Support for PZEM 004T Energy monitor
Re: Support for PZEM 004T Energy monitor
Can you make a pull request for it on GitHub?
That's easier to discuss compared to downloading ZIP and looking at separate files.
Why not. But unfortunately, I ve no knowlege about how to work with github! As said I'm a beginner.
I try to do something in "Pull requests" of ESPEasyPluginPlayground. Don't know if I'm in right way ...
I have seen your PR and already commented on it
Hello, thanks for plugin.
What kind of sensor to choose in domoticz to display data?
I have a pzem-004(V3.0) sensors, it can transmit more data than V1, can you add this data (VA, VAr, PF...) to the plugin?
Here's how, for example, in tasmota, this data is transferred:
I don't know about domoticz, because I use Jeedom.
But what I know is in Espeasy, it's not possible to have more than 4 data in a pluggin.
To bypass this, you can create a second occurence of this plugin with the same PZEM address than the first occurence. In this second occurence, you can select the other missing data that are not in the first occurence.
By the way, PZEMv3 only measures 6 parameters: Voltage, Current, Active power, Active energy, Frequency, Power factor. Other parameters that you can find in Tasmota (Apparent power, Reactive power, Today and yesterday energy) are calculated by Tasmota. It can be done with a dummy device in espeasy if you really need this information
I had difficulties with connecting 2 devices at the same time.
I connect both devices in parallel and if I connect load to one of it, then the data is displayed, and if I connect the load to both devices, then NAN.
I changed the GPIO. turned on / off Serial port.
Сan you write instructions for beginners. so that in steps from 0 to configure 2 devices on your firmware
Here are the pictures assembled diagram and settings, what needs to be changed in them?
First I update my code since last month. Updated files are viewtopic.php?f=5&t=2595&start=100#p41093. Perhaps it can help.
Sources are now https://github.com/djelau/ESPEasyPluginPlayground
Otherwise, you use GPIO1 as TX and GPIO3 as RX. I said "don't use HW serial" => You should invert these wires only on Node MCU side: Then, in the first occurence of the plugin, select "Software serial" as serial port. And configure like that (take care that data acquisisiton interval is more that 1sec also):
Thank you very much !
Everything works
p.s.
How to do, when the load is disconnected, the values changed to - 0, not NAN
Can this be done in the rules?
1. ESP: 2. Domoticz:
Add rules:
on PZ1#Voltage_(V) do
SendToHTTP 10.0.0.131,8080,/json.htm?type=command¶m=udevice&idx=95&nvalue=0&svalue=[PZ1#Voltage_(V)]
SendToHTTP 10.0.0.131,8080,/json.htm?type=command¶m=udevice&idx=96&nvalue=0&svalue=[PZ1#Current_(A)]
SendToHTTP 10.0.0.131,8080,/json.htm?type=command¶m=udevice&idx=97&nvalue=0&svalue=[PZ1#Power_(W)];[PZ1#Energy_(WH)]
on PZ2#Voltage_(V) do
SendToHTTP 10.0.0.131,8080,/json.htm?type=command¶m=udevice&idx=99&nvalue=0&svalue=[PZ2#Voltage_(V)]
SendToHTTP 10.0.0.131,8080,/json.htm?type=command¶m=udevice&idx=100&nvalue=0&svalue=[PZ2#Current_(A)]
SendToHTTP 10.0.0.131,8080,/json.htm?type=command¶m=udevice&idx=101&nvalue=0&svalue=[PZ2#Power_(W)];[PZ2#Energy_(WH)]
Dear all,
I am trying to use Djelau binaires on a NoceMCU. I have try to follow the guideline in this thread but whatever I've tried I kept with a "NaN" value display on the espeasy. Any idea why ? I have tried software serial and hardware serial with the same results.
I see the led on the PZEM blinking at the frequency of the request but kept with a NaN displayed. Any idea what's wrong ?
And the physical wiring :
but I am getting crazy in reading the "NaN" : I am sure I miss Something,... The question, is what part did I miss ?
If only one PZEM, then try select HW default, not SW serial.
Hello everyone,
Something to clarify for everyone: it's really not mandatory to use RX/TX pin of your WEMOS/nodeMCU => Any pin can be used with the solution of "software serial". Then, if you have trouble, first try to change for other pins. As an example, for my 5 PZEM on a WEMOS, here is the configuration: The first line means that TX of the PZEM is connected to GPIO 4 of te WEMOS.
The second line means that RX of the PZEM is connected to GPIO 5 of te WEMOS
To Jack2222:
Your hardware configuration seems to be OK:
The purple wire from TX PZEM is connected to GPIO 1 (don't care if named TX0 in espeasy)
On the other side the orange wire to RX PZEM is connected from GPIO 3 (don't care if named RX0 in espeasy) But I think the problem is your configuration of serial port in the general settings: Indeed, here TX is used to transmit whereas in the plugin PZEM you declare it to receive. Then you ve got trouble ....
Tell me if it solves your problem (otherwise don't use GPIO1 and GPIO3).
To Jack2222:
Dear all, a great support from the Community…
I have to confess, my only issue was about the power of the PZEM. The nodeMCU was not delivering the expected 5V I've tried with an other ESP (Wemos D1) and it worked directly… Now everything is working perfectly ! Thank you all !
- dynamicdave
I've just ordered a PZEM-004 v3 from China (with the external split CT sensor) - this particular version is housed in a plastic box for safety.
I'm a bit confused as to the correct connection for AC mains as they seem to vary between photos.
On the function diagram (screenshot-090) it shows 'Live' on the bottom terminal, while on the wiring diagram (screenshot-091) it shows it on the second from the bottom terminal.
I don't suppose it matters as it's AC mains - just thought I'd ask.
What is also confusing is the choice of colours.
Here in the UK we use 'brown' as 'live' and 'blue' as 'neutral' (no red wires at all) - but maybe in China it's different ??
- ScreenShot092.png (1.04 MiB) Viewed 1652741 times
- ScreenShot091.png (401.25 KiB) Viewed 1652741 times
- ScreenShot090.png (132.76 KiB) Viewed 1652741 times
If you swap live and neutral, I can imagine it will give a 180 degree phase difference between measured current and voltage, so if supported by the sensor, you could get a negative reading on the current.
The current is measured via a coil right?
So I expect there will be some issues with regards to determine the cos-phi or power factor as a coil will smooth out the current measurement anyway.
Not sure if that's a bad thing though, as some appliances do draw a really non-sinus current, which makes it hard to determine a proper apparent and real power consumption.
But it will give quite an incorrect power measurement on highly inductive loads or some dimming circuits that switch on and off during the period.
- dynamicdave
Thanks for the feedback.
Yes the current is measured using a coil clamped around one of the mains cables.
My question was... does it matter which way round the L and N wires are connect in respect of destroying the PZEM-004 ?
From your response I think it doesn't - just might affect the reading.
David.
David.
I don't have clear answer about how to connect L and N. But I made so many test when I developped the plugin without taking care of the direction of L/N. And I never noticed that the measurements was negative (cos phi or current). Thus I can deduce that PZEM internal component detects the direction of the current.
- dynamicdave
Hi @djelau
Thanks for your response.
The only thing I was concerned about was damaging (i.e. KILLING) the PZEM-004 by connecting the AC connections the wrong-way round.
I can't wait for the energy sensor to arrive so I can get the system up and running - sounds like a lot of fun.
PS: I've ordered the version that comes in a plastic box as I thought that would be safer !!!!!
There is no wrong way as it is AC. It can be connected in any direction.
And about wires color, neutral shall be blue. Line can be any color except blue, green/yellow (common colors are red, brown, black). This is the norm in France.dynamicdave wrote: ↑04 Feb 2020, 13:31 What is also confusing is the choice of colours.
Here in the Netherlands we used to have "red" and "green" as wire colours until the '70s I guess.
Those were rather bad chosen colors for several reasons:
- Red was neutral, green was "live". That's counter intuitive.
- Red / Green is the most common form of color blindness.
So we now have:
- Blue for neutral
- Brown for "live"
- Black for "live" to switch something on/off (e.g. from a wall switch to a light bulb)
- Yellow/Green for earth/ground.
There is also a grey one possible, but that was for 3-phase if I'm not mistaken. (0-line???)
- dynamicdave
Well I'm sort of hoping that now we have left the EU (I live in the UK) we'll be able to change the colour of our wires back to the scheme we had when I was a lad.
Red was Live
Black was Neutral
Green was Earth
Ha, ha, ha - wishful thinking.
Red was Live
Black was Neutral
Green was Earth
So, you have your answer about the connection of phase and neutral: do the opposite of me and it will work (I am from France).
NodeMcu + PZEM-004Tv30 (2pcs), works finedjelau wrote: ↑30 Nov 2019, 23:05 Hi guys,
This is my first post, so keep cool. I'm a great fan of ESPeasy; So I try to contribute with this code for PZEM004Tv30. I'm not a software expert so please be tolerant with me.
Hardware part:
PZEM004Tv30 can be wired in parallel without any aditionnal component: simply connect RX of PZEM together and Tx of PZEM together.
However, if programming the address, only one PZEM must be connected at once during address setting.
Software part:
If you want to use several PZEM, you need to add several occurence of the pluggin.
First occurence of pluggin allows to configure serial interface and modify address of PZEM.
Next occurence of the pluggin only allows to read an adress and reset energy
Energy can also be reset with command : http://<espeasyip>/control?cmd=resetenergy,<PZEM address> (example: "http://192.168.0.1/control?cmd=resetenergy,2" => Reset energy of the PZEM with address #2)
I modify PZEM004Tv30.h and PZEM004Tv30.cpp in order to be compatible with espeay serial. Please use it rather than official PZEM004Tv30.h and PZEM004Tv30.cpp from PZEM github.
Known restriction:
Don't use HW serial when several PZEM connected in series. Over 2 PZEM, frames conflict occurs and I don't know why. The solution is to use SW serial with GPIO3 as TX and GPIO1 as RX (or to use other pins with software serial)
I try only with WEMOS D1mini. So I compile 1M bin, but I don't test it. 4M is OK
Don't hesitate to give me your feedback. And feel free to improve my code.
Djelau
I requested "ESP_Easy_mega-20191003_PZEM_core_ESP8266_4M1M.bin"
But it does not work DS18B20
It works on the original firmware
Hello, i install the firmware pzem-004 v30 multiple, but only use one pzem, the problem is that the energy shown on espeasy is not correct. I use this firmware because it work better with a display oled ssd1306. Is there a way to fix this?
I don't test this configuration. Normally, plugins are independant so my plugin shouldn't have any impact on the DS18B20. But I'll check anyway.White_SinSay wrote: ↑13 Feb 2020, 03:29 NodeMcu + PZEM-004Tv30 (2pcs), works fine
I tested on 1 PZEM with sucess. What do you mean by not correct ? Stucked? alway 0?
Have in mind that the vealue is in kWh thus I could take a couple of hours to change.
I perform some test without problem on "ESP_Easy_mega-20191003_PZEM_core_ESP8266_4M1M.bin": I'm able to have DS18B20 and 2 PZEM on the same Wemos. My PZEM are connected with software serial on D1/D2 pin / Refresh 2s and 6s. DS18B20 is connected on D6 pin / Refresh 4s.White_SinSay wrote: ↑13 Feb 2020, 03:29 But it does not work DS18B20
My succesful tests:
DS18 with 3V3 supply => OK
DS18 with 5V supply => OK
DS18 with 840ohm PU => OK
DS18 with 10kohm PU => OK
DS18 9bit/10bit/11bit/12bit => OK
Create DS18 device first and then PZEM devices => OK
Erase the flash
Create PZEM devices first and then DS18 devices => OK
Recompile with ESPeasy20200204 => OK
Some question for you: the DS18b is detected (Device Address is proposed) ?
Are you sure about current capability of the NodeMCU to supply all devices ? It seems that power supply of the Node MCU is weak.
jack2222 wrote: ↑03 Feb 2020, 22:01 Dear all, a great support from the Community…
Hi, newbie here.
I bought a pzem-004t, an ESP2866 board, download some code from git, follow all instruction but.... I cannot manage in have all the set working.
My target is to publish over my mqtt server the values collected by the ESP from the pzem.
I wrote the routine for posting a value over mqtt and it works. So I paste all necessary for setting up the pzem comunication but... I need to uplug tx and rx cable during the sketch upload, and ok, but with the rx and tx connected the ESP is hung and no values are published because it cannot connect to the pzem
Can you help me?
thks
Can you help me?
thks
- 20200306_184033.jpg (1.8 MiB) Viewed 1651568 times
- 20200306_184005.jpg (1.97 MiB) Viewed 1651568 times
As already repeated: it's really not mandatory to use RX/TX pin of your WEMOS/nodeMCU => Any pin can be used with the solution of "software serial". See my post #165I need to uplug tx and rx cable during the sketch upload, and ok, but with the rx and tx connected the ESP is hung and no values are published because it cannot connect to the pzem
Yep, you' re right.
I changed ports and library.
The library I'm using is this
PZEM004Tv30.h instead of PZEM004T.h
And the setup is
PZEM004Tv30 pzem( D5, D6, 1 ) instead of serial. 1 is the address, no longer needed the fake ip address to be defined.
Thankyou, all works perfectly now.
Stefano
And the setup is
Stefano
- EE.PNG (15.29 KiB) Viewed 1651546 times
Hi all again.
All is in place, just one thing I cannot explain.
The current value is correctly shown on between 0 and 5 A range despite the values seems ok.
The card has no particular configuration, the card is very simple
entity: sensor.corrente
min: 0
severity:
green: 0
red: 16
yellow: 10
theme: default
type: gauge
max: 16
min: 0
severity:
green: 0
red: 16
yellow: 10
theme: default
type: gauge
max: 16
- 3.PNG (15.37 KiB) Viewed 1651417 times
- 2.PNG (13.48 KiB) Viewed 1651417 times
- 1.PNG (14.86 KiB) Viewed 1651417 times
What does the ESPEasy page show?
Maybe the issue is in the interpretation of the values between your system and ESPEasy?
Uhm...
MQTT receive an empty string, trying to modify the conversion from float to string but... 5 as maximum value... mmmhhh
- ABC.PNG (27.75 KiB) Viewed 1651017 times
Strange behavior...
Perhaps you can copy the value to a dummy device and then send this dummy value to your controller.
Or refer to them in rules and send them to the log using logentry.
logentry,"PZEM: [taskname#varname]"
Hi all, after some 'singular' test for debug purpose I reviewed the code and all work correctly now.
Thankyou
Thankyou
- okPZEM.jpg (76.56 KiB) Viewed 1646916 times
Hi Djelaudjelau wrote: ↑30 Nov 2019, 23:05 Hi guys,
Hardware part:
Software part:
Known restriction:
Djelau
I have tried your firmware and it works well. I wanted to ask you a pleasure could you create a firmware test version of esp easy or add the blynk library in your firmware?
thank you very much
sorry for my bad english
Marco
Hello Marco,
OK I'll try to add Blynk controller (C012). This is what you want ?
For 4Mb ?
Update:
I don't test it !
For 4Mb ?
Update:
I don't test it !
- ESP_Easy_mega-20200204_PZEM+Blynk_normal_ESP8266_4M1M.zip
- (552.01 KiB) Downloaded 3084 times
Thanks for all the great info shared o this thread. I have some doubts regarding safety, please forgive me if I am too newbie.
I have installed this pzem 004-t https://es.aliexpress.com/item/32955314 ... hweb201603_
The CT that comes with has no specs, however I assume it is a 100-1 ratio
I have seen information online that says if the secondary side of the CT becomes open cirtuited, then a dangerous high voltage could appear between the wires, so they should always be short circuited or using a burden resistor. The wires of the CT are quite thin, and I wonder if something dangerous could happen if the connection to the pzem loosens up, or the wires break for some reason. Should I install a burden resistor between them or something?
Thanks for your help!
What does CT mean ?
However, your PZEM is a v1.0 not a v30 because optocoupler are black and not white. So not use the plugin for PZEMv30 is not compatbile with your PZEM.
Hello, people
I try to connect ESP8266 to PZEM-004T. I load firmware and connect pins. But I can not see real digits. How can I check that PZEM-004 send any datat to ESP8266?
- Снимок2.PNG (27.63 KiB) Viewed 1641723 times
- Снимок.PNG (25.51 KiB) Viewed 1641723 times
- IMG_20200701_214333.jpg (2.76 MiB) Viewed 1641723 times
You connect a PZEM 004T v3 but the plugin that you use is not the one that I create for v3: PZEM-004Tv30-Multiple. So I can't help you.
Bad news
Any chance to connect PZEM 004T v3? What is diffrence? Maybe I can modify current plugin? Any tips and links will be helpful. Thank you in advance.
For PZEM v3, have a look to this post:
viewtopic.php?p=41093#p41093
I advice not to use NodeMCU because voltage level are 3v3 whereas PZEM expects 5V. Try a Wemos.
Sorry first time I use old firmware. Now I load yours. I connect RX-TX, TX-RX, G-GND, VIN-5V
but stell zeros... Can you please give advise what I do wrong?
- Снимок2.PNG (26.14 KiB) Viewed 1641575 times
- IMG_20200705_154654.jpg (4.14 MiB) Viewed 1641575 times
- Снимок.PNG (51.5 KiB) Viewed 1641575 times
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 24 guests
