My switch works - done by tutorial..
Now, how do I make it change state, rather than turn on - every time I hit it?
Here is my setup in ESPEasy and the results in Domoticz
http://imgur.com/a/GXXLA
Switching the switch off again?
Re: Switching the switch off again?
Looks like you're using a push button. So select this (in field "switch button type") and it will toggle the state each time you press it.
I chose "Push Button Active High" - and now it works like a charm.
Thank you for the swift reply!
Always a joy.
You can even fine-tune the behaviour: depending on the selection (active high/active low) the toggle happens on pushing or releasing the button.
