I'm creating a little project of mine, for which I need to establish communication between microchip (any ie. 16f1937 or faster 18f4550) to pass commands send from domoticz/openhab or other source and perform certain actions.
Since I havent succeded so far with that, I created simple and very early version of light driver based on PWM code, which turns ON and OFF 8 light points in the room, one by one from 0 to 100% of brightness. ESP sets 0 or 1 on one of the GPIO pins, and PIC chip based on the state of that pin drives PWM accordingly to animate lights. But I'd like to add more sequences/scenarios for turning lights ON and OFF, and attach more lights/LED strips to the same PIC controller. Using pin states is not possible, as I'd run out of pins very soon. So I need to pass commands via i2c, and here's where I need some help/direction how to do this easly.
Is there a way to achieve that using any of the existing plugins in ESPeasy or do I rather need to make new custom plugin? PIC controller I'll handle, at least I think so
PICmicrochip/ESP8266 - i2c communication
Re: PICmicrochip/ESP8266 - i2c communication
You could use the ser2net plugin and send the data using serial?
Script it from Domoticz and send it to the pic through espeasy.
Using a PWM expander seems easier and is implemented in ESPEasy.
PWM expander is some solution but it would be tricky to code all those scenarios and animate lights on all channels to work without a glitch. It's good to set PWM level and forget about it, but acting according to lookup table or incrementation would fail I think. Besides PIC can do much more than PWM, while ESP is for communication and basic sensors.
Ser2net seems to be ok, but... I dont know how to get it to work yet. Need to educate myself a bit.
But still would be nice to have some kind of generic and configurable i2c plugin for custom devices and MCUs.
