433 Mhz and 868 Mhz with the same Arduino
About receivers, transmitters, transceivers, connections, antennas etc.
jit
#1 Post by jit » 01 Oct 2017, 23:25
I'm just discovering RFlink and playing with all my 433 Mhz devices, it works very well ;)
I'm planning to also use it for my X2D devices which are in 868 Mhz. I'am under the impression that I should wait a bit for the cc1101 support... ok I can wait !
But I have two questions :
- Will it be possible to make it works together with a RXB6 and a XD-FST FS1000A on the same Arduino Mega ?
- What is the model of cc1101 module are you using for your development (so I could order one in advance) ?
ArnoM91
Re: 433 Mhz and 868 Mhz with the same Arduino
#2 Post by ArnoM91 » 09 Feb 2019, 21:16
I am also interested in havong both 433MHz and 868MHz protocols working on the same Arduino.
Does someone have tips to build it ?
Thank you
Arno
