EspEasy restore config.dat rules1.txt using script
Posted: 19 Sep 2017, 14:56
by ensingg
I made a (powershell) script dat backups all the settings from the esp8266's in my network and zip it to a daily package.
But now I like to change a rules1.txt using that script and put it back to the espeasy.
Is it possible to do an upload of a rules1.txt (or other) to the esp using HTTP url commands?
Re: EspEasy restore config.dat rules1.txt using script
Posted: 19 Sep 2017, 17:25
by grovkillen
Posted: 30 Sep 2017, 20:22
by elmicha
You can upload files using
curl:
curl --form "file=@rules1.txt" http://esp_easy_1/upload
Posted: 01 Oct 2017, 07:42
by ensingg
Super. Thats working excellent. Thank you.
Posted: 01 Oct 2017, 08:29
by papperone
ensingg would you mind to share your script?
Powershell Backup script for ESP
Posted: 01 Oct 2017, 10:03
by ensingg
This is the Windows powershell script I created for home use. It will backup all configuration files of the espeasy in a folder (see end of script) and zip it together.
The code can probably optimized. But works.
.Synopsis
Short description
.DESCRIPTION
Long description
.EXAMPLE
Example of how to use this cmdlet
.EXAMPLE
Another example of how to use this cmdlet
function Export-ESPSettings
[CmdletBinding()]
[Alias()]
[OutputType([int])]
Param
# Param1 help description
[Parameter(Mandatory=$true,
ValueFromPipelineByPropertyName=$true,
Position=0)]
$Hostname,
# Param2 help description
$OutputDir
Begin
remove-item $OutputDir"config.dat"
remove-item $OutputDir"security.dat"
remove-item $OutputDir"rules1.txt"
remove-item $OutputDir"rules2.txt"
remove-item $OutputDir"rules3.txt"
remove-item $OutputDir"rules4.txt"
remove-item $OutputDir"esp.css"
Process
Invoke-WebRequest -uri "http://$hostname/config.dat" -outfile $outputdir"config.dat"
Invoke-WebRequest -uri "http://$hostname/security.dat" -outfile $outputdir"security.dat"
Invoke-WebRequest -uri "http://$hostname/rules1.txt" -outfile $outputdir"rules1.txt"
Invoke-WebRequest -uri "http://$hostname/rules2.txt" -outfile $outputdir"rules2.txt"
Invoke-WebRequest -uri "http://$hostname/rules3.txt" -outfile $outputdir"rules3.txt"
Invoke-WebRequest -uri "http://$hostname/rules4.txt" -outfile $outputdir"rules4.txt"
Invoke-WebRequest -uri "http://$hostname/esp.css" -outfile $outputdir"esp.css"
End
$Hostn=$hostname.replace(".","")
compress-archive -path $OutputDir"config.dat" -DestinationPath ($OutputDir + $hostn +"_" + (get-date -Format yyyyMMddHHmm) + '.zip')
compress-archive -path $OutputDir"security.dat" -update -DestinationPath ($OutputDir+ $hostn +"_" + (get-date -Format yyyyMMddHHmm) + '.zip')
compress-archive -path $OutputDir"rules1.txt" -update -DestinationPath ($OutputDir + $hostn +"_" + (get-date -Format yyyyMMddHHmm) + '.zip')
compress-archive -path $OutputDir"rules2.txt" -update -DestinationPath ($OutputDir + $hostn +"_" + (get-date -Format yyyyMMddHHmm) + '.zip')
compress-archive -path $OutputDir"rules3.txt" -update -DestinationPath ($OutputDir + $hostn +"_" + (get-date -Format yyyyMMddHHmm) + '.zip')
compress-archive -path $OutputDir"rules4.txt" -update -DestinationPath ($OutputDir + $hostn +"_" + (get-date -Format yyyyMMddHHmm) + '.zip')
compress-archive -path $OutputDir"esp.css" -update -DestinationPath ($OutputDir + $hostn +"_" + (get-date -Format yyyyMMddHHmm) + '.zip')
$pad="c:\backup\esp\"
Export-ESPSettings -Hostname "192.168.0.10" -OutputDir $pad
Export-ESPSettings -Hostname "192.168.0.20" -OutputDir $pad
