I build a raspberry with Jessie Lite & Domoticz.
Connect the Raspberry with usb on an Arduino 2560 board with NRF24L01 transmitter.
http://blog.applamp.nl/posts/nrf24l01-m ... p-led-rgbw
I Had another configuration with the NRF24L01 connected to the GPIO of the rasp an can adjust the Milight flood lamp, so transmitter works ( not always)
Now the problem is , de milight won't pair when I send the code with domoticz: 10;MiLightv1;F746;01;34BC;PAIR;
I have even try to reset the flood light, but pairing by his lamp is different the a bulb version.
BTW , the Arduino board leds do flashes when I send commands
Please help
MiLight Flood pairing failure
Re: MiLight Flood pairing failure
After using a second rasp with NRF24 on the GPIO on listening mode,
I concluded that the nrf24L01 connected on the arduino isn't transmitting!
That was a config error, now it works, at least transmitting,
But pairing doesn't work
