Support for PZEM 004T Energy monitor
Re: Support for PZEM 004T Energy monitor
I'm trying to compile last ESPeasy V2.0 release (ESPEasy-2.0-20180510) but I'm getting the same errors as #71 http://www.letscontrolit.com/forum/view ... 585#p22585.
Did anyone solve this issue? How to compile this plug in under the latest releases of ESPeasy software?
Thanks in advance,
Thanks in advance,
i am also getting same error -1 randomely inbetween 1 minute readings... did you solved it ? what was the issue ? can you share ?Raspi_0x00 wrote: ↑27 Mar 2018, 11:24 Hi,
Problem solved. Works grate!!! The problem was that my PCB was configured for use UART0 (GPIO1..3).
When I changed do 13-15 everything is OK.
But I wonder why the Voltage measurement is such unstalble ( I get -1 in most readings).
Any ideas? Update rate is 1min
I have two pzem connected to my wemos ; I've also got this problem on one of them I never understood what was the cause, I simply ignore wrong reading in domoticz. Not very satisfying, but enough for my purpose
Do you think its related to software library of arduino ? or TTL 5V to 3.3V Converter issue ?
I don't think so as the 2 pzem are connected on the same module, so same software library ; I also don't use any converters and connected 5V to GPIO directly. This is not conventional but I wanted to make a test and it's working 24/7 since last november, so I think it's safe enough
It's something related to either the pzem itselft, or the GPIO used to connect them. But as my setup is now kinda "in production" I cannot make any tests anymore
I plan to buy some more for another equipment, it'll give me another testing possibility. But it'll be in a month or so
Dear all,
i have tried to compile the _P171_PZEM-004T.ino plugin (last version 8 months ago) and I get some errors and warnings:
lib/AS_BH1750/AS_BH1750A.cpp: In member function 'bool AS_BH1750A::startMeasurementAsync(TimeFuncPtr)':
lib/AS_BH1750/AS_BH1750A.cpp:518:7: warning: unused variable '_lastResult' [-Wunused-variable]
int _lastResult = -1;
lib/AS_BH1750/AS_BH1750A.cpp: In member function 'bool AS_BH1750A::delayExpired()':
lib/AS_BH1750/AS_BH1750A.cpp:533:19: warning: comparison between signed and unsigned integer expressions [-Ws
ign-compare]
if (timestamp < _lastTimestamp)
lib/AS_BH1750/AS_BH1750A.cpp:536:45: warning: statement has no effect [-Wunused-value]
delayTime = MAX_U_LONG - _lastTimestamp + timestamp;
lib/AS_BH1750/AS_BH1750A.cpp:542:24: warning: comparison between signed and unsigned integer expressions [-Ws
ign-compare]
return (delayTime >= _nextDelay);
ESPEasy-mega-20180809/src/_P171_PZEM-004T.ino: In function 'boolean Plugin_171(byte, Eve
ntStruct*, String&)':
ESPEasy-mega-20180809/src/_P171_PZEM-004T.ino:69:68: error: too many arguments to functi
on 'void addFormNote(const String&)'
addFormNote(string, F("SoftSerial: 1st=RX-Pin, 2nd=TX-Pin"));
ESPEasy-mega-20180809/src/WebServer.ino:2788:6: note: declared here
void addFormNote(const String& text)
Could anybody help me with these issues?
ign-compare]
ign-compare]
The signed/unsigned warning can be ignored.
The errors in WebServer.ino are also quite simple to resolve.
The functions used there in the "PLUGIN_WEBFORM_LOAD" case no longer need the first parameter "string"
So just remove that parameter:
Change it into:
addFormNote(F("SoftSerial: 1st=RX-Pin, 2nd=TX-Pin"));
Change it into:
I need to review this plugin in order to move it to the standard repository...
honestly still same issue, lack of time to improve it making it working with multiple devices (e.g. to monitor multiple lines or 3-phase AC).
yes, you are right, I already corrected the error regarding addFormNote function, but I am getting more errors after the warning
ESPeasySoftwareSerial.cpp:(.iram.text+0xd4): multiple definition of `sws_isr_0()'
.pioenvs/normal_ESP8266_1024/lib010/SoftwareSerial/SoftwareSerial.cpp.o:SoftwareSerial.cpp:(.iram.text+0xf8):
first defined here
.pioenvs/normal_ESP8266_1024/libc99/ESPEasySoftwareSerial/ESPeasySoftwareSerial.cpp.o: In function `sws_isr_1
ESPeasySoftwareSerial.cpp:(.iram.text+0xec): multiple definition of `sws_isr_1()'
.pioenvs/normal_ESP8266_1024/lib010/SoftwareSerial/SoftwareSerial.cpp.o:SoftwareSerial.cpp:(.iram.text+0x110)
: first defined here
.pioenvs/normal_ESP8266_1024/libc99/ESPEasySoftwareSerial/ESPeasySoftwareSerial.cpp.o: In function `sws_isr_2
ESPeasySoftwareSerial.cpp:(.iram.text+0x104): multiple definition of `sws_isr_2()'
.pioenvs/normal_ESP8266_1024/lib010/SoftwareSerial/SoftwareSerial.cpp.o:SoftwareSerial.cpp:(.iram.text+0x128)
collect2: error: ld returned 1 exit status
*** [.pioenvs/normal_ESP8266_1024/firmware.elf] Error 1
========================== [ERROR] Took 59.91 seconds ==========================
Environment normal_ESP8266_1024 [ERROR]
first defined here
Hmm, that's very strange, I only got those errors when building the latest ESP32 code.
Try to run a "clean" build first before recompiling.
Thank you very much.
Yes, it is very strange. I have cleaned the project and compiled it again but no luck... I dont understand what it is going on. I am using last mega release.
Any other suggestion will be appreciated.
kind regards,
kind regards,
Hello everybody,
My energy measurement is operationnal by following this post and this one http://www.domoticz.com/forum/viewtopic ... 14&t=20820
I use an ESP8266_4096.
But I have a problem :
- if I boot my ESP connected to the PZEM. My ESP doesn't start (no effect if I push on RESET button),
- If I boot my ESP (not connected to the PZEM), this one start normaly and after i can connect the PZEM to the ESP and the Energy measurement is OK.
This problem is painful because if i have a power cut, my Energy measurement does not restart.
Can you help me ?
Thanks in advance.
Can you help me ?
Thanks in advance.
Maybe you connected the sensor to one of the pins needed to indicate the boot-mode?
For example GPIO0, which is connected to the "Flash" button on NodeMCU boards, will put the ESP into flash mode when pressed.
I can imagine the sensor will do the same when connected to that pin.
I modified the GPIO pin : GPIO-12 and 13 instead of GPIO-14 and 15 and all is OK.Dim33 wrote: ↑29 Aug 2018, 00:16 Hello everybody,
Can you help me ?
Thanks in advance.
Hi there,
I've got a PZEM an tried to compile, but got same "multiple definition" error, as miki_tnt :
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\SoftwareSerial.cpp.o: In function `sws_isr_0()':
SoftwareSerial.cpp:(.iram.text+0xd0): multiple definition of `sws_isr_0()'
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\ESPeasySoftwareSerial.cpp.o:ESPeasySoftwareSerial.cpp:(.iram.text+0xd4): first defined here
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\SoftwareSerial.cpp.o: In function `sws_isr_1()':
SoftwareSerial.cpp:(.iram.text+0xe8): multiple definition of `sws_isr_1()'
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\ESPeasySoftwareSerial.cpp.o:ESPeasySoftwareSerial.cpp:(.iram.text+0xec): first defined here
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\SoftwareSerial.cpp.o: In function `sws_isr_2()':
SoftwareSerial.cpp:(.iram.text+0x100): multiple definition of `sws_isr_2()'
.pioenvs\test_ESP8266_4096\lib46c\ESPEasySoftwareSerial\ESPeasySoftwareSerial.cpp.o:ESPeasySoftwareSerial.cpp:(.iram.text+0x104): first defined here
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z21Plugin171_ReadVoltagev+0x8): undefined reference to `PZEM004T::voltage(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o: In function `Plugin171_ReadVoltage()':
ESPEasy.ino.cpp:(.text._Z21Plugin171_ReadVoltagev+0x25): undefined reference to `PZEM004T::voltage(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z21Plugin171_ReadCurrentv+0x0): undefined reference to `PZEM004T::current(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z21Plugin171_ReadCurrentv+0x1d): undefined reference to `PZEM004T::current(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z19Plugin171_ReadPowerv+0x0): undefined reference to `PZEM004T::power(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z19Plugin171_ReadPowerv+0x1d): undefined reference to `PZEM004T::power(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z20Plugin171_ReadEnergyv+0x0): undefined reference to `PZEM004T::energy(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o: In function `Plugin171_ReadEnergy()':
ESPEasy.ino.cpp:(.text._Z20Plugin171_ReadEnergyv+0x1d): undefined reference to `PZEM004T::energy(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z10Plugin_171hP11EventStructR6String+0x1c): undefined reference to `PZEM004T::PZEM004T(unsigned char, unsigned char)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o:(.text._Z10Plugin_171hP11EventStructR6String+0x20): undefined reference to `PZEM004T::setAddress(IPAddress const&)'
.pioenvs\test_ESP8266_4096\src\ESPEasy.ino.cpp.o: In function `Plugin_171(unsigned char, EventStruct*, String&)':
ESPEasy.ino.cpp:(.text._Z10Plugin_171hP11EventStructR6String+0x14e): undefined reference to `PZEM004T::PZEM004T(unsigned char, unsigned char)'
ESPEasy.ino.cpp:(.text._Z10Plugin_171hP11EventStructR6String+0x15b): undefined reference to `PZEM004T::setAddress(IPAddress con
Is there any suggestion to overcome this issue ?
Perhaps something changed in libraries, etc. in the last months ?
Thanx & Regards
Paolo
Thanx & Regards
Paolo
Would it give advice to throw the plugin into the latest software. PZEM has been working very well for me for half a year but I miss some features from the new software.
Greetings.
Greetings.
Please open an issue for it on GitHub and ask the maintainer to add it as a PR.
Thank you very much for your answer.
I did what you wrote.
Greetings.
GieBek
Greetings.
GieBek
I am not getting correct value for Watts when i did the calculation, example as below
Actual reading from meter = 232.20 Volts , 2.89 Amps, 665.00 Watts, 1311707.00 KWH
232.20 x 2.89 = 671.06 Watts, but in the meter it shows 665.00, can i know why its not accurate ?
Thanks in advance.
Thanks in advance.
I also have some problem with building this project
I have two builds ESPEasy_mega-20181231 and latest with changed Softwareserial library
ESPEasy_mega-20181231 compiles without error only if espsoftwareserial-3.2.3 used
20190110 compiles with new ESPEasySerial library also without any errors
But both firmwares always shows me 0.00, even old version mega 2.00 dev
I think that is not a hardware problem, wifi-iot firmware works fine, but with the hardware serial.
Im already tried to change GPIOs to another with the same result.
Interesting that is no voltage measuring in the log, A W Wh only
- Снимок.JPG (100.53 KiB) Viewed 1708406 times
Hi guys,
I got working on one esp-12f 6 of PZEM 004T. Probably I could connect up to 8 PZEM in the same time to one esp-12f.
The idea was to use many PZEM 004T on one esp-12f without using address of each one. I connected each one in parallel with RX, TX, and GND. For select with whom I am communicating right now I decided to use esp-12f ports.
If anyone interested I would share my schematic and plugin.
Thank you.
Thank you.
- IMG_20190330_161357_750.jpg (73.95 KiB) Viewed 1707129 times
- IMG_20190330_105736.jpg (2.54 MiB) Viewed 1707129 times
I'm interested - can you send me plugin ?
Also you can share public
Hi serjkru,
I'm very interested, too! This seems to have a good fit with the direction I'd like to take, which is to measure power use in each (main) circuit in my house.
I'd be very happy if you could share your schematic and plugin, please.
Thanks in advance,
Andrew
Thanks in advance,
Andrew
Hi guys,
Thank you for your interest.
There is a pdf how to connect them
Plugin for PZEM-004T.(I used one from playground but change it a lot)
Also I had to change Software serial ESPeasySoftwareSerial.cpp because original didnot work.
I think I did not mess something.
If you have a question, do not hesitate!
- PZEM-004T.zip
- (693.54 KiB) Downloaded 4119 times
If someone use OpenHab there is sample:
items
sitemap
items
Number Sensor_Laundry_Voltage "Laundry [%.1f V]" <voltage>(Home) [ "LaundryVoltage" ] { mqtt="<[myhome:/HouseVACMeter/PZEM_1/Voltage(V):state:default]" }
Number Sensor_Laundry_Current "Laundry [%.1f A]" <current>(Home) [ "LaundryCurrent" ] { mqtt="<[myhome:/HouseVACMeter/PZEM_1/Current(A):state:default]" }
Number Sensor_Laundry_Power "Laundry [%.1f W]" <power> (Home) [ "LaundryPower" ] { mqtt="<[myhome:/HouseVACMeter/PZEM_1/Power(W):state:default]" }
Number Sensor_Laundry_Energy "Laundry [%.1f Wh]" <energy> (Home) [ "LaundryEnergy" ] { mqtt="<[myhome:/HouseVACMeter/PZEM_1/Energy(Wh):state:default]" }
Frame label="House Sensors" icon="house"{
Text label="Power management" icon="power" {
Text label="Laundry" icon="energy" {
Text item=Sensor_Laundry_Voltage label="Voltage" icon="energy"
Text item=Sensor_Laundry_Current label="Current" icon="energy"
Text item=Sensor_Laundry_Power label="Power" icon="energy"
Text item=Sensor_Laundry_Energy label="Energy" icon="energy"
Hi guys,
I have developed many projects for my smart house but not sure when I should post them.
If someone lives in US or Canada, you might be interested in WiFi wall switch.
My idea was to use jst regular wall switch and put all elecrtonics right under switch button. You can see it on the photoes:
It is dimmable switch with two buttons.
I created plugin for it as well and connected to OpenHab.
Also I developed two version of Humidity/Temperature/Pressure devices. I use BME280 as sensor.
One of them looks like usb stick for remoute mouse or keyboard another one a little bit bigger.
- usb BME280.png (2.84 MiB) Viewed 1707085 times
- Light3.png (3.56 MiB) Viewed 1707088 times
- Light2.png (4.63 MiB) Viewed 1707088 times
- Light.png (72.34 KiB) Viewed 1707088 times
@serjkru.
Please could you post the wiring schematic for the PZEM-004 modules to the ESP-8266 module,I do not see the pdf file.
Looking at the wiring picture posted earlier, you are sequentially supplying power to the PZEM modules and taking readings to send to openhab.
Good idea to save IO pins !
Cheers mate.
Very nice work !
Very nice work !
Very good idea.
What is the reading time of all sensors?
How often can you read?
Hi Guys!
Thank you Serjkru for firmware. I tried with two device (Wemos D1 4 MB, and Wemos D1 mini 4 MB), but I did not found the Voltage & Current (AC) in device list.
Where did I go wrong?
Thank you
Best
Tamas
Thank you
Best
Tamas
"P183-Voltage & Current (AC) - PZEM-004T" almost at the end of the list of devices
I did not found.
Here is the picture about the last devices.
Thank you
Best
Tamas
Thank you
Best
Tamas
Try with attached file
- firmware_PZEM004T multiple.zip
- (584.94 KiB) Downloaded 3722 times
RobertM, you are GENIUS!
It works!
Thank you very much!
Best
Tamas
It works!
Best
Tamas
serjkru Why did you removed R15?
And why you swap R17 to 120 Ohm except 510 Ohm?
It would not be enough to solder 1k resistor as in the picture?
Hi all,
I'm using the firmware provided by serjkru and is working fine (pzem-004t v2.0)...good job
I have another question: is it possible to use the PZEM-004T V3.0 ? The firmware on the board has changed and I think the protocol is different, so no communication with esp.
The last board I got is 3.0
Anyone is working with that kind of board ?
Thank you
Gianluca
Thank you
Gianluca
you should have used USPS service, it is very good
Now USPS employees can use liteblue portal (liteblue usps gov) to get all the benefits.
Hi I ordered PZEM-004 and got V3.0 version.
This version have new mdbus MTU protocol.
Someone tried develop a plugin?
Friends, I bought PZEM 004t v3, he refused to work on this firmware. I found articles in the network, how people use the corrected libraries for the PZEM 004t v3. Maybe someone of you can download a new library and upload it with a new firmware for 4mb?
gumilev If you need only one device you can use Tasmota software.
PZEM004T v3 uses same protocol as PZEM-016 So you need set proper rx and tx gpio's in config.
Thanks for the advice, it really works, this is enough to transfer data using MQTT to Domoticz. However, I will continue to wait for the plugin to be updated for EspEasy. In order to run pzem004t v3.0 in tasmota - it was necessary to enter only one line:
{"NAME":"HW-655 PZEM","GPIO":[0,62,0,98,0,0,0,0,0,0,0,0,0],"FLAG":0,"BASE":1}
Then we assign gpio and go configure mqtt for data transfer!
- Screenshot_20190802-030452_Chrome.jpg (422.63 KiB) Viewed 1700285 times
- Screenshot_20190802-030323_Chrome.jpg (336.19 KiB) Viewed 1700285 times
- Screenshot_20190802-030427_Chrome.jpg (378.09 KiB) Viewed 1700285 times
Can you make an issue for it on GitHub and provide a link to this topic as well.However, I will continue to wait for the plugin to be updated for EspEasy
I have to order one of these sensors too before I can work on it.
But since I've been doing a number of Modbus plugins recently I don't expect it to be very hard to do.
Is it similar to model 017?
Unfortunately, I can’t help. My copy-paste programming level, all that I could find and try, I outlined above.
I am new to automation. I got PZEM 004t. Anyone can guide how I can add it to Home Assistant as Energy Meter. Thanks in advance
Hi guys,
This is my first post, so keep cool. I'm a great fan of ESPeasy; So I try to contribute with this code for PZEM004Tv30. I'm not a software expert so please be tolerant with me.
Hardware part:
PZEM004Tv30 can be wired in parallel without any aditionnal component: simply connect RX of PZEM together and Tx of PZEM together.
However, if programming the address, only one PZEM must be connected at once during address setting.
Software part:
If you want to use several PZEM, you need to add several occurence of the pluggin.
First occurence of pluggin allows to configure serial interface and modify address of PZEM.
Next occurence of the pluggin only allows to read an adress and reset energy
Energy can also be reset with command : http://<espeasyip>/control?cmd=resetenergy,<PZEM address> (example: "http://192.168.0.1/control?cmd=resetenergy,2" => Reset energy of the PZEM with address #2)
I modify PZEM004Tv30.h and PZEM004Tv30.cpp in order to be compatible with espeay serial. Please use it rather than official PZEM004Tv30.h and PZEM004Tv30.cpp from PZEM github.
Known restriction:
Don't use HW serial when several PZEM connected in series. Over 2 PZEM, frames conflict occurs and I don't know why. The solution is to use SW serial with GPIO3 as TX and GPIO1 as RX (or to use other pins with software serial)
I try only with WEMOS D1mini. So I compile 1M bin, but I don't test it. 4M is OK
Don't hesitate to give me your feedback. And feel free to improve my code.
Djelau
Hardware part:
Software part:
Known restriction:
Djelau
- 4Mbin+1Mbin.zip
- (1.07 MiB) Downloaded 5974 times
