[SOLVED] ESP Easy Mega - InfluxDB works again with ESPEasy_v2.0.0-dev7_dev
Posted: 22 Mar 2017, 14:21
by lukaszj
I had an issue with not working InfluxDB write on dev-03, but I've upgraded to latest dev-07 - and it works!
The setup with Generic Advanced HTTP [TESTING] is here:
http://imgur.com/a/RyjzU
The goal was to sent 3 different values form BME280 (Temp/Humi/Pressure)
So instead of complaining - I just wrote this to let you know that it works
Re: [SOLVED] ESP Easy Mega - InfluxDB works again with ESPEasy_v2.0.0-dev7_dev
Posted: 22 Mar 2017, 19:09
by krikk
good to hear that i am not the only one using that, influxdb + grafana still the best graphs
Posted: 22 Mar 2017, 21:16
by lukaszj
I would love to get the SDS011 under ESP Easy Mega. Currently we have only the Sharp dust sensor, and it is... crappy
The SDS011 is managed via serial interface, commands are simple, documentation is quite good... And it produces very nice comparable results:
https://goo.gl/LZdKSy (or just for results:
http://weather.jokielowie.com/
Where can make the request?
Posted: 23 Mar 2017, 12:57
by krikk
there are already plugins for serial devices for example:
https://github.com/letscontrolit/ESPEas ... _MHZ19.ino, so should be easy to adapt this code to your sensor, every pull request (or code in every form) is welcome.
Posted: 23 Mar 2017, 13:20
by lukaszj
Hmmm... this looks easy enough, although I'm not a programmer. Now I definitely need to get another SDS011 and Arduino IDE ^^. Thanks!
Posted: 15 Apr 2018, 00:53
by fbrors
i can't verify your solution. please share your config.dat. "This file contains the ESP main configuration settings, except security data." (
https://www.letscontrolit.com/wiki/inde ... _interface )
