Same devices - same codes?
jiran
#1 Post by jiran » 16 Nov 2017, 12:22
HI. I have 3 the same motion sensor. Each of them sends little bit different codes (8 codes in single broadcasting, 4 are the same other little bit different. I use entered those commands:
10;RFFind;0;xxxxxx;B;xx;1;
10;RFFind;0;xxxyxx;B;xx;1;
10;RFFind;0;xxxxyx;B;xx;1;
But after I want to let show using 10;rfshow; which codes rflink learned it shows only single code.
I have arduino connected to raspberry via USB but it sends the same device code for all motion sensors. How could I change those remembered device codes to be sent to raspberry under different codes?
Stuntteam
Site Beheer
Re: Same devices - same codes?
#2 Post by Stuntteam » 18 Nov 2017, 00:35
The 0 in your command is the record number you are writing to.
Thus you write 3 times to the same record..
Result: you have 1 record.
