
Ah, sorry, didn't realise that was the same board with the problem.
Oh well, it may be a wasted purchase! Let's hope we can find a solution.
Re: ESP32 boards
Posted: 21 Mar 2018, 20:00
by LisaM
Found it!
It's a building firmware bug, fixed it!
I've uploaded two new versions into the
https://github.com/letscontrolit/uPyEas ... s/tag/BETA section, can you download the 4096 version and try it again? If it doesn't work, you can try the 2048 version.
esptool.py --chip esp32 --port COM7 --baud 460800 write_flash --flash_freq 40m --flash_mode dio --flash_size 2MB -z 0x1000 upyeasy_v021_20180321_test_esp32_4096.bin
Cheers,
Lisa
Re: ESP32 boards
Posted: 21 Mar 2018, 21:14
by raptor
Hi, karl222! I was able to build and deploy firmware following the instructions. I've little problems, but now seems ok.
You can see my post here:
http://www.letscontrolit.com/forum/view ... =23&t=3903
I hope this my post helps you.
Re: ESP32 boards
Posted: 21 Mar 2018, 21:27
by LisaM
Hi, see my changed remark above:
I've uploaded two new versions into the https://github.com/letscontrolit/uPyEas ... s/tag/BETA section, can you download the 4096 version and try it again? If it doesn't work, you can try the 2048 version.
Cheers,
Lisa
Re: ESP32 boards
Posted: 21 Mar 2018, 21:29
by LisaM
The build & deploy doesn't change, it's only my 'how to get the damn binary to github script which was pulling the wrong binary...'
Ps. i'm happy the guide worked for you!
Cheers,
Lisa
Re: ESP32 boards
Posted: 21 Mar 2018, 21:49
by raptor
You are right, Lisa - build & deploy doesn't change. The problem must by in his custom makefile which overrides some variables from Makefile.
Re: ESP32 boards
Posted: 21 Mar 2018, 21:54
by LisaM
raptor wrote: ↑21 Mar 2018, 21:49
No, it's my fault. The new binaries in the
https://github.com/letscontrolit/uPyEasy/releases section should not have this reboot problem.
Re: ESP32 boards
Posted: 21 Mar 2018, 22:15
by BertB
It is not looping anymore.
But now I get this:
load:0x3fff0018,len:4
load:0x3fff001c,len:4364
load:0x40078000,len:0
load:0x40078000,len:10992
entry 0x4007a6c4
W (65) rtc_clk: Potentially bogus XTAL frequency: 35 MHz, guessing 40 MHz
I (447) cpu_start: Pro cpu up.
I (447) cpu_start: Single core mode
I (448) heap_init: Initializing. RAM available for dynamic allocation:
I (451) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (457) heap_init: At 3FFDCDD0 len 00003230 (12 KiB): DRAM
I (463) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (470) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (476) heap_init: At 4009005C len 0000FFA4 (63 KiB): IRAM
I (482) cpu_start: Pro cpu start user code
I (53) cpu_start: Starting scheduler on PRO CPU.
File "_boot.py", line 10, in <module>
File "inisetup.py", line 28, in setup
File "inisetup.py", line 6, in check_bootsec
File "flashbdev.py", line 13, in readblocks
OSError: [Errno 5] EIO
OSError: [Errno 1] EPERM
MicroPython v1.9.3-255-g979c688-dirty on 2018-03-21; ESP32 module with ESP32
Type "help()" for more information.
>>> import upyeasy
I (21537) modsocket: Initializing
>>> upyeasy.setwifi('xxxxxxxxxx', 'xxxxxxxx')
File "<stdin>", line 1, in <module>
File "upyeasy/__init__.py", line 29, in setwifi
File "upyeasy/utils.py", line 39, in setwifi
File "upyeasy/db.py", line 87, in getrow
File "filedb.py", line 91, in get
OSError: [Errno 19] ENODEV
Re: ESP32 boards
Posted: 21 Mar 2018, 22:32
by LisaM
BertB wrote: ↑21 Mar 2018, 22:15
But now I get this:
entry 0x4007a6c4
>>> import upyeasy
>>> upyeasy.setwifi('xxxxxx', 'xxxxxxxxxxxJ')
Bert, your wifi password is in there...
Did you use the 4096 or 2048 version?
If you used the 4096 version, can you also try using the 2048 version? It sounds like a flash drive error to me.
Re: ESP32 boards
Posted: 21 Mar 2018, 22:35
by BertB
I am getting tired ... thanks.
Ehm, I tried both.
Re: ESP32 boards
Posted: 21 Mar 2018, 22:38
by BertB
It is also impossible to use ampy to upload main.py
D:\Program Files\Python\Python36>ampy --port COM6 put D:\Tools\uPython\main.py
File "d:\program files\python\python36\lib\runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "d:\program files\python\python36\lib\runpy.py", line 85, in _run_code
exec(code, run_globals)
File "D:\Program Files\Python\Python36\Scripts\ampy.exe\__main__.py", line 9, in <module>
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 722, in __call__
return self.main(*args, **kwargs)
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 697, in main
rv = self.invoke(ctx)
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 1066, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 895, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 535, in invoke
return callback(*args, **kwargs)
File "d:\program files\python\python36\lib\site-packages\ampy\cli.py", line 213, in put
board_files.put(remote, infile.read())
File "d:\program files\python\python36\lib\site-packages\ampy\files.py", line 137, in put
self._pyboard.exec_("f = open('{0}', 'wb')".format(filename))
File "d:\program files\python\python36\lib\site-packages\ampy\pyboard.py", line 265, in exec_
raise PyboardError('exception', ret, ret_err)
ampy.pyboard.PyboardError: ('exception', b'', b'Traceback (most recent call last):\r\n File "<stdin>", line 1, in <module>\r\nOSError: [Errno 1] EPERM\r\n')
Re: ESP32 boards
Posted: 21 Mar 2018, 23:00
by LisaM
BertB wrote: ↑21 Mar 2018, 22:38
No need to upload main.py! Main.py is 'frozen', meaning it's part of the firmware.
Using 'import upyeasy' loads the uPyEasy module (which include main.py) into memory and 'upyeasy.main()' runs upyEasy.
Re: ESP32 boards
Posted: 22 Mar 2018, 08:30
by karl222
uiuiui, still a long way to go...
i’ll give it a try in the evening....
karl
Re: ESP32 boards
Posted: 22 Mar 2018, 11:47
by raptor
Hello, Lisa
The connection to my router is successful, but when i make request to 192.168.100.3 from my browser it tells me that is unable to connect.
This is what I got:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
load:0x3fff001c,len:4416
ho 0 tail 12 room 4
load:0x40078000,len:11816
entry 0x4007a9fc
I (265) cpu_start: Pro cpu up.
I (265) cpu_start: Single core mode
I (265) heap_init: Initializing. RAM available for dynamic allocation:
I (269) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (275) heap_init: At 3FFC4E80 len 0001B180 (108 KiB): DRAM
I (281) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (288) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (294) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (300) cpu_start: Pro cpu start user code
I (20) cpu_start: Starting scheduler on PRO CPU.
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-473-g22c693a-dirty on 2018-03-21; ESP32 module with ESP32
import upyeasy
I (19363) modsocket: Initializing
import network
station = network.WLAN(network.STA_IF)
I (86893) wifi: wifi firmware version: ebd3e5d
I (86893) wifi: config NVS flash: enabled
I (86893) wifi: config nano formating: disabled
I (86893) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (86903) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (86923) wifi: Init dynamic tx buffer num: 32
I (86923) wifi: Init data frame dynamic rx buffer num: 64
I (86923) wifi: Init management frame dynamic rx buffer num: 64
I (86933) wifi: wifi driver task: 3ffcaf40, prio:23, stack:4096
I (86933) wifi: Init static rx buffer num: 10
I (86943) wifi: Init dynamic rx buffer num: 0
I (86943) wifi: wifi power manager task: 0x3ffcfb90 prio: 21 stack: 2560
I (87013) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
I (87013) wifi: mode : null
station.active(True)
I (98793) wifi: mode : sta (30:ae:a4:04:80:30)
I (98793) wifi: STA_START
True
station.connect("my_ssid", "my_pass")
>>> I (132043) wifi: n:10 0, o:1 0, ap:255 255, sta:10 0, prof:1
I (132603) wifi: state: init -> auth (b0)
I (132603) wifi: state: auth -> assoc (0)
I (132613) wifi: state: assoc -> run (10)
I (132673) wifi: connected with OpenWrt2, channel 10
I (132673) network: event 4
I (133893) event: sta ip: 192.168.100.3, mask: 255.255.255.0, gw: 192.168.100.1
I (133893) network: GOT_IP
I (135613) wifi: pm start, type:0
print('network config:', station.ifconfig())
network config: ('192.168.100.3', '255.255.255.0', '192.168.100.1', '192.168.100.1')
station.isconnected()
True
I've got ping to 192.168.100.3, but seems web server isn't working.
What I'm missing?
Re: ESP32 boards
Posted: 22 Mar 2018, 15:48
by LisaM
raptor wrote: ↑22 Mar 2018, 11:47
Hello, Lisa
This is what I got:
What I'm missing?
It's working, cool!
The webserver doesn't work, because you're only connected to the wifi (which doesn't include a webserver).
To run uPyEasy:
>>> import upyeasy
>>> upyeasy.main()
Part of the uPyEasy module is a fully functional webserver, so you should be able to connect now...
Cheers,
Lisa
Re: ESP32 boards
Posted: 22 Mar 2018, 22:15
by raptor
Lisa, you are great
Thank you, very much for your help! I have working ESP32 module with uPyEasy firmware. I will be glad to help in developing and popularization of this great firmware
Re: ESP32 boards
Posted: 22 Mar 2018, 22:42
by karl222
yep, Installation was successful:
rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
entry 0x4007a6c4
I (442) cpu_start: Pro cpu up.
I (442) cpu_start: Single core mode
I (443) heap_init: Initializing. RAM available for dynamic allocation:
I (446) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (452) heap_init: At 3FFDCDD0 len 00003230 (12 KiB): DRAM
I (458) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (464) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (471) heap_init: At 4009005C len 0000FFA4 (63 KiB): IRAM
I (477) cpu_start: Pro cpu start user code
I (47) cpu_start: Starting scheduler on PRO CPU.
BUT, I can't set wifi Parameters accordingly via Python window:
>>> upyeasy.setwifi('xxxxx', 'yyyyyyy')
NameError: name 'upyeasy' is not defined
even when I do this, it doesn't work:
>>> import upyeasy
ModuleNotFoundError: No module named 'upyeasy'
Any Ideas?
thx
karl
Re: ESP32 boards
Posted: 22 Mar 2018, 22:43
by karl222
LisaM wrote: ↑22 Mar 2018, 15:48
Hello, Lisa
This is what I got:
What I'm missing?
It's working, cool!
To run uPyEasy:
>>> import upyeasy
>>> upyeasy.main()
Cheers,
Lisa
How can the webserver be started via autostart? what is the reason behind the logic of being startet not automatically?
thx
karl
Re: ESP32 boards
Posted: 22 Mar 2018, 23:14
by BertB
I followed all the steps of Raptor, no success:
entry 0x4007a6c4
NameError: name 'station' is not defined
>>> import upyeasy
I (51960) modsocket: Initializing
>>> import network
I (66090) wifi: wifi firmware version: 111e74d
I (66090) wifi: config NVS flash: enabled
I (66090) wifi: config nano formating: disabled
I (66100) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (66120) wifi: Init dynamic tx buffer num: 32
I (66120) wifi: Init data frame dynamic rx buffer num: 64
I (66120) wifi: Init management frame dynamic rx buffer num: 64
I (66130) wifi: wifi driver task: 3ffddfb0, prio:23, stack:4096
I (66140) wifi: Init static rx buffer num: 10
I (66140) wifi: Init dynamic rx buffer num: 0
I (66140) wifi: Init rx ampdu len mblock:7
I (66150) wifi: Init lldesc rx ampdu entry mblock:4
I (66150) wifi: wifi power manager task: 0x3ffe85b4 prio: 21 stack: 2560
I (66180) phy: phy_version: 362.0, 61e8d92, Sep 8 2017, 18:48:11, 0, 0
I (66180) wifi: mode : null
I (75420) wifi: mode : sta (30:ae:a4:22:e8:1c)
I (75420) wifi: STA_START
True
>>> station.connect("xxxxxxx", "xxxxxxxxx")
>>> I (109500) wifi: n:7 1, o:1 0, ap:255 255, sta:7 1, prof:1
I (110060) wifi: state: init -> auth (b0)
I (110060) wifi: state: auth -> assoc (0)
I (110070) wifi: state: assoc -> run (10)
I (110080) wifi: connected with xxxxxxxx, channel 7
I (110080) network: event 4
I (110950) event: sta ip: -------------, mask: 255.255.255.0, gw: -----------
I (110950) network: GOT_IP
I (113070) wifi: pm start, type:0
network config: ('------------', '255.255.255.0', '----------', '-----------')
True
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
2000-01-01T00:02:17.005 [debug] uPyEasy: Init: Init constructor
2000-01-01T00:02:17.005 [debug] uPyEasy: Init: Entering init
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create directory config
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create directory config exception: OSError(17,)
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create directory plugins
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory plugins exception: OSError(17,)
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory protocols
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory protocols exception: OSError(17,)
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory scripts
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory scripts exception: OSError(17,)
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory rules
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory rules exception: OSError(17,)
2000-01-01 00:02:18 [debug] uPyEasy: Init: config Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: network Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: protocol Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: controller Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: hardware Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: dxpin Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: dxmap Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: plugin Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: pluginstore Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: device Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: service Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: notification Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: advanced Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: script Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: rule Table
File "upyeasy/__init__.py", line 40, in main
File "upyeasy/init.py", line 158, in init
File "upyeasy/db.py", line 43, in public
File "upyeasy/db.py", line 1, in <listcomp>
Re: ESP32 boards
Posted: 23 Mar 2018, 00:07
by LisaM
@karl222 @bertb
The errors in your log:
means that the flashdrive could not be initialized, so that the database isn't build (no dir) and upyeasy fails. Did you flash the 2048 or the 4096 version?
Re: ESP32 boards
Posted: 23 Mar 2018, 17:10
by BertB
This is the sequence with the 2048 bin.
entry 0x4007a6c4
>>> import upyeasy
I (19590) modsocket: Initializing
ets_main.c 371
entry 0x4007a6c4
I (465) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (48) cpu_start: Starting scheduler on PRO CPU.
>>> import upyeasy
I (86063) modsocket: Initializing
>>> import network
IndentationError: unexpected indent
I (149973) wifi: wifi firmware version: 111e74d
I (149973) wifi: config NVS flash: enabled
I (149973) wifi: config nano formating: disabled
I (149973) system_api: Base MAC address is not set, read default base MAC addres s from BLK0 of EFUSE
I (149983) system_api: Base MAC address is not set, read default base MAC addres s from BLK0 of EFUSE
I (150003) wifi: Init dynamic tx buffer num: 32
I (150003) wifi: Init data frame dynamic rx buffer num: 64
I (150003) wifi: Init management frame dynamic rx buffer num: 64
I (150013) wifi: wifi driver task: 3ffe15f4, prio:23, stack:4096
I (150023) wifi: Init static rx buffer num: 10
I (150023) wifi: Init dynamic rx buffer num: 0
I (150023) wifi: Init rx ampdu len mblock:7
I (150033) wifi: Init lldesc rx ampdu entry mblock:4
I (150033) wifi: wifi power manager task: 0x3ffe8508 prio: 21 stack: 2560
W (150043) phy_init: failed to load RF calibration data (0x1102), falling back t o full calibration
I (150203) phy: phy_version: 362.0, 61e8d92, Sep 8 2017, 18:48:11, 0, 2
I (150213) wifi: mode : null
I (166333) wifi: mode : sta (30:ae:a4:22:e8:1c)
I (166333) wifi: STA_START
True
>>> station.connect("xxxxx", "xxxxxx"
>>> I (207423) wifi: n:7 1, o:1 0, ap:255 255, sta:7 1, prof:1
I (207983) wifi: state: init -> auth (b0)
I (207983) wifi: state: auth -> assoc (0)
I (207993) wifi: state: assoc -> run (10)
I (208003) wifi: connected with Spoon, channel 7
I (208003) network: event 4
I (208673) event: sta ip: xxxxxxxxx, mask: xxxxx, gw: xxxxxxx
I (208673) network: GOT_IP
I (210993) wifi: pm start, type:0
network config: (xxxxxxxx', 'xxxxxxxxx', 'xxxxxxxx', 'xxxxxxxxxxx')
True
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
2000-01-01T00:03:50.005 [debug] uPyEasy: Init: Init constructor
2000-01-01T00:03:50.005 [debug] uPyEasy: Init: Entering init
2000-01-01 00:03:50 [debug] uPyEasy: Init: Create directory config
2000-01-01 00:03:50 [debug] uPyEasy: Init: Create directory plugins
2000-01-01 00:03:50 [debug] uPyEasy: Init: Create directory protocols
2000-01-01 00:03:50 [debug] uPyEasy: Init: Create directory scripts
2000-01-01 00:03:51 [debug] uPyEasy: Init: Create directory rules
2000-01-01 00:03:51 [debug] uPyEasy: Init: config Table
2000-01-01 00:03:51 [debug] uPyEasy: Init: network Table
2000-01-01 00:03:52 [debug] uPyEasy: Init: protocol Table
2000-01-01 00:03:52 [debug] uPyEasy: Init: controller Table
2000-01-01 00:03:52 [debug] uPyEasy: Init: hardware Table
2000-01-01 00:03:52 [debug] uPyEasy: Init: dxpin Table
2000-01-01 00:03:53 [debug] uPyEasy: Init: dxmap Table
2000-01-01 00:03:53 [debug] uPyEasy: Init: plugin Table
2000-01-01 00:03:53 [debug] uPyEasy: Init: pluginstore Table
2000-01-01 00:03:53 [debug] uPyEasy: Init: device Table
2000-01-01 00:03:54 [debug] uPyEasy: Init: service Table
2000-01-01 00:03:54 [debug] uPyEasy: Init: notification Table
2000-01-01 00:03:54 [debug] uPyEasy: Init: advanced Table
2000-01-01 00:03:55 [debug] uPyEasy: Init: script Table
2000-01-01 00:03:55 [debug] uPyEasy: Init: rule Table
2000-01-01 00:03:55 [debug] uPyEasy: Init: Create Config Record
2000-01-01 00:03:56 [debug] uPyEasy: Init: Create Network Record
2000-01-01 00:03:56 [debug] uPyEasy: Init: Create Hardware Record
2000-01-01 00:03:56 [debug] uPyEasy: Hal: hardwaredb init
2000-01-01 00:03:56 [debug] uPyEasy: Hal: hardwaredb esp32
2000-01-01 00:03:56 [debug] uPyEasy: Init: Create dxpin Record
2000-01-01 00:03:57 [debug] uPyEasy: Hal: dxpins_init
2000-01-01 00:03:57 [debug] uPyEasy: Hal: dxpins_init esp32
2000-01-01 00:03:57 [debug] uPyEasy: Init: Create advanced Record
2000-01-01 00:03:58 [debug] uPyEasy: Hal: Init
2000-01-01 00:03:58 [debug] uPyEasy: Hal: init, network record present
2000-01-01 00:03:58 [debug] uPyEasy: Hal: esp32
2000-01-01 00:03:58 [debug] uPyEasy: Hal: esp32, ssid empty
I (256873) network: event 1
2000-01-01 00:04:00 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Spoon Strengt h: -73 dBm Security: 3
2000-01-01 00:04:00 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Lepelke Stren gth: -77 dBm Security: 3
2000-01-01 00:04:00 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: torenvalk Str ength: -90 dBm Security: 3
2000-01-01 00:04:00 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Ziggo9D8234B Strength: -91 dBm Security: 3
2000-01-01 00:04:01 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Ziggo Strengt h: -91 dBm Security: 5
2000-01-01 00:04:01 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Ziggo Strengt h: -93 dBm Security: 5
2000-01-01 00:04:01 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: HZN240406906 Strength: -93 dBm Security: 3
2000-01-01 00:04:01 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: CelenoInitial AP8A186F Strength: -94 dBm Security: 3
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Load
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Init protocol records
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Load protocol domoticz_mqtt
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Create protocol Record: domoticz _mqtt
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Load protocol domoticz_http
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Create protocol Record: domoticz _http
2000-01-01 00:04:02 [debug] uPyEasy: Protocols: Init protocol records, run async loop
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: Load
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: init plugin records
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: Register frozen plugin switch
2000-01-01 00:04:02 [debug] uPyEasy: Plugin: switch contruction
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: Create frozen plugin Record: switc h
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: Register frozen plugin bme280
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Create frozen plugin Record: bme28 0
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Register frozen plugin test
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Create frozen plugin Record: test
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Register frozen plugin ds18
2000-01-01 00:04:03 [debug] uPyEasy: Plugin: ds18 contruction
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Create frozen plugin Record: ds18
2000-01-01 00:04:04 [debug] uPyEasy: Plugins: Init plugin records, run async loo p
2000-01-01 00:04:04 [debug] uPyEasy: Init: Init devices
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: Load
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: Init
2000-01-01 00:04:04 [debug] uPyEasy: Plugins: GetQueue
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: init scripts records
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: init rules records
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: Init script/rule records, run asyn c loop
2000-01-01 00:04:04 [debug] uPyEasy: Utils: Sys hostname
2000-01-01 00:04:05 [debug] uPyEasy: Utils: uPyEasy Name
Set syslog hostname 0.0.0.0
reloaded sink syslog
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Entering SetTime
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Entering GetNtpTime
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: network Table
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Using NTP Hostname: pool.ntp.o rg
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: TimeZome offset: 60
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Received UTC NTP Time: 5751363 35
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Timezone corrected NTP Time: 5 75139935
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: DST corrected NTP Time: 575139 935
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Received NTP Time: 575139935
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: StartTime: 575139935
2018-03-23 17:05:35 [debug] uPyEasy-uPyEasy: Set time: 2018-03-23T17:05:35
Exiting: Network not available, set network values!
>>> upyeasy.setwifi('xxxxxxxxxxx','xxxxxxxxxxxxx')
File "upyeasy/utils.py", line 46, in setwifi
File "filedb.py", line 73, in update
Re: ESP32 boards
Posted: 23 Mar 2018, 18:18
by LisaM
@bertb: and now a reboot and only do:
>>> import upyeasy
>>> upyeasy.main()
Still a network not found error?
Ps. Thx! line 46 of utils.py had a bug! It stated
db.configTable.update({"timestamp":network['timestamp']},port = wport)
But it should have been:
db.configTable.update({"timestamp":config['timestamp']},port = wport)
Found it due to the micropython error trail!
Re: ESP32 boards
Posted: 23 Mar 2018, 18:49
by BertB
Great, it runs.
But ...
First I added the BME280. That went good.
Znd then, when I ad a DS18B20 device, the interface looses connection and this is the trace:
stack: 2032 out of 15360
GC: total: 96000, used: 90224, free: 5776
No. of 1-blocks: 1468, 2-blocks: 179, max blk sz: 902, max free sz: 360
575145912.170 <HTTPRequest object at 3ffc9250> <StreamWriter <socket>> "POST /device_setting?id=0"
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: Pages: Entering Device Settings Page
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: Pages: POST
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: id
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: 0
2018-03-23 18:44:50 [debug] uPyEasy-uPyEasy: New Plugin: 4
2018-03-23 18:44:50 [debug] uPyEasy-uPyEasy: Pages: Create Device
2018-03-23 18:44:50 [debug] uPyEasy-uPyEasy: Pages: New Device and plugin choosen: 4
2018-03-23 18:44:50 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-23 18:44:51 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy with plugin: 4
2018-03-23 18:44:51 [debug] uPyEasy-uPyEasy: Protocols: GetQueue controller 192.168.0.243-Domoticz HTTP-1
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy ,instantiate plugin: DS18B20
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugin: ds18 init
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugins: Read device store: dummy
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugin: ds18 init, pin used:
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Hal: pin =
575145912.170 <HTTPRequest object at 3ffc9250> <StreamWriter <socket>> AttributeError("'NoneType' object has no attribute 'init'",)
File "picoweb/__init__.py", line 186, in _handle
File "upyeasy/pages.py", line 1249, in devicesettingpage
File "upyeasy/plugin.py", line 118, in initdevice
File "upyeasy/plugins/ds18.py", line 84, in init
File "onewire.py", line 17, in __init__
AttributeError: 'NoneType' object has no attribute 'init'
After that I rebooted and tried it again with the DS18B20 and it worked.
Re: ESP32 boards
Posted: 23 Mar 2018, 19:41
by BertB
having said that, There still is no automatic update of the devices and no value is written to Domoticz.
Re: ESP32 boards
Posted: 23 Mar 2018, 20:27
by karl222
LisaM wrote: ↑23 Mar 2018, 00:07
@karl222 @bertb
hi,
have tried it with both files, both sShow the same issues... still not running...
I don't know what to do with BertB's findings... I would love to see a working .bin
regards
karl
