Hi Guys
I'm looking for control my fireplace remotely with RFlink, I own an RFlink V1.1 in 433MHz unfortunately, Can I change Receivers and Transmitters for 315MHz and hoping he will work with the receiver Maxitrol G6R. If yes
Witch Transmitters will be suitable for the exchange ?
Regards, Vic
Fireplace Mertik G6R-H3T6 controller 315MHz
Re: Fireplace Mertik G6R-H3T6 controller 315MHz
Yes you can swap for 315mhz..
Use something like this:
https://nl.aliexpress.com/item/NEW315mh ... 90214.html
Ok just got my stuff thk free shipping, so after wiring RX pin 19 I got something like this in RFLink loader
When I include it in domoticz he recognize something one device, not sure where he come from
and the device is not updated anymore.
When I play with the remote close the rx nothing happen in domoticz or rflink loader.
Something special to do for the inclusion ?
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
20;01;MySensors=OFF;NO NRF24L01;
20;02;setGPIO=ON;
10;version;
20;03;VER=1.1;REV=48;BUILD=04;
10;status;
20;04;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=ON;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;05;RFDEBUG=ON;
20;06;DEBUG;Pulses=33;Pulses(uSec)=840,30,180,90,690,600,540,210,180,300,240,510,360,360,120,180,30,270,120,630,30,360,90,270,420,450,270,570,120,510,30,390,1320;
20;07;DEBUG;Pulses=26;Pulses(uSec)=60,960,270,900,510,30,330,90,30,3840,90,930,390,1380,60,660,60,870,60,540,4770,5760,90,210,330,90;
20;08;DEBUG;Pulses=46;Pulses(uSec)=60,150,120,2100,1950,210,30,210,180,960,1800,30,30,180,1020,570,90,90,150,30,2070,570,0,510,450,120,270,210,90,150,540,240,210,600,210,90,90,330,120,810,660,5610,930,420,390,1410;
20;09;DEBUG;Pulses=30;Pulses(uSec)=90,1350,1620,30,1590,60,30,0,360,180,690,60,480,90,240,150,2700,2790,270,240,30,3030,210,240,180,420,30,660,30,240;
20;0A;DEBUG;Pulses=38;Pulses(uSec)=390,150,30,270,60,240,150,180,30,1140,180,1560,30,1800,30,1350,1500,90,300,90,1260,390,1710,210,870,30,150,150,4290,390,0,150,210,2160,2220,390,30,1140;
20;0B;DEBUG;Pulses=64;Pulses(uSec)=30,30,180,90,360,3510,2280,60,2310,120,390,30,30,30,1320,90,30,210,1020,60,390,150,630,60,2700,90,210,360,30,420,420,120,90,180,390,1110,0,570,420,270,450,90,210,180,330,240,60,810,120,660,540,1230,90,180,840,630,420,180,30,420,330,300,30,420;
20;0C;DEBUG;Pulses=24;Pulses(uSec)=90,1200,60,270,90,90,120,210,270,2760,270,1200,0,510,30,420,4080,60,990,4950,180,4950,210,6990;
20;0D;DEBUG;Pulses=30;Pulses(uSec)=60,90,30,900,90,420,30,1140,1740,120,0,3570,270,480,30,120,690,1080,30,570,120,900,2220,120,1200,120,600,1140,60,630;
20;0E;DEBUG;Pulses=27;Pulses(uSec)=150,810,780,1020,30,600,90,930,0,330,570,90,240,930,120,1770,30,330,2160,4320,270,3690,120,6120,60,3480,1080;
20;0F;DEBUG;Pulses=36;Pulses(uSec)=270,2280,150,2610,480,1890,60,2400,3240,660,0,150,60,180,90,30,690,150,120,600,30,390,480,120,120,90,570,60,30,180,1080,1740,330,1110,180,60;
20;10;DEBUG;Pulses=35;Pulses(uSec)=420,30,1650,4770,60,3720,90,630,150,450,840,240,90,4740,60,210,150,1080,6630,30,4380,60,750,180,540,180,120,0,450,960,30,1680,180,150,630;
20;11;DEBUG;Pulses=30;Pulses(uSec)=6090,60,270,480,60,60,1290,90,720,180,1140,1800,150,3270,600,90,420,1680,1350,150,360,630,660,60,360,840,90,1980,1680,6990;
20;12;DEBUG;Pulses=28;Pulses(uSec)=390,870,510,240,300,330,0,570,330,3510,930,240,60,750,30,2940,3090,210,390,6390,840,5730,120,960,1050,240,60,1080;
20;13;DEBUG;Pulses=46;Pulses(uSec)=990,60,180,2190,1230,570,30,2580,60,1770,0,30,1860,870,90,2550,30,2760,1170,240,150,270,3030,1050,390,1320,120,5550,420,870,330,330,0,630,0,300,180,3990,330,3360,90,900,3420,330,180,5370;
20;14;DEBUG;Pulses=34;Pulses(uSec)=390,1290,180,60,90,4230,150,900,660,1140,30,690,330,420,3000,990,420,870,570,5760,690,1080,30,3840,630,2160,330,90,30,3090,1860,600,60,120;
20;15;DEBUG;Pulses=32;Pulses(uSec)=840,1020,60,510,210,240,660,630,30,900,870,2880,60,360,0,30,180,390,60,2160,930,930,1440,30,30,1710,1200,1080,210,6300,30,660;
20;16;DEBUG;Pulses=26;Pulses(uSec)=120,180,60,810,90,600,30,1710,150,900,720,1290,30,330,240,750,90,2610,60,690,3480,30,660,600,480,6990;
20;17;DEBUG;Pulses=34;Pulses(uSec)=90,1140,60,6060,120,990,360,1950,90,1050,30,480,90,1440,180,720,570,510,240,360,60,420,90,240,180,2460,1620,6930,300,510,150,420,210,330;
20;18;DEBUG;Pulses=38;Pulses(uSec)=1140,2850,240,1920,60,120,30,1800,30,690,360,240,90,750,30,360,60,180,390,720,300,960,150,810,90,1200,60,870,510,390,390,300,90,120,390,780,2310,6990;
20;19;DEBUG;Pulses=31;Pulses(uSec)=1230,60,1620,450,630,30,1590,30,4830,4230,180,3480,30,3480,2310,210,90,120,180,60,270,120,600,270,120,150,840,60,4890,120,1350;
20;1A;DEBUG;Pulses=27;Pulses(uSec)=90,150,330,1260,570,60,30,990,30,840,900,180,0,30,300,60,4530,3900,450,270,90,2820,240,2910,750,2400,6990;
20;1B;DEBUG;Pulses=30;Pulses(uSec)=180,660,30,300,30,420,180,330,2460,3300,360,3600,90,2070,600,6030,30,930,630,300,840,450,60,240,60,240,30,420,90,120;
20;1C;DEBUG;Pulses=26;Pulses(uSec)=180,120,360,570,570,180,930,330,420,510,30,30,120,1470,330,1650,150,270,30,210,60,540,510,930,30,390;
20;1D;DEBUG;Pulses=86;Pulses(uSec)=120,360,90,1710,300,2550,480,330,60,270,90,300,480,150,120,660,210,540,270,2070,210,390,0,90,1830,1200,90,90,30,2880,60,3000,150,750,120,420,60,60,90,360,120,480,30,1470,30,150,540,510,30,690,0,390,120,210,60,570,600,390,270,1710,120,570,300,300,210,30,1170,1020,480,1410,300,1380,30,150,180,360,30,480,30,1170,300,570,180,600,120,90;
20;1E;DEBUG;Pulses=23;Pulses(uSec)=1500,870,90,240,120,120,90,120,1530,120,450,300,540,120,630,180,1200,90,210,1650,1590,360,90;
20;1F;DEBUG;Pulses=44;Pulses(uSec)=480,60,330,150,180,120,960,330,510,3000,540,30,570,60,780,90,90,1350,2580,5340,150,2970,330,4080,300,5520,240,180,60,2610,5430,660,120,1830,30,570,300,690,330,150,150,1050,930,900;
20;20;DEBUG;Pulses=25;Pulses(uSec)=4950,570,60,90,810,930,120,360,750,360,90,810,30,300,30,960,150,870,690,1110,30,420,4680,3150,90;
20;21;DEBUG;Pulses=50;Pulses(uSec)=150,1500,450,1890,180,270,690,720,360,390,240,90,330,690,60,210,120,90,120,240,90,360,90,540,450,1890,90,570,420,1110,270,720,1470,330,150,1410,60,60,660,690,30,1710,30,1380,30,1230,120,120,240,1770;
10;rfdebug=off;
20;22;RFDEBUG=OFF;
2018-01-08 14:39:15.013 RFLink: Controller Initialized!...
2018-01-08 14:39:15.097 RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2018-01-08 14:39:26.085 (RFLink) Temp + Humidity (Alecto V1)
2018-01-08 14:40:25.353 New sensors allowed for 5 minutes...
2018-01-08 14:57:10.364 RFLink: Controller Initialized!...
2018-01-08 14:57:10.449 RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2018-01-08 14:57:39.380 New sensors allowed for 5 minutes...
