Alecto SA-33
Alecto SA-33
I have some Alecto SA-33 smoke detectors which according to the supported device list are supported. However I can not get them registered in Domoticz (they don't show up in the (unknown) device list when I push either the test button or the learn button) I have two other smoke detectors (FA20RF ) and they are working perfectly. Is there something extra I need to enable for the SA-33 to be detected/visible?
Re: Alecto SA-33
Hi Debink,
I've the same problem. Did you found a solution yet?
Thanks in advance, Bart
NB: The AS-33 (I bought 3) is different form the Flamingo FA20RF (witch I already had). On the outside they look the same, but on the inside the layout en some of the components in the PCB is different. I tried logging the AS-33 on the RFLink Loader, bus as you said, no response in the textbox ...
Domoticz on Raspberry Pi 3 with RFLink Gateway (433 MHz en NRF 2,4GHz) and EnOcean USB 300.
Re: Alecto SA-33
If you get nothing in debug mode on rflink it's probably frequency coded and not supported by RfLink(actually the receiver module)
Re: Alecto SA-33
The SA-33 is supported but there seem to exist some variants..
Re: Alecto SA-33
Do you have an RTL-SDR Adapter? If so, you could check the frequency. Maybe it is on 868MHz?
Can you upload a photo of the module?
Re: Alecto SA-33
Googling the internet i found this post.
I also have some SA-33 smoke detectors and also I can not get them registered in Domoticz.
I'm using an RFlink with fimrware 48.4
As xztraz suggested i tried the debug mode in the RFLink loader tool. I got response in the log window, but it doesn't make sence to me.
Can somebody help?
10;rfdebug=on;
20;0A;RFDEBUG=ON;
20;0B;DEBUG;Pulses=150;Pulses(uSec)=810,1950,750,1950,750,1950,750,1950,750,1950,1770,900,1770,900,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,810,4080,810,3900,3660,3720,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,1770,900,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,810,4080,810,3900,3660,3720,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,1770,900,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,810,4080,810,3900,3660,3720,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,1770,900,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,810,4080,810,6990;
20;0C;DEBUG;Pulses=150;Pulses(uSec)=810,1950,750,1950,750,1950,750,1950,750,1950,1770,900,1770,900,750,1950,750,1950,750,1950,750,1920,750,1950,750,1950,750,1950,750,1950,1770,900,810,4080,810,3900,3690,3720,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,1770,900,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,810,4080,810,3900,3660,3720,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,1770,900,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,810,4080,810,3900,3660,3720,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,1770,900,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,750,1950,1770,900,810,4080,810,6990;
20;0D;DEBUG;Pulses=264;Pulses
Re: Alecto SA-33
oh i forgot, my Alecto is a SA-30 and it's label says it's a v2.2
And yes, i know this is a year old topic, but i hope we can figure this out.
Re: Alecto SA-33
I also have 3 Alecto SA-33 Smoke detectors. V1.1 PD:1115. I was hoping to get them visual in Domoticz but no luck so far. I pushed the test button on the master, went through a hell of sound, but it does not show up at Domoticz. Anyone who has this working out there with some advice?
I did connect them together using the learn button, thats working, tested them also. RFLink R48. Domoticz is latest stable version 3.8153.
Re: Alecto SA-33
Make a bit longer debug log triggering the device a few times and mail that to frankzirrone@gmail.com
