Hi!
First of all I like to thank you for your work with RFlink! I like it very much and use it with Domoticz.
I recently bought a cheap RF433-controlled 12V dimmer, like this :
https://www.lightinthebox.com/sv/tradlo ... 1.50.198.0
It has three buttons (one on/off switch, one dim-up and one dim-down).
The on/off button, domoticz adds as a on/off switch that can be used, sending "10;TriState;0aaaa1;3;ON" or "10;TriState;0aaaa1;3;OFF” does not matter witch, it will just toggle the dimmer.
The dimmer buttons though does not get properly recognised.
Here is the RF-link(R48) debug output when pressing the buttons:
ON/OFF (just sending OFF-commands):
2017-11-09 22:06:49.280 RFLink: 20;ED;DEBUG;Pulses=50;Pulses(uSec)=240,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,180,780,750,210,780,210,180,780,180,780,180,780,180,780,180,6990;
2017-11-09 22:06:49.286 RFLink: 20;EE;TriState;ID=0aaaa1;SWITCH=3;CMD=OFF;
2017-11-09 22:06:49.289 (RFLink433) Light/Switch (LED-Dimmer-switch1)
2017-11-09 22:06:49.391 RFLink: 20;EF;DEBUG;Pulses=50;Pulses(uSec)=270,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,810,780,210,180,780,780,210,180,780,180,780,750,210,780,210,180,810,180,780,180,780,180,780,180,6990;
DIM-DOWN Button:
20;DC;DEBUG;Pulses=50;Pulses(uSec)=240,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,180,780,180,780,180,780,750,210,780,210,180,780,180,780,180,6990;
2017-11-09 22:15:21.220 RFLink: 20;DD;TriState;ID=0aaaa0;SWITCH=10;CMD=OFF;
2017-11-09 22:15:21.224 (RFLink433) Light/Switch (Unknown)
2017-11-09 22:15:21.325 RFLink: 20;DE;DEBUG;Pulses=50;Pulses(uSec)=240,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,180,780,180,780,180,780,750,210,780,210,180,780,180,780,180,6990;
2017-11-09 22:15:21.400 RFLink: 20;DF;DEBUG;Pulses=50;Pulses(uSec)=210,750,750,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,180,780,180,780,180,780,750,210,780,210,180,780,180,780,180,6990;
2017-11-09 22:15:21.475 RFLink:
DIM-UP Button:
2017-11-09 22:28:30.717 RFLink: 20;44;DEBUG;Pulses=50;Pulses(uSec)=240,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,180,780,180,780,180,780,180,780,180,780,750,210,780,210,180,6990;
2017-11-09 22:28:30.722 RFLink: 20;45;AB400D;ID=41;SWITCH=7;CMD=ON;
2017-11-09 22:28:30.725 (RFLink433) Light/Switch (Unknown)
2017-11-09 22:28:30.827 RFLink: 20;46;DEBUG;Pulses=50;Pulses(uSec)=270,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,180,780,180,780,180,780,180,780,180,780,750,210,780,210,180,6990;
2017-11-09 22:28:30.902 RFLink: 20;47;DEBUG;Pulses=50;Pulses(uSec)=240,720,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,780,210,180,780,180,780,180,780,180,780,180,780,180,780,750,210,780,210,180,6990;
2017-11-09 22:28:30.976 RFLink:
You think its possible to have the RFlink decode this properly?
Kind regards,
Jacob Gårder
Environment is:
RFlink R48 on Mega with Aurel 433Mhz chip
Domoticz 3.8373 on RPi v3 running stretch
LEDstrip 12V dimmer
