sorry for my english, but I have a few questions:
1) anywhere on the forum did not find information about the integration of the server and RFLINK MQTT brigde https://github.com/enc-X/mqtt-rflink-bridge Are there any examples of work? Why RFLINK author does not write about it openly?
2) I would like to integrate this RFLINK home automation system MAJORDOMO (majordomo.smartliving.ru) Russian-speaking users. Is there any API automation?
MQTT integration
Re: MQTT integration
1) It is mentioned on the links page: http://www.nemcon.nl/blog2/links
Now added some more links as well.
2) Majordomo looks very nice. Is it only Russian or does it have multi language support?
Integration can be done directly using the serial text based protocol which is fully described here: http://www.nemcon.nl/blog2/protref
for any additional questions on this protocol you can mail frankzirrone@gmail.com
Of course you have our full support for this.
Alternatively one could use or extend on of the MQTT implementations.
These are not created or maintained by us.. so we only know the ones that are brought to our attention or that can be found by searching github etc.
Majordomo international community http://majordomohome.com/
Very important, i think author of majordomo add support rflink protokol
Hi stuntteam, we brainstormed it before...
It would be really great if you could send mqtt data to a mqtt broker (+netshield) out of the box
Hello,Stuntteam wrote: ↑09 Feb 2017, 13:55 1) It is mentioned on the links page: http://www.nemcon.nl/blog2/links
I was actually checking more information about RFLink but accidentally found MajorDoMo mentioned here. And by being author of MajorDoMo I can post some information here.
1. MajorDoMo does have multi-language support and there is some more info about the system (in English) here: http://majordomohome.com
2. I really like RFLink project and definitely planning to do integration by writing a plugin
3. MQTT protocol can be already used with MajorDoMo so if there are MQTT implementation then it should not be a problem at all
