Please follow our tutorial for ESP Easy firmware loading...
Posted: 15 Nov 2015, 11:11
When you start using the ESP with ESPEasy, please keep using our tutorial on our wiki! Many forum issues about webgui are due to RAM issues with the wrong Arduino Package, either to old or to new. Also Arduino 1.6.6. is not supported.
As the wiki states: Use Arduino 1.6.5. and use ONLY Arduino IDE 1084 package
http://www.esp8266.nu/index.php/Tutoria ... are_Upload
If you need other Arduino versions on your system or other ESP Package releases, you can make a "portable" Arduino edition and use this only for ESP Easy projects. This is what I do to avoid conflicts with other projects that need older Arduino versions. Your preferences are kept within this portable version.
