Hello, again! I've now succeeded in building and flashing uPyEasy on ESP32 WROOM. The problem was in description of how to fetch esp-idf:
$ git clone
https://github.com/espressif/esp-idf.git
$ git checkout <Current supported ESP-IDF commit hash>
$ git submodule update –recursive
The right commands according to
http://esp-idf.readthedocs.io/en/latest ... et-esp-idf is:
git clone --recursive
cd esp-idf/
git submodule update --recursive
Current supported ESP-IDF commit hash can be seen in /home/ivanov/micropython/ports/esp32/Makefile. In this case is 3ede9f011b50999b0560683f9419538c066dd09e.
My makefile in /home/ivanov/micropython/ports/esp32/ is:
ESPIDF = $(HOME)/esp-idf
PORT = /dev/ttyUSB0
BAUD = 115200
FLASH_MODE = dio
FLASH_SIZE = 4MB
CROSS_COMPILE = xtensa-esp32-elf-
include Makefile
After successful building and deploying I get
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-473-g22c693a-dirty on 2018-03-21; ESP32 module with ESP32
Type "help()" for more information.
>>> help()
This mean that main.py is missing and I must to create it manually like here:
https://github.com/micropython/micropyt ... /issues/90
>>> f = open("main.py", "w")
>>> f.write("print(\"main.py: Hello\")\n")
24
>>> f.close()
Then restart and voila:
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4416
ho 0 tail 12 room 4
load:0x40078000,len:0
load:0x40078000,len:11816
entry 0x4007a9fc
I (265) cpu_start: Pro cpu up.
I (265) cpu_start: Single core mode
I (265) heap_init: Initializing. RAM available for dynamic allocation:
I (269) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (275) heap_init: At 3FFC4E80 len 0001B180 (108 KiB): DRAM
I (281) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (287) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (294) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (300) cpu_start: Pro cpu start user code
I (20) cpu_start: Starting scheduler on PRO CPU.
main.py: Hello
