BMP280 give wrong temp at below o
The BMP280 shows in the transition to frost a wrong temperature value. The measured value jumps nearly 2 degrees up.
Re: BMP280 give wrong temp at below o
I also had too high readings and I think that error is from continuous measurement in Bosch sensor so I set standby 1000ms (and some other settings) in this commit https://github.com/letscontrolit/ESPEas ... 25e985955a and my reading now are correct.c0ding4fun wrote:The BMP280 shows in the transition to frost a wrong temperature value. The measured value jumps nearly 2 degrees up.
I tested it on my BMP280 and on my BME280 they both show now values close to my reference ds18b20 (before that commit 1-2 degrees up).
Sorry, did not work. Same issue: going below zero a jump to 1.6 C.
Thanks for your reply do
sorry wrong reading... deleted my comment.
BME280 delivers below zero also false temperature value
With my outside temperature sensor on the chart is in the morning a jump at minus 2.1 degrees to zero and then again a jump at minus 2.1 degrees:
Could this be caused by an incorrect formula calculation from ESPEasy because I also correct the temperature measurement value with this formula:
