WH2A (Branded as Lacrossetechnology and Tesa Weather Pro)
Posted: 19 Jan 2017, 17:06
Would it be possible to add support for the WH2A transmitter. I purchased mine from: https://www.aliexpress.com/item/Transmi ... 0.0.Ihdr0l
But can also be seen here:
http://shop.lacrossetechnology.com.au/t ... itter.html
Log is below for temperature around 26,7 and humidity around 41 %:
10;rfdebug=on;
20;0C;RFDEBUG=ON;
20;0D;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,870,390,870,390,870,390,870,390,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,420,870,1380,870,420,870,390,870,1380,870,420,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;0E;DEBUG;Pulses=48;Pulses(uSec)=450,810,360,840,1320,810,390,870,390,870,390,870,390,870,390,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1380,870,1380,6990;
20;0F;DEBUG;Pulses=100;Pulses(uSec)=60,840,1290,840,1290,840,1290,840,1350,870,1380,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,1380,870,390,870,420,870,390,870,390,870,390,870,1350,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,1380,870,1350,870,1380,6990;
20;10;DEBUG;Pulses=222;Pulses(uSec)=1410,1410,2070,660,600,2130,2070,660,600,2130,2100,660,600,2130,2070,660,2070,660,2070,660,2100,660,2070,660,2070,660,600,2130,2070,660,2100,660,600,2130,600,2130,600,2130,600,2130,600,2130,600,2130,1350,1410,2070,660,600,2130,2070,660,630,2130,2070,660,600,2130,2070,660,2070,660,2070,660,2070,660,2070,660,2070,660,600,2130,2070,660,2100,660,600,2130,600,2130,600,2130,630,2130,600,2130,630,2130,1350,1410,2070,660,600,2130,2070,660,630,2130,2070,660,600,2130,2070,660,2070,660,2070,660,2070,660,2070,660,2070,660,600,2130,2070,660,2100,660,600,2130,600,2130,630,2130,600,2130,600,2130,600,2130,1350,1380,2070,660,630,2130,2070,660,600,2130,2070,660,600,2130,2100,660,2070,660,2070,660,2100,660,2070,660,2070,660,600,2130,2070,660,2070,660,600,2130,600,2130,630,2130,600,2130,600,2130,600,2130,1350,1380,2070,660,600,2130,2100,660,600,2130,2070,660,600,2130,2070,660,2070,660,2100,660,2070,660,2070,660,2070,660,600,2130,2070,660,2070,660,600,2130,630,2130,630,2130,600,2130,600,2130,600,2130,1230,6990;
20;11;Biltema;ID=0002;TEMP=00dd;HUM=32;
20;12;DEBUG;Pulses=118;Pulses(uSec)=480,870,390,900,390,870,420,870,390,870,390,870,390,870,1380,870,390,870,1350,870,1380,870,1380,870,1380,870,390,870,1350,870,1380,870,1380,870,420,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1380,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,390,870,390,870,390,870,390,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,390,870,1380,870,1380,870,1380,870,1380,6990;
20;13;DEBUG;Pulses=48;Pulses(uSec)=360,840,360,840,360,810,390,810,360,870,1380,870,1380,870,390,870,1380,870,390,870,1380,870,1380,870,1380,870,420,870,1380,870,1380,870,1380,870,1380,870,420,870,390,870,1380,870,1380,870,1350,870,1380,6990;
20;14;DEBUG;Pulses=98;Pulses(uSec)=1380,810,1320,810,1290,840,360,840,1350,870,1380,870,1380,870,420,870,390,870,1380,870,1380,870,1350,870,390,870,1380,870,1380,870,1380,870,1350,870,390,870,390,870,1350,870,390,870,1350,870,1380,870,390,870,1380,870,420,870,390,870,390,870,390,870,420,870,1380,870,1350,870,390,870,1350,870,390,870,1380,870,1380,870,1380,870,390,870,1380,870,1380,870,1380,870,1380,870,390,870,420,870,1380,870,1350,870,1380,870,1380,6990;
10;rfdebug=off;
20;15;RFDEBUG=OFF;
10;rfdebug=on;
20;0C;RFDEBUG=ON;
10;rfdebug=off;
20;15;RFDEBUG=OFF;
