I tried using some Waveman switches today. According to the list of supported devices it should work, but it does not seem to have a plugin in the current versions and I can't see any code in the publicly available source code.
Can anyone please tell if it is supposed to work?
When I manually register a Waveman switch in Domoticz, with house code and device number it sends commands like these:
10;Waveman;000050;1;ON
10;Waveman;000050;1;OFF
2016-12-29 00:52:54.775 Error: RFLink: Error/Unknown command received!...
20;88;Kaku;ID=50;SWITCH=4;CMD=ON;
20;89;TriState;ID=0aa000;SWITCH=0;CMD=OFF;
20;8D;DEBUG;Pulses=50;Pulses(uSec)=152e200b07231f0b07231f0b07231f0b072307230723072307230723072307230823072307231f0b07231f0b07231f0b07e9;
20;8E;DEBUG;Pulses=36;Pulses(uSec)=200a072106220721072107210621072307230723072307231f0b07231f0b07231f0b07e9;
20;8F;DEBUG;Pulses=44;Pulses(uSec)=200a07211d0a06211d0a062106210723072307230723072307230723072307231f0b07231f0a07231f0b07e9;
20;90;DEBUG;Pulses=40;Pulses(uSec)=200a06211d0a062107210621072107230723072307230723072307231f0b07231f0b06231f0b07e9;
I really wish that I could see the latest source code. As an experienced developer that would give me all the answers and I would be able to fix a new module if it shows out to be missing. Is there any plans on putting the source on for example GitHub?
