I have followed the steps to flash the ESP (I have ESP8266-07) but when I look for the Wfi AP on my tablet, it does not show up in the list.
I tried ESPEasy V1.47 and then 2.0 but neither worked.
The steps I took:
>For V147
Run Flash.cmd
Enter serial port number
select size 4096
select version 147
The device flashed ok.
Rebooted the ESP and no AP found
>For V2
Run FlashESP8266.exe
Select comport 8 from pull down
Select image using "firmware" pull down (I tried "normal" then tried "dev" version
Reboot device
No AP
Before I flashed the device, I tested it by flashing my previous MQTT app (using Arduino IDE) and it was running fine, so I know the device is ok and wifi is working)
Any help much appreciated, I am not sure if I have overlooked something and don't know how to debug from here.
Dave
No AP for ESP Easy
Re: No AP for ESP Easy
I figured it out. For some reason I thought the module was same as 12E with 4096 flash but it only has 1024 flash.
