My setup is a Wemos D1 with a BMP280 sensor attached to it. This reports to Domoticz.
As Domoticz didn't have the BMP280 sensor standard onboard, I requested it. They added it, which is nice.
However, the pressure doesn't get registered right.
They use a standard JSON method, see here http://www.domoticz.com/wiki/Domoticz_A ... Fbarometer
/json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=TEMP;BAR;BAR_FOR;ALTITUDE
The above sets the parameters for a Temp+Humidity+Barometer device
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
TEMP = Temperature
BAR = Barometric pressure
BAR_FOR = Barometer forecast
ALTITUDE= Not used at the moment, can be 0
Barometer forecast can be one of:
0 = No Info
1 = Sunny
2 = Paryly Cloudy
3 = Cloudy
4 = Rain
Does anyone have insight in the JSON send by EspEasy with the BMP280. Or is it adjustable to the standard Domoticz uses?
Thanks in advance
