AcuRite Model: 00592tx Temperature and Humidity Sensor log
This sensor is recognized by RFLink and Domoticz , but it is very intermittent . Sometimes it will update a few times in a day and other times it will skip a couple days. It seems the latest firmware may have made it worse. The included temperatures are in degrees Fahrenheit. The temperatures and humidity levels reported are correct.
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
10;version;
20;01;VER=1.1;REV=45;BUILD=09;
20;C6;DEBUG;Pulses=306;Pulses(uSec)=240,210,390,30,210,210,390,30,210,210,210,210,210,210,390,30,180,210,180,210,180,210,180,210,390,30,390,30,180,240,180,240,180,240,180,240,180,240,180,240,180,240,180,240,360,60,180,240,180,240,360,60,180,240,360,60,180,240,360,60,360,60,180,240,180,240,360,60,180,240,150,240,360,60,360,60,150,240,180,240,360,60,360,60,150,2100,570,480,540,480,570,480,540,450,360,60,360,60,150,270,150,240,360,60,150,270,150,240,150,270,330,60,150,270,150,270,330,60,150,270,330,90,150,270,330,90,150,270,360,60,150,270,150,270,150,270,330,60,150,270,150,270,150,270,150,270,330,90,330,90,150,270,150,270,150,270,150,270,150,270,150,270,150,270,150,270,330,90,150,270,150,270,330,90,150,270,330,90,150,270,330,90,330,90,150,270,150,270,330,90,150,270,150,270,330,90,330,90,150,270,120,270,330,90,330,90,150,2130,540,480,540,480,540,480,510,510,330,90,330,90,120,300,120,270,330,90,120,300,120,300,120,300,330,90,120,300,120,300,330,90,120,300,300,120,120,300,300,90,120,300,300,120,120,300,90,300,120,300,300,120,90,300,90,330,90,330,90,300,300,120,270,150,90,330,60,330,90,330,90,330,90,330,60,330,60,330,90,330,270,180,60,360,60,360,240,210,30,390,240,180,30,390,210,210,180,240;
Temp 75
humidity 48
20;D1;DEBUG;Pulses=310;Pulses(uSec)=240,210,390,30,210,210,390,30,210,210,390,30,210,210,210,210,210,210,390,30,210,210,180,210,180,210,180,240,390,30,390,30,180,240,180,210,180,240,180,240,180,240,180,240,180,240,180,240,360,30,180,240,180,240,360,60,180,240,360,30,180,240,360,60,360,60,150,240,360,60,180,240,180,240,180,240,360,60,360,60,180,240,360,60,150,240,150,240,150,2100,570,450,570,450,570,450,540,480,330,60,360,60,150,270,150,270,330,60,150,240,150,270,150,270,360,60,150,270,150,240,360,60,150,270,360,60,150,270,360,60,150,270,330,60,150,270,150,270,150,240,330,90,150,270,150,270,150,270,150,270,330,60,330,60,150,270,150,270,150,270,150,270,150,270,150,270,150,270,150,270,330,90,150,270,150,270,330,90,150,270,330,90,150,270,330,90,330,90,150,270,330,90,150,270,150,270,150,270,330,90,330,90,150,270,330,90,150,270,120,270,120,2130,540,480,540,510,540,510,510,480,330,90,330,90,150,270,120,270,330,90,120,300,120,270,120,300,330,90,120,270,120,300,300,90,120,300,300,120,120,300,300,120,120,300,300,120,120,300,120,300,90,300,300,120,120,300,120,300,90,300,90,330,300,120,270,150,90,330,90,330,90,330,90,330,90,330,90,330,90,330,60,330,270,150,60,330,60,330,270,180,60,360,240,180,30,360,240,210,210,210;
Temp 76
humidity 48
20;D7;DEBUG;Pulses=306;Pulses(uSec)=240,210,390,30,210,210,390,30,210,210,210,210,210,210,390,30,180,210,180,210,180,210,180,240,360,30,390,30,180,240,180,210,180,240,180,240,180,210,180,240,180,240,180,240,360,30,180,240,180,240,360,60,180,240,360,60,180,240,360,60,360,60,180,240,360,60,180,240,150,240,180,240,360,60,360,60,150,240,360,60,150,240,150,240,150,2100,570,450,570,450,540,480,570,480,330,60,360,60,150,270,150,240,360,60,150,270,150,240,150,270,330,60,150,270,150,270,360,60,150,270,330,60,150,270,330,60,150,270,330,60,150,240,150,270,150,270,330,60,150,270,150,270,150,270,150,270,330,60,330,90,150,270,150,270,150,270,150,270,150,270,150,270,150,270,150,270,330,60,150,270,150,270,330,90,150,270,330,90,150,270,330,60,330,90,150,270,330,90,120,270,150,270,150,270,330,90,330,90,120,270,330,90,120,270,150,270,120,2130,540,480,540,510,540,480,540,480,330,90,330,90,120,270,120,270,330,90,120,300,120,300,120,270,330,90,120,270,120,300,300,90,120,300,300,120,120,300,300,120,120,300,300,120,120,300,120,300,120,300,300,120,120,300,120,300,120,300,90,330,300,120,300,150,90,330,90,330,90,330,90,330,90,330,90,330,90,330,90,330,270,150,60,330,60,360,240,150,60,360,240,180,60,390,210,210,210,210;
Temp 76
humidity 48
20;29;DEBUG;Pulses=225;Pulses(uSec)=240,210,210,180,390,30,210,210,420,0,210,210,390,30,210,210,390,30,210,210,210,210,210,210,390,30,210,210,210,210,390,30,180,240,390,30,390,30,360,60,180,240,180,240,180,240,180,240,180,240,180,240,180,240,360,60,180,240,360,60,180,240,360,60,360,60,180,240,150,240,180,240,360,60,150,240,360,60,150,240,150,240,360,60,150,270,360,60,150,270,150,270,150,270,150,2100,540,480,540,480,540,480,540,480,330,90,330,60,150,270,150,270,330,90,150,270,150,270,150,270,330,90,150,270,150,270,330,90,120,270,330,90,150,270,330,90,150,270,330,90,120,270,120,300,120,270,330,90,120,300,120,300,330,120,120,300,300,120,300,120,300,120,120,300,120,300,120,300,90,300,90,300,90,300,90,300,300,120,90,330,300,120,90,330,270,150,270,150,60,330,90,330,90,330,270,150,60,330,240,180,60,360,60,360,240,180,60,360,240,210,30,390,30,390,30,390,30,2250,420,600,420,630,390,660,60;
Temp 95
humidity 56
20;31;DEBUG;Pulses=220;Pulses(uSec)=240,210,390,0,210,210,390,30,210,210,180,210,210,210,390,30,180,210,210,210,360,30,180,240,390,30,390,30,180,240,360,30,360,60,360,60,180,240,180,240,180,240,180,240,360,60,180,240,360,60,180,240,360,60,150,240,360,60,360,60,360,60,360,60,360,60,180,240,150,240,150,240,360,60,150,240,150,240,150,240,150,240,150,270,150,2100,570,450,540,480,540,480,540,480,330,90,330,90,150,270,150,270,330,90,150,270,150,270,150,270,330,90,150,270,150,270,330,90,150,270,330,90,150,270,330,90,150,270,330,90,150,270,150,270,120,270,330,90,150,270,150,270,330,90,120,270,330,90,330,90,120,270,330,90,330,90,330,90,120,300,120,300,120,300,120,300,300,90,120,300,300,120,120,300,300,120,120,300,300,120,300,120,300,120,300,120,300,120,90,330,90,330,90,330,270,150,90,330,60,330,90,330,60,330,60,330,60,2190,480,570,450,570,450,570,450,600,210,210,210,240;
Temp 94
humidity 55
20;40;DEBUG;Pulses=252;Pulses(uSec)=240,210,390,0,210,210,390,30,210,210,390,30,210,210,210,210,180,210,390,30,180,240,180,210,390,30,180,210,390,30,360,30,180,240,360,60,180,240,180,240,180,240,180,240,180,240,180,240,360,60,180,240,360,60,180,240,360,60,180,240,360,60,180,240,360,60,360,60,360,60,360,60,180,240,150,240,150,240,180,240,360,60,360,60,330,60,150,240,150,2130,540,480,540,480,540,450,570,450,360,60,330,60,150,240,150,270,330,60,150,270,150,270,150,270,330,60,150,270,150,270,330,90,150,270,330,60,150,270,330,90,150,270,330,90,150,270,150,270,150,270,330,90,150,270,150,270,330,90,150,270,330,90,330,90,120,270,330,90,150,270,150,270,150,270,120,270,120,270,150,270,330,90,150,270,330,90,150,270,330,90,150,270,330,90,120,270,330,90,330,90,330,90,330,120,120,300,120,300,120,300,120,300,300,120,300,120,300,120,90,300,120,2160,510,510,510,510,510,540,480,540,270,150,270,150,60,330,90,330,270,150,60,330,60,360,60,360,240,180,60,360,60,360,240,210,30,390,210,210,30,390,210,240;
Temp 91
humidity 52
20;46;DEBUG;Pulses=302;Pulses(uSec)=240,180,390,30,210,210,390,30,210,210,210,210,210,210,390,30,180,210,210,210,210,210,180,210,390,30,390,30,210,210,180,240,360,30,390,30,180,240,180,210,180,240,180,240,390,30,180,240,360,30,180,240,180,240,180,240,360,60,180,240,360,60,180,240,180,240,180,240,180,240,180,240,180,240,180,240,150,240,360,60,360,60,180,240,180,2100,570,450,570,450,570,450,570,450,360,60,360,60,150,240,150,270,360,60,150,240,150,240,150,240,360,60,150,240,150,270,330,60,150,240,360,60,150,240,360,60,150,270,360,60,150,270,150,240,150,270,330,60,150,240,150,270,150,240,150,270,330,90,330,60,150,270,150,270,330,90,330,90,150,270,150,270,150,270,150,270,330,90,150,270,330,90,150,270,150,270,150,270,330,90,150,270,330,90,150,270,150,270,150,270,150,270,150,270,150,270,150,270,150,270,330,90,330,90,120,270,120,2130,540,480,540,480,540,510,540,480,330,90,330,90,120,270,120,270,330,90,120,300,120,300,120,300,330,90,120,300,120,270,330,120,120,300,300,90,120,300,300,120,120,300,300,120,120,300,120,300,120,300,300,120,90,300,120,300,90,330,90,300,300,150,270,150,90,330,90,330,270,150,270,150,60,360,60,330,60,360,60,360,240,180,60,360,240,180,30,390,30,360,30,390,210,210;
Temp 90
humidity 51
20;94;DEBUG;Pulses=290;Pulses(uSec)=240,210,390,30,210,180,390,30,210,210,210,210,210,210,390,30,210,210,180,210,390,30,180,240,390,30,390,30,180,210,180,240,180,240,390,30,180,240,180,210,180,240,180,240,390,30,180,240,180,240,360,60,360,60,360,60,360,60,180,240,180,240,360,60,360,60,360,60,180,240,360,60,150,240,180,240,150,240,180,240,360,60,150,240,150,2100,570,450,570,450,570,450,570,450,360,60,360,60,150,240,150,240,360,60,150,240,150,270,150,240,360,60,150,270,150,240,360,60,150,240,360,90,150,270,330,60,150,270,330,60,150,270,150,270,150,270,330,60,150,270,150,270,330,90,150,270,330,90,330,60,150,270,150,270,150,270,330,90,150,270,150,270,150,270,150,270,330,90,150,270,150,270,330,90,330,90,330,90,330,90,150,270,150,270,330,90,330,90,330,90,120,300,330,90,120,300,120,270,120,270,150,270,330,90,120,270,120,2130,540,480,510,510,540,510,510,510,330,90,330,90,120,300,120,300,330,120,120,300,120,300,120,300,300,90,120,300,120,300,300,120,120,300,300,120,120,300,300,120,120,300,300,120,90,300,90,330,90,330,300,120,90,330,90,330,270,150,90,330,270,150,270,180,60,360,60,360,60,360,240,180,60,390,30,360,30,390,30,390,210,210;
Temp 78
humidity 49
Solved: AcuRite Model: 00592tx Temperature and Humidity Sensor log
Re: AcuRite Model: 00592tx Temperature and Humidity Sensor log
I wanted to report that this senor is working now very reliably with firmware (R46). Thanks
